knight09 3 Posted July 19, 2019 Share Posted July 19, 2019 (edited) I recently took the plunge with a lifetime Emby primer license. Mainly to gain live tv support for my Hauppauge tv tuner (HVR950Q). When I select "detect my devices" it is not found even though it is listed as a valid device on my windows 8.1 OS. There is no option to enter the device information manually as directed by the UI. Thanks, David Log.txt Edited July 19, 2019 by knightboy09 Link to comment Share on other sites More sharing options...
PenkethBoy 2063 Posted July 19, 2019 Share Posted July 19, 2019 have you installed wintv 8.5??? 1 Link to comment Share on other sites More sharing options...
knight09 3 Posted July 19, 2019 Author Share Posted July 19, 2019 (edited) Oh no I have not. I vaguely recall that now from the beta! Thanks, I'll give that a shot. Edited July 19, 2019 by knightboy09 Link to comment Share on other sites More sharing options...
PenkethBoy 2063 Posted July 19, 2019 Share Posted July 19, 2019 its been a long time since i installed my tuners - but if they show up in the settings dialog of wintv then emby will see them if they are on the same machine as emby Link to comment Share on other sites More sharing options...
knight09 3 Posted July 19, 2019 Author Share Posted July 19, 2019 (edited) So I found my WinTV v7 disk but installing it and the drivers doesn't appear to have solved my problem. Is 8.5 the minimum requirements? 8.0 is the latest version that supports my tuner and I would need to purchase a key to upgrade to it. Edited July 19, 2019 by knightboy09 Link to comment Share on other sites More sharing options...
Solution knight09 3 Posted July 19, 2019 Author Solution Share Posted July 19, 2019 (edited) Thanks for the assist, I'm up and running now! I needed to install WinTV v8.0 before Emby would detect my Hauppauge tv tuner (HVR950Q). @@Luke it might be helpful to disclose this in the UI when adding a tuner. Edited July 19, 2019 by knight09 Link to comment Share on other sites More sharing options...
Luke 36997 Posted July 19, 2019 Share Posted July 19, 2019 Thanks for the feedback ! Link to comment Share on other sites More sharing options...
