Emby Blog
  • entries
    572
  • comments
    4982
  • views
    3502206
Contributors to this blog
  • Luke 355
  • ebr 70
  • Carlo 31
  • sross44 18
  • 7illusions 15
  • ScottIsAFool 12
  • Abobader 11
  • radeon 8
  • xnappo 8
  • darwindeeds 7
  • Redshirt 6
  • Cheesegeezer 5
  • leedavies 3
  • Aphid 3
  • bigjohn 3
  • snazy2000 3
  • softworkz 3
  • techywarrior 3
  • Soultaker 2
  • chef 2
  • gcw07 2
  • marcelveldt 1
  • hurricanehrndz 1
Switch Users from inside MBC
New, much easier way to switch user profiles in MB Classic
Starting with version 3.0.100.0 it will be much easier to manage a mult-user profile setup with MBC. As each theme gets it implemented, you should have an easy button somewhere on the interface to allow you to select a different user profile than the one you are currently within.
The below images show where this button is in chocolate and the default theme. Subdued also implements this new feature. If you don't use one of those themes, ask your theme dev to get this into your favorite theme as soon as they can.
This will make it much easier to manage multiple users and parental control settings. You can configure each MBC installation to automatically log on to the profile you use most often and then easily switch between it and other profiles as you wish. The next start of MBC will then go into your default profile again.
  • Like 6
2 Comments
Recommended Comments
TheWorkz
Awesome!!! You are seriously the best man! I like this a lot better than your first response to me. :) Lol
Dan64
Now it's better ! Now I can also set MB3C to autologin to the default user and still be able to switch user If I need (before was impossible).
To reach the perfection should be implemented also these features:
1) Remove the initial spash-screen when switch user (nice to have)
2) After the switch try to restore the same browser collection that was selected at the moment of the switching (more than nice to have)
Thanks
