Can't login after upgrade
coudy
 Share
Hi,
after upgrade from mediabrowser to emby (3.0.5621.4), I can't login. In mediabrowser I had user name mediabrowser without password. Now in emby I can't log in. I have tried emby,mediabrowser,admin, with password, without password.
How to manually add admin account ?
Link to comment
Share on other sites
Hi,
I can't. Emby crashed and I can't start it again:
root@nas:/var/lib/mediabrowser/logs# cat server-63570424882.txt
2015-06-20 19:21:22.5602 Info - Main: Emby
	Command line: /opt/emby-server/MediaBrowser.Server.Mono.exe -programdata /var/lib/mediabrowser -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe
	Operating system: Unix 4.1.0.3
	Processor count: 2
	64-Bit OS: True
	64-Bit Process: True
	Program data path: /var/lib/mediabrowser
	Mono: 4.0.1 (tarball Tue Jun  2 13:06:11 UTC 2015)
	Application Path: /opt/emby-server/MediaBrowser.Server.Mono.exe
2015-06-20 19:21:22.7006 Info - App: Application version: 3.0.5621.4
2015-06-20 19:21:22.7555 Info - App: Application configuration:
	{"EnableUPnP":true,"PublicPort":8096,"PublicHttpsPort":8920,"HttpServerPortNumber":8096,"HttpsPortNumber":8920,"EnableHttps":false,"EnableUserSpecificUserViews":true,"CertificatePath":"","EnableInternetProviders":true,"IsPortAuthorized":true,"ItemsByNamePath":"","MetadataPath":"","SeasonZeroDisplayName":"Specials","SaveLocalMeta":true,"EnableLocalizedGuids":true,"EnableLibraryMetadataSubFolder":true,"PreferredMetadataLanguage":"cs","MetadataCountryCode":"SK","SortReplaceCharacters":[".","+","%"],"SortRemoveCharacters":[",","&","-","{","}","'"],"SortRemoveWords":["the","a","an"],"MinResumePct":5,"MaxResumePct":90,"MinResumeDurationSeconds":300,"RealtimeLibraryMonitorDelay":40,"EnableDashboardResponseCaching":false,"EnableDashboardResourceMinification":false,"DashboardSourcePath":"","MergeMetadataAndImagesByName":true,"EnableStandaloneMetadata":true,"ImageSavingConvention":"Compatible","MetadataOptions":[{"ItemType":"Book","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Movie","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Disc","Limit":0,"MinWidth":0},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Series","ImageOptions":[{"Type":"Backdrop","Limit":2,"MinWidth":1280},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicAlbum","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Disc","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicArtist","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Banner","Limit":0,"MinWidth":0},{"Type":"Art","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Season","ImageOptions":[{"Type":"Backdrop","Limit":0,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Episode","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicVideo","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Video","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]}],"EnableAutomaticRestart":true,"EnableRealtimeMonitor":false,"PathSubstitutions":[],"ServerName":"Emby","WanDdns":"pc.chovan.net","UICulture":"en-GB","PeopleMetadataOptions":{"DownloadActorMetadata":true,"DownloadDirectorMetadata":true,"DownloadProducerMetadata":false,"DownloadWriterMetadata":false,"DownloadComposerMetadata":false,"DownloadOtherPeopleMetadata":false,"DownloadGuestStarMetadata":false},"FindInternetTrailers":true,"InsecureApps9":["Chromecast","iOS","Unknown app","MediaPortal","Media Portal","iPad","iPhone","Windows Phone"],"SaveMetadataHidden":false,"ContentTypes":[],"EnableAudioArchiveFiles":false,"EnableVideoArchiveFiles":false,"RemoteClientBitrateLimit":1750000,"EnableDebugLevelLogging":true,"EnableAutoUpdate":true,"SystemUpdateLevel":"Release","LogFileRetentionDays":3,"RunAtStartup":false,"IsStartupWizardCompleted":true,"CachePath":"","EnableCustomPathSubFolders":false}
2015-06-20 19:21:22.7660 Info - App: Loading MediaBrowser.Plugins.TuneIn, Version=1.0.5448.33319, Culture=neutral, PublicKeyToken=null
2015-06-20 19:21:22.7660 Info - App: Loading MediaBrowser.Plugins.Trailers, Version=1.0.5573.39176, Culture=neutral, PublicKeyToken=null
2015-06-20 19:21:22.7660 Info - App: Loading MediaBrowser.Api, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null
2015-06-20 19:21:22.7660 Info - App: Loading MediaBrowser.WebDashboard, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null
2015-06-20 19:21:22.7660 Info - App: Loading MediaBrowser.Model, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null
2015-06-20 19:21:22.7660 Info - App: Loading MediaBrowser.Common, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null
2015-06-20 19:21:22.7660 Info - App: Loading MediaBrowser.Controller, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null
2015-06-20 19:21:22.7660 Info - App: Loading MediaBrowser.Providers, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null
2015-06-20 19:21:22.7660 Info - App: Loading MediaBrowser.Common.Implementations, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null
2015-06-20 19:21:22.7660 Info - App: Loading MediaBrowser.Server.Implementations, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null
2015-06-20 19:21:22.7660 Info - App: Loading MediaBrowser.MediaEncoding, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null
2015-06-20 19:21:22.7660 Info - App: Loading MediaBrowser.Dlna, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null
2015-06-20 19:21:22.7660 Info - App: Loading MediaBrowser.LocalMetadata, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null
2015-06-20 19:21:22.7660 Info - App: Loading MediaBrowser.XbmcMetadata, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null
2015-06-20 19:21:22.7660 Info - App: Loading MediaBrowser.IsoMounting.Linux, Version=1.0.5131.24779, Culture=neutral, PublicKeyToken=null
2015-06-20 19:21:22.7660 Info - App: Loading MediaBrowser.Server.Mono, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null
2015-06-20 19:21:22.7660 Info - App: Loading MediaBrowser.Server.Startup.Common, Version=3.0.5621.4, Culture=neutral, PublicKeyToken=null
2015-06-20 19:21:22.8635 Info - SqliteUserRepository: Sqlite 3.8.7.1 opening /var/lib/mediabrowser/data/users.db
2015-06-20 19:21:22.9074 Info - SqliteItemRepository: Sqlite 3.8.7.1 opening /var/lib/mediabrowser/data/chapters.db
2015-06-20 19:21:22.9113 Info - SqliteItemRepository: Sqlite 3.8.7.1 opening /var/lib/mediabrowser/data/mediainfo.db
2015-06-20 19:21:22.9185 Info - SqliteFileOrganizationRepository: Sqlite 3.8.7.1 opening /var/lib/mediabrowser/data/fileorganization.db
2015-06-20 19:21:22.9241 Info - AuthenticationRepository: Sqlite 3.8.7.1 opening /var/lib/mediabrowser/data/authentication.db
2015-06-20 19:21:22.9341 Info - SyncRepository: Sqlite 3.8.7.1 opening /var/lib/mediabrowser/data/sync14.db
2015-06-20 19:21:22.9731 Info - ImageMagick: ImageMagick version: ImageMagick 6.9.1-2 Q8 x86_64 2015-06-02 http://www.imagemagick.org
2015-06-20 19:21:22.9800 Info - ImageProcessor: ImageProcessor started with 4 max concurrent image processes
2015-06-20 19:21:22.9941 Error - Connect: Error loading data
	*** Error Report ***
	Version: 3.0.5621.4
	Processor count: 2
	64-Bit OS: True
	Type definitions should start with a '{', expecting serialized type 'ConnectData', got string starting with: "{\"ServerId\":"ee2a7b5aff3f8aeed1ff09d29ddcfb98",
	System.Runtime.Serialization.SerializationException
	  at ServiceStack.Text.Common.DeserializeTypeRefJson.StringToType (ServiceStack.Text.TypeConfig typeConfig, System.String strType, ServiceStack.EmptyCtorDelegate ctorFn, System.Collections.Generic.Dictionary`2 typeAccessorMap) [0x00000] in <filename unknown>:0
	  at ServiceStack.Text.Common.DeserializeType`1+<>c__DisplayClass3[ServiceStack.Text.Json.JsonTypeSerializer].<GetParseMethod>b__1 (System.String value) [0x00000] in <filename unknown>:0
	  at ServiceStack.Text.Json.JsonReader`1[MediaBrowser.Server.Implementations.Connect.ConnectData].Parse (System.String value) [0x00000] in <filename unknown>:0
	  at ServiceStack.Text.JsonSerializer.DeserializeFromString[ConnectData] (System.String value) [0x00000] in <filename unknown>:0
	  at MediaBrowser.Common.Implementations.Serialization.JsonSerializer.DeserializeFromString[ConnectData] (System.String text) [0x00000] in <filename unknown>:0
	  at MediaBrowser.Server.Implementations.Connect.ConnectManager.LoadCachedData () [0x00000] in <filename unknown>:0
2015-06-20 19:21:23.0154 Info - App: FFMpeg: /usr/bin/ffmpeg
2015-06-20 19:21:23.0154 Info - App: FFProbe: /usr/bin/ffprobe
2015-06-20 19:21:23.0245 Info - ActivityRepository: Sqlite 3.8.7.1 opening /var/lib/mediabrowser/data/activitylog.db
2015-06-20 19:21:23.0314 Info - SqliteDisplayPreferencesRepository: Sqlite 3.8.7.1 opening /var/lib/mediabrowser/data/displaypreferences.db
2015-06-20 19:21:23.0349 Info - SqliteItemRepository: Sqlite 3.8.7.1 opening /var/lib/mediabrowser/data/library.db
2015-06-20 19:21:23.0401 Info - SqliteProviderInfoRepository: Sqlite 3.8.7.1 opening /var/lib/mediabrowser/data/refreshinfo.db
2015-06-20 19:21:23.0454 Info - SqliteUserDataRepository: Sqlite 3.8.7.1 opening /var/lib/mediabrowser/data/userdata_v2.db
2015-06-20 19:21:23.0502 Info - SqliteNotificationsRepository: Sqlite 3.8.7.1 opening /var/lib/mediabrowser/data/notifications.db
2015-06-20 19:21:23.0790 Error - Main: UnhandledException
	Version: 3.0.5621.4
	Processor count: 2
	64-Bit OS: True
	One or more errors occurred.
	System.AggregateException
	  at System.Threading.Tasks.Task.WaitAll (System.Threading.Tasks.Task[] tasks, Int32 millisecondsTimeout, CancellationToken cancellationToken) [0x00000] in <filename unknown>:0
	  at System.Threading.Tasks.Task.WaitAll (System.Threading.Tasks.Task[] tasks, Int32 millisecondsTimeout) [0x00000] in <filename unknown>:0
	  at System.Threading.Tasks.Task.WaitAll (System.Threading.Tasks.Task[] tasks) [0x00000] in <filename unknown>:0
	  at MediaBrowser.Server.Mono.MainClass.RunApplication (MediaBrowser.Server.Implementations.ServerApplicationPaths appPaths, ILogManager logManager, MediaBrowser.Server.Startup.Common.StartupOptions options) [0x00000] in <filename unknown>:0
	  at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) [0x00000] in <filename unknown>:0
	InnerException: System.Runtime.Serialization.SerializationException
	Type definitions should start with a '{', expecting serialized type 'User', got string starting with: "{\"UsesIdForConfigurationPath\":true,\"LastLoginD
	  at ServiceStack.Text.Json.JsonReader`1[MediaBrowser.Controller.Entities.User].Parse (System.String value) [0x00000] in <filename unknown>:0
	  at ServiceStack.Text.JsonSerializer.DeserializeFromString[User] (System.String value) [0x00000] in <filename unknown>:0
	  at ServiceStack.Text.JsonSerializer.DeserializeFromStream[User] (System.IO.Stream stream) [0x00000] in <filename unknown>:0
	  at MediaBrowser.Common.Implementations.Serialization.JsonSerializer.DeserializeFromStream[User] (System.IO.Stream stream) [0x00000] in <filename unknown>:0
	  at MediaBrowser.Server.Implementations.Persistence.SqliteUserRepository+<RetrieveAllUsers>c__Iterator2.MoveNext () [0x00000] in <filename unknown>:0
	  at System.Collections.Generic.List`1[MediaBrowser.Controller.Entities.User]..ctor (IEnumerable`1 collection) [0x00000] in <filename unknown>:0
	  at System.Linq.Enumerable.ToList[User] (IEnumerable`1 source) [0x00000] in <filename unknown>:0
	  at MediaBrowser.Server.Implementations.Library.UserManager+<LoadUsers>c__async3.MoveNext () [0x00000] in <filename unknown>:0
	--- End of stack trace from previous location where exception was thrown ---
	  at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0
	  at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0
	  at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0
	  at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00000] in <filename unknown>:0
	  at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[System.Collections.Generic.IEnumerable`1[MediaBrowser.Controller.Entities.User]].GetResult () [0x00000] in <filename unknown>:0
	  at MediaBrowser.Server.Implementations.Library.UserManager+<Initialize>c__async0.MoveNext () [0x00000] in <filename unknown>:0
	  at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <filename unknown>:0
	  at MediaBrowser.Server.Startup.Common.ApplicationHost+<RegisterResources>c__async2.MoveNext () [0x00000] in <filename unknown>:0
	  at MediaBrowser.Common.Implementations.BaseApplicationHost`1+<Init>c__async0[MediaBrowser.Server.Implementations.ServerApplicationPaths].MoveNext () [0x00000] in <filename unknown>:0
	  at MediaBrowser.Server.Startup.Common.ApplicationHost+<Init>c__async1.MoveNext () [0x00000] in <filename unknown>:0
Link to comment
 Share
