pdebelak 2 Posted November 27, 2013 Share Posted November 27, 2013 Hi again. I have many 3D Blu-Ray titles which I've ripped to my NAS as ISO files. I watch these 3D Movies using TMT5 and NVidia 3DTVPlay software and have been doing so for a while now. Alcohol 52% is the ISO mount software I use, and it works a treat. What I haven't been able to do so far is to work out how I set Media Browser to work with these ISO files so I don't have to load this manually (ie, the way I do now). Here is what I do to watch a Blu-Ray 3D ISO today: 1. Start Alcohol 52% and mount the ISO image 2. Start Total Media Theatre 5 and hit play I do these steps from the Windows desktop interface and would like Media Browser to handle this as it does with the other movies. I'm sure there is a simple answer out there, but I haven't found it yet. Any help would be greatly appreciated. Thanks Paul Link to comment Share on other sites More sharing options...
wraslor 70 Posted November 27, 2013 Share Posted November 27, 2013 Are you using media browser classic or theater 3 alpha? In classic go under external players and associate bluray and dvd and 3D with TMT5 as your external player (not iso) and point the iso mounter to your program of choice, I use VCD. Now when you hit play in media browser it will mount the iso and launch tmt5 and play. See this thread for details http://community.mediabrowser.tv/permalinks/1054/iso-playback-how-does-it-work If using theater it has a section under the config where you can pick external players as well but I'm having issues with it so can't be of much help. Link to comment Share on other sites More sharing options...
riverboat2001 16 Posted January 28, 2014 Share Posted January 28, 2014 Hi, I'm also having problems with this. If i mount the file first then it plays in TMT5 or WMP fine. But i can't get the image to mount automatically. I'm using Win7 MB3 DVDfab I've set up as you suggested above, but can't seem to get the image to mount automatically. Any help appreciated. Link to comment Share on other sites More sharing options...
bluc 21 Posted February 24, 2014 Share Posted February 24, 2014 (edited) sorry wrong forum. Edited February 24, 2014 by bluc Link to comment Share on other sites More sharing options...
