KRA 39 Posted April 26, 2015 Posted April 26, 2015 (edited) Has anyone else has this problem? i have installed the package on fresh centos7 setups and had.no problems I just did a centos7 mini install, I get no reply on port 8096 I tried disable selinux but only difference I notice after that is ssh stopped working should note I'm a complete noob on CentOS, never used it. Have used ubuntu quite a bit, and tested several other distro's also. But I struggle with CentOS now.. Edited April 26, 2015 by KRA
KRA 39 Posted April 26, 2015 Posted April 26, 2015 Ok, it was a firewall issue. I tried poking a hole in iptables but it did not help. So a simple "service firewalld stop" solved the issue.
psdl 5 Posted May 4, 2015 Posted May 4, 2015 Ok, it was a firewall issue. I tried poking a hole in iptables but it did not help. So a simple "service firewalld stop" solved the issue. as root: #firewall-cmd --list-all look at your zone ! # firewall-cmd --permanent --zone=your_zone --add-port=8096/tcp for https: (you can generate and put your own certificate under preferences/hosting) # firewall-cmd --permanent --zone=your_zone --add-port=8920/tcp # firewall-cmd --reload Hope this helps. firewalld is great. Use it for your care ! 2
robotmaxtron 0 Posted May 14, 2015 Posted May 14, 2015 (edited) Did a fresh install on a Red Hat Enterprise 7 machine, when I attempted to install it I got the following error: failure: repodata/repomd.xml from MediaBrowserServer-Dependancies: [Errno 256] No more mirrors to try. http://download.opensuse.org/repositories/home:/jose-pr:/MediaBrowserServer-Dependancies/RedHatEnterpriseServer_7Server/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found I fixed it by manually updating the repo to point to the CentOS 7 repo and it works as expected. Since the CentOS 7 Repo is the one that should be used for RHEL 7 boxes, it should be pretty trivial to point RHEL 7 boxes at the CentOS repo. I'll attempt to get a PR in as soon as I get some time but in the event that somebody can get to it first, that'll do the trick. I've opened an issue on GitHub: https://github.com/MediaBrowser/MediaBrowser.Build/issues/30 Edited May 15, 2015 by robotmaxtron
stangri 2 Posted May 15, 2015 Posted May 15, 2015 The WebApp is telling me there's a newer server version (3.0.5607.2), however the latest version available in the repo is 3.0.5588.1 (as can be manually verified here: http://download.opensuse.org/repositories/home:/jose-pr:/MediaBrowserServer/Fedora_20/noarch/). How can I update to the latest version of the server?
robotmaxtron 0 Posted May 15, 2015 Posted May 15, 2015 (edited) The WebApp is telling me there's a newer server version (3.0.5607.2), however the latest version available in the repo is 3.0.5588.1 (as can be manually verified here: http://download.opensuse.org/repositories/home:/jose-pr:/MediaBrowserServer/Fedora_20/noarch/). How can I update to the latest version of the server? You have the most up to date version of Emby from this repo, the owner of the repo (Jose I believe) will have to update it to grab the most current stable version. Possible solutions: Use the Beta release Use the Dev release Wait for the repo to be updated. I've reported this in Github: https://github.com/MediaBrowser/MediaBrowser.Releases/issues/14 Edited May 15, 2015 by robotmaxtron
stangri 2 Posted May 15, 2015 Posted May 15, 2015 You have the most up to date version of Emby from this repo, the owner of the repo (Jose I believe) will have to update it to grab the most current stable version. Possible solutions: Use the Beta release Use the Dev release Wait for the repo to be updated. I've reported this in Github: https://github.com/MediaBrowser/MediaBrowser.Releases/issues/14 Thanks, I've tried to enable the beta repository but there was no package MediaBrowserServer-Beta so I gave up and posted here. Is it possible to download the rpm from somewhere while I'm waiting for the repo to be updated? The download page on emby.media directs me to the repo.
robotmaxtron 0 Posted May 16, 2015 Posted May 16, 2015 Thanks, I've tried to enable the beta repository but there was no package MediaBrowserServer-Beta so I gave up and posted here. Is it possible to download the rpm from somewhere while I'm waiting for the repo to be updated? The download page on emby.media directs me to the repo. Not as far as I'm aware of, I am however running the most current (as of the time of this writing) dev version and everything's working as expected.
stangri 2 Posted May 16, 2015 Posted May 16, 2015 How can I switch to a Dev version? I know how to enable Dev repo, but what's the package name I need to install from there?
jose 73 Posted May 17, 2015 Posted May 17, 2015 How can I switch to a Dev version? I know how to enable Dev repo, but what's the package name I need to install from there? The latest release shuold be building itself , i have been busy with work and other personal matter so i haven' had the chance to update it. For the dev version once the repo is enabled you just need to try to update the server it should get the dev version instead. 1
mattman73 0 Posted May 21, 2015 Posted May 21, 2015 (edited) Hi I have tried to install this on my F19 system but i'm getting this error Protected multilib versions: ImageMagick-6.9.0-26.1.i686 != ImageMagick-6.7.8.9-5.fc19.x86_64 as yet I have not found any way round this error, could someone help please. Regards MattMan Ok found a fix, I removed ImageMagick and then install it again, MediaBrowserServer has now just install lets hope I can get it to work. Got it working but my Now tv boxes did not play anything, I would like to remove this and upgrade to F21 and install again and see if that helps but yum will not let me uninstall/remove the software. Edited May 26, 2015 by mattman73
stangri 2 Posted May 29, 2015 Posted May 29, 2015 Should we expect the changes similar to http://emby.media/community/index.php?/blog/1/entry-218-try-the-new-emby-linux-packages/ for the CentOS 6.x?
hurricanehrndz 149 Posted May 29, 2015 Posted May 29, 2015 Should we expect the changes similar to http://emby.media/community/index.php?/blog/1/entry-218-try-the-new-emby-linux-packages/ for the CentOS 6.x? I hope so, I'm trying to work with Jose to get similar stuff setup. CentOS 6.x seems to be more troublesome then CentOS 7.x
stangri 2 Posted May 30, 2015 Posted May 30, 2015 I hope so, I'm trying to work with Jose to get similar stuff setup. CentOS 6.x seems to be more troublesome then CentOS 7.x Uh oh. Is it because of the lack of systemd in 6.x? I've been reluctant to migrate to 7.x because from what I've read it's not going to be as simple as a major upgrade on Ubuntu (and when the 7.x was first released there was no ZFSoL support for 7.x which is crucial for me), but if the 6.x repo is going to be constantly behind it may be the last straw for me to either upgrade to 7.x or move to Ubuntu.
hurricanehrndz 149 Posted May 30, 2015 Posted May 30, 2015 I will try and look at it soon, it was more about satisfying some dependencies during build.
tadeucruz 0 Posted June 2, 2015 Posted June 2, 2015 Hi, where can i find the version 3.0.5621.4 for Centos? Thanks.
hurricanehrndz 149 Posted June 2, 2015 Posted June 2, 2015 I think Jose is working on getting the new packing done, please be patient as we are in transition due to the renaming. 1
jose 73 Posted June 8, 2015 Posted June 8, 2015 Please test new repo aslo if you want to use yoru own imagemagick and mono only do sudo yum install emby-server-core if you run CentOS -susbtitute Fedora with CentOS wget -q https://raw.githubusercontent.com/jose-pr/MediaBrowser.Build/master/RPM/SOURCES/Emby/root/etc/yum.repos.d/emby.repo -O /etc/yum.repos.d/emby.repo NAME=${NAME:=Fedora} sudo sed -i "s;{Dist};$NAME;g" /etc/yum.repos.d/emby.repo sudo yum install emby-server --enablerepo=Emby-Deps
s4mp3 0 Posted June 14, 2015 Posted June 14, 2015 In CentOS 7 the part where you enable MediaBrowserDependancies doesn't work like this: if not you can enable the MediaBrowserServer-Dependancies repo to supply the dependancies sudo yum-config-manager --enable MediaBrowserServer-Dependancies Becuase there doesn't seem to be yum-config-manager anymore. Instead you can have to use command: sudo yum install MediaBrowserServer --enbalerepo=MediaBrowserServer-Dependancies
steini 1 Posted June 18, 2015 Posted June 18, 2015 Please test new repo aslo if you want to use yoru own imagemagick and mono only do sudo yum install emby-server-core if you run CentOS -susbtitute Fedora with CentOS wget -q https://raw.githubusercontent.com/jose-pr/MediaBrowser.Build/master/RPM/SOURCES/Emby/root/etc/yum.repos.d/emby.repo -O /etc/yum.repos.d/emby.repo NAME=${NAME:=Fedora} sudo sed -i "s;{Dist};$NAME;g" /etc/yum.repos.d/emby.repo sudo yum install emby-server --enablerepo=Emby-Deps I´m running centos 7 version 3.0.5607.2 I ran the update - moved data dir from /var/opt/MediaBrowser/MediaBrowserServer to /var/opt/Emby/server and restarted the service Emby came up but the library is missing. A scan does not work at all and I cant add to the library, even though emby has access to the folders and I can see them when browsing for content. The only error is see is "ImageMagick: Error loading webp:" but the whole log can be seen here: http://pastebin.com/raw.php?i=r0MKNCgA Hope you can see something I cant
hurricanehrndz 149 Posted June 19, 2015 Posted June 19, 2015 I´m running centos 7 version 3.0.5607.2 I ran the update - moved data dir from /var/opt/MediaBrowser/MediaBrowserServer to /var/opt/Emby/server and restarted the service Emby came up but the library is missing. A scan does not work at all and I cant add to the library, even though emby has access to the folders and I can see them when browsing for content. The only error is see is "ImageMagick: Error loading webp:" but the whole log can be seen here: http://pastebin.com/raw.php?i=r0MKNCgA Hope you can see something I cant I'm sorry to inform you, but the data dir can't be moved.
steini 1 Posted June 19, 2015 Posted June 19, 2015 (edited) So complete rebuild with users watch statuses. Passwords etc? ... Or I have to try to change the data dir in the config Edited June 19, 2015 by steini
stangri 2 Posted June 19, 2015 Posted June 19, 2015 (edited) Please test new repo aslo if you want to use yoru own imagemagick and mono only do sudo yum install emby-server-core if you run CentOS -susbtitute Fedora with CentOS wget -q https://raw.githubusercontent.com/jose-pr/MediaBrowser.Build/master/RPM/SOURCES/Emby/root/etc/yum.repos.d/emby.repo -O /etc/yum.repos.d/emby.repo NAME=${NAME:=Fedora} sudo sed -i "s;{Dist};$NAME;g" /etc/yum.repos.d/emby.repo sudo yum install emby-server --enablerepo=Emby-Deps It wrecked my install on CentOS 6.6: Installed: emby-server.noarch 0:3.0.5621.4-Stable.7.1 Dependency Installed: ImageMagick-opt.x86_64 0:6.9.0-10.1 emby-server-core.noarch 0:3.0.5621.4-Stable.7.1 Replaced: MediaBrowserServer.noarch 0:3.0.5607.2-Stable.67.1 But then: [root@[member="nas"] /]# /etc/init.d/emby start /etc/init.d/emby: line 19: /root/.Emby/server.conf: No such file or directory Don't know what to do at this point. Edited June 19, 2015 by stangri
stangri 2 Posted June 19, 2015 Posted June 19, 2015 (edited) I've commented out: #. ~/.Emby/server.conf in the startup script, and now I have this: [root@[member="nas"] /]# service emby start /etc/init.d/emby: line 30: [: {:=/opt/Emby/server}/Emby.sh: binary operator expected Now I'm really out of my depth. BTW, /etc/opt/Emby/server.conf is empty now. Should I run another script to set things up or something? Edited June 19, 2015 by stangri
