Terribly slow/long loading on devices using Emby
markdj
Did you try what I suggested?
Well, I have just deleted the plugin.video.emby folder and amazingly, that seemed to work. For now. I hope the problem doesn't return (I do have one other problem right now), but I'll check back tonight. Good suggestion, thanks!
Edit: I do have to note that I did downgrade to the stable version of Emby yesterday evening, but it gave me the same results then as well.
Edited by markdj
  • Like 1
Link to comment
Share on other sites
Guest
