schmitty 61 Posted November 24, 2018 Share Posted November 24, 2018 Hi, This is a part of the combined request https://emby.media/community/index.php?/topic/65020-live-tv-enhancements/, I decided to group these particular ones together as they tie in with each other. tv (0/1) - enable/disable tv (must specify either radio or audio-only options if set to 0) radio (true) - enable radio-specific stream with rich metadata (only use if tv=0, can not be used with audio-only) audio-only (true) - enable audio only stream without rich metadata (only use if tv=0, can not be used with radio) 1 Link to comment Share on other sites More sharing options...
