fc7 123 Posted August 21, 2015 Posted August 21, 2015 While testing version 590 I tried to login manually to Emby, with the manual login option. I noticed that there is no "Sign In" button so it's hard to tell if you triggered the login or not. I think I'm also facing a login problem since when I put the wrong password and press <Enter> the app will give me a message that the user or password are wrong but when I put the correct password the app is not doing anything and it's not login in either. Since there is no "Login" button I can't tell if the app is really trying to login or not unless I check the server logs. Can anyone else try to do a manual login and tell me if it's working for you? On the other hand adding a "Login" or "Sign In" buttong would not hurt I guess.
FrostByte 5257 Posted August 22, 2015 Posted August 22, 2015 I get the same error logging on manually
fc7 123 Posted August 22, 2015 Author Posted August 22, 2015 (edited) I get the same error logging on manuallyThanks for checking this. Maybe @@chessdragon136 can fix it for the next release. Sent from my iPad using Tapatalk Edited August 22, 2015 by fc7
