icedragonslair
Audio Placement Mask Issues
icedragonslair
I am wondering if this will have any issues the audio in a theater surround system using kodi v18? It seems to be a little heavy on the audio on the right side or is it just me. These are the comparison of the two files (original vs converted) MediInfo entries, should I be concerned?
original mkv from my blu-ray via make mkv
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
converted file
Channel positions                        : Front: L C R, Side: C, Back: L R
Full audio reports from mediainfo here:
my original converted x264 Source:
Audio
Format                                   : E-AC-3
Format/Info                              : Enhanced Audio Coding 3
Codec ID                                 : A_EAC3
Duration                                 : 42 min 20 s
Bit rate mode                            : Constant
Bit rate                                 : 640 kb/s
Sampling rate                            : 48.0 kHz
Frame rate                               : 187.500 FPS (256 SPF)
Compression mode                         : Lossy
Stream size                              : 194 MiB (8%)
Language                                 : English
Service kind                             : Complete Main
Default                                  : Yes
Forced                                   : No
my newly converted hevc source:
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : A_AAC-2
Frame rate                               : 46.875 FPS (1024 SPF)
Writing library                          : Lavc58.18.100 aac
Language                                 : English
Default                                  : Yes
Forced                                   : No
Statistics Tags Issue                    : mkvmerge v23.0.0 ('The Bride Said No') 64-bit 2018-07-04 03:51:43 / Lavf58.12.100
FromStats_BitRate                        : 640000
FromStats_Duration                       : 00:42:20.597000000
FromStats_FrameCount                     : 79393
I am not sure if this is the correct place to post this, please feel free to move if needed.
Thanks again for all,
Ice
Edited by icedragonslair
Share this post
Link to post
Share on other sites
