SuperNic 4 Posted March 13, 2021 Share Posted March 13, 2021 Dear support. In the past I tried a few times to activate camera uploads on my phones. It, in some ways, worked, but always with the same issue; it created maybe 5/10 library with the same path and settings. And so I had to manually delete them and then disable camera upload function. Today, after many app updates, I'd want to retry. Unfortunately, it creates 1680 and counting libraries! Please, help me removes them automatically, it takes so much time to remove one by one and please, try to find a solution to the problem. Thanks a lot. Link to comment Share on other sites More sharing options...
Luke 37049 Posted March 15, 2021 Share Posted March 15, 2021 Hi, please follow along here: Thanks. Link to comment Share on other sites More sharing options...
SuperNic 4 Posted March 16, 2021 Author Share Posted March 16, 2021 Ok, I'll follow the other post. Thanks, you can close it, if you want. Link to comment Share on other sites More sharing options...
