Emby Emby Emby Learn
  • Emby Home
  • Video
  • Audio
  • Media Files
    • Subtitles and captions
    • Photos and images
    • Metadata and discovery
    • Playback and streaming
    • Media hardware acceleration
    • Displays and AV connections
    • Live TV and recording
  1. Emby Learn
  2. Displays and AV connections
  3. Display characteristics
  4. Display technologies
  5. OLED displays
Search Results for
    Show / Hide Table of Contents
    OLED displays
    An OLED display produces light through independently driven organic emissive elements, with picture behaviour determined by its pixel arrangement, drive and brightness controls.
    An OLED display generates light in its organic emissive elements instead of passing a shared backlight through a liquid-crystal panel. Its pixel drive controls the local light output.
    A dark pixel can consequently stop emitting while a neighbouring pixel remains bright. That changes the local-contrast problem encountered with a shared LCD backlight zone.
    Emission is local; the complete panel has shared limits
    Property Meaning for the picture
    Local emission control A small bright object does not require a surrounding backlight zone to brighten
    Subpixel/color arrangement The panel’s specific arrangement forms the displayed colors
    Whole-screen electrical loading Many bright elements require more combined drive than a small highlight
    Pixel response The light output can change rapidly, while presentation timing remains another constraint
    Different OLED arrangements produce their color channels differently. “OLED” does not specify every subpixel pattern, spectral property or screen-surface treatment.
    Likewise, a pixel that emits no light does not remove room light reflected by the screen. The apparent black level in a bright room includes that reflected contribution.
    A highlight and a white screen are different workloads
    A small highlight can use high local drive while much of the panel remains dark. A largely white picture drives many more elements at once.
    The display can reduce permitted drive under that larger load. Dell documents picture-pattern-dependent luminance on specified OLED laptop panels. The general relationship is developed in automatic brightness limiting; the exact curve belongs to the product and its mode.
    For an Emby movie, a bright snow scene can therefore have different sustained brightness from a small bright lamp in an otherwise dark scene. This is a panel-output relationship, not evidence that the player has changed the encoded video bitrate.
    Brightness should be described with its picture area and duration. A peak figure from a small patch cannot be applied unchanged to an entire screen.
    A fast pixel still displays timed movie pictures
    Fast response reduces the time a transition spends between its old and new level. It does not add source pictures.
    A 24-fps film still contains a new source picture roughly every 41.7 milliseconds. Repeating each picture evenly on a high-refresh display preserves that sampling. An uneven repeat pattern can still cause judder.
    Holding a picture’s light while the eye tracks a moving object can also produce persistence blur, even if the initial pixel transition is very fast. Black-frame insertion explains one way a display can shorten the illuminated interval.
    See Also
    • LCD and LED-backlit displays
    • Automatic brightness limiting
    • Display response time and motion blur
    • Black-frame insertion and display persistence
    References
    • LG: OLED emission and LCD backlighting
    • Dell: OLED luminance and display-pattern loading
    • VESA: DisplayHDR performance criteria
    On this Page
    Back to Top
