FordGT90Concept 61 Posted April 14, 2018 Author Share Posted April 14, 2018 (edited) Updated to .68, tested, no change from before (message about audio/video not working). Enabled direct stream, worked. Same channel both times. Edited April 14, 2018 by FordGT90Concept Link to comment Share on other sites More sharing options...
FordGT90Concept 61 Posted August 13, 2018 Author Share Posted August 13, 2018 Live TV on Shield is quite terrible. The aforementioned audio desync is still present. The initial pause can now last upwards of a minute and it can happen again several minutes after it does the intitial pause. In terms of trick play, only pause/resume works. If you try to jump forward or backwards, there's an excellent chance the stream will simply freeze. Server is on 3.6.0.2 beta and I'm concerned that it hasn't seen an update in a long time (especially the retroactive timer patch on the 3.5.2 branch). Link to comment Share on other sites More sharing options...
ebr 14912 Posted August 13, 2018 Share Posted August 13, 2018 This is not my experience at all so it is very difficult to diagnose. You are streaming in seek mode, correct? Link to comment Share on other sites More sharing options...
FordGT90Concept 61 Posted August 13, 2018 Author Share Posted August 13, 2018 I assume so. All the settings are default. Link to comment Share on other sites More sharing options...
ebr 14912 Posted August 13, 2018 Share Posted August 13, 2018 Does the app say it is playing direct or remuxing? Link to comment Share on other sites More sharing options...
FordGT90Concept 61 Posted August 14, 2018 Author Share Posted August 14, 2018 Has to be remuxing. The Xbox One S has no problems doing live TV. They're connected to the same switch. Link to comment Share on other sites More sharing options...
Luke 37063 Posted August 14, 2018 Share Posted August 14, 2018 There hasn't been a beta server in a while due to this: https://emby.media/community/index.php?/topic/61079-3603-db-changes/ 1 Link to comment Share on other sites More sharing options...
