pgalbavy 6 Posted February 22, 2019 Posted February 22, 2019 (edited) Something like what is described in this thread started for me last night. I rebooted by Shield TV just to be sure. What happened, watch different types of content (SD, HD, recorded and ripped) is that playback froze after 5-15 minutes. I have to stop and resume and play/pause did nothing. I actually dropped back to Plex to finish watching stuff. All content on local server. Server: 4.1.0.8 Beta App: 1.6.88g Logs for yesterday attached. Activity from 17:42 or so: 2019-02-21 17:42:46.430 Info HttpServer: HTTP GET http://192.168.234.16:8096/emby/system/info/public?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 8.0.0; SHIELD Android TV Build/OPR6.170623.010) ... embyserver-63686390400.zip Edited February 22, 2019 by pgalbavy
KaptainKrypton 2 Posted February 25, 2019 Posted February 25, 2019 (edited) My most current update from NVIDIA tech support: Hello Kasey,Thanks for the information.Both issues are under active engineering investigation. Thanks for your patience.Best Regards,TroyNVIDIA Customer Care L2-------------------------------------------------------------------------------------------------------NVIDIA Software Downloads - www.nvidia.com/Download/index.aspx?lang=en-usNVIDIA Knowledge Base - nvidia.custhelp.com/cgi-bin/nvidia.cfg/php/enduser/std_alp.php/track/AvOBzwqLDv8S~QJbGrIe~yJj_9UqyS75Mv8t~zj~PP~kNVIDIA Hardware Support - http://www.nvidia.com/object/hardware_support.html Customer By CSS Web (Kasey Olson) (02/23/2019 08:24 AM) https://emby.media/community/index.php?/topic/66681-nvidia-shield-tv-playback-will-pause-constantly/page-12Up to the 12th page and it's been repeatedly confirmed that rolling Nvidia Shield system back to 7.1 fixes the issue. Any update on repairs that will allow stutter-free playback?In addition, one of the things I noticed is that DTS-HD Master Audio tracks at or above 96kz that play in this instance will generally coincide with the playback stuttering. Something involved in the audio drivers, maybe? Customer By CSS Email (Kasey Olson) (01/15/2019 04:44 PM) Edited February 25, 2019 by KaptainKrypton 1
rickn345 1 Posted March 6, 2019 Posted March 6, 2019 The Plex forum is also lite up with the same problem (search Nvidia Shield Playback Issues). The conclusion is the same, Nvidia's update is the source of the problem.
fizzyade 132 Posted March 12, 2019 Posted March 12, 2019 7.2.3 is out, I wonder if this contains a fix for it? (not updating until I hear that the bug is positively fixed)
CBers 7554 Posted March 12, 2019 Posted March 12, 2019 https://forums.geforce.com/default/topic/1102308/shield-tv/shield-experience-upgrade-7-2-3/
Jdiesel 1439 Posted March 12, 2019 Posted March 12, 2019 This could be it • Streaming from high latency network services has lower bandwidth than expected. Unfixed unfortunately...
Pog22 52 Posted March 12, 2019 Posted March 12, 2019 Ah damn I was hoping this was it, I saw a blog post about the update but haven't been offered it yet
puithove 209 Posted March 13, 2019 Posted March 13, 2019 (edited) Yea, upgraded my Sheild to 7.2.3 today, still seeing these random freezes during playback. Edited March 13, 2019 by puithove
Sammy 791 Posted March 13, 2019 Posted March 13, 2019 So is thiwhy some of my HEVC files will not play smoothly? I thought it might be a bad encode or my 1080p Plasma but even a run through Handbrake didn't fix the one I tried correcting. I ended up nuking and replacing the file with a Blu-ray 1080p since this TV isn't 4K HDR anyway so I cannot test it but other HEVC files work. Next time this happens I'll pay closer attention and post logs etc. Sent from my SM-G960U1 using Tapatalk
sephx 5 Posted March 15, 2019 Posted March 15, 2019 if you happen to run server on linux, enabling tcp bbr can help alleviate 'some' of these problems. but yes, anything after 7.1.0 is broken and very much hit/miss for streaming above 10-12mbit. tcp bbr - https://www.linuxbabe.com/ubuntu/enable-google-tcp-bbr-ubuntu
Pog22 52 Posted March 15, 2019 Posted March 15, 2019 if you happen to run server on linux, enabling tcp bbr can help alleviate 'some' of these problems. but yes, anything after 7.1.0 is broken and very much hit/miss for streaming above 10-12mbit. tcp bbr - https://www.linuxbabe.com/ubuntu/enable-google-tcp-bbr-ubuntu I have had BBR enabled for months and still have the issue
nebster 3 Posted March 15, 2019 Posted March 15, 2019 @@ebr Do you have any idea why this only happens for direct play and not for transcoding? I've had emby transcode from 5.6Mbps (stopping every 5 secs) to roughly the same bitrate (no stops at all). It seems a bit weird that this is a network stack issue given that. A workaround (not sure how easy this is but hopefully copy paste from the android mobile app) is to add syncing to android tv so that we can cache the whole file on the tv before watching.
ebr 16338 Posted March 16, 2019 Posted March 16, 2019 When we transcode, we use a protocol specifically designed for streaming media. When we direct-stream, we just send data over raw http. So the method of delivery and how it would be handled by the network side is really very different.
jonboyuk 12 Posted March 18, 2019 Posted March 18, 2019 It's a shame really because the Android TV app is fantastic. I have to use the Samsung one on my TV instead. That actually works better in so many ways, with HDR working every time and it never pauses either.
Riggs 312 Posted March 22, 2019 Posted March 22, 2019 (edited) Hello. I wrote this slowly and very carefully, I hope it is understood well. Since I installed Emby in Fedora 29, the server's Web interface seems to be working fine as usual. However, any movie that I see on my Nvidia Shield, at the least expected moment stops. You try to play again (thinking that you mistakenly paused the movie by accident, but nothing happens). Then I must return to the main screen, and I choose to resume, and continue, but for a few minutes, until the same thing happens again. The day before yesterday, I discovered that the default paths for the cache on the server, if they are not defined, they fill the / root of .temp files and saturates the space in the / root. This topic of path and space I solved yesterday defining the paths and deleting all the temporary files within the / root. I thought that was the problem, but apparently even if it was a problem, it was not the cause of the reproduction interruption.So, I turned off the server, and deleted all the temporary files in / root (which by the way were several gigs).With all this corrected and revised, I started the server again. I checked that the paths were correct and working.I thought that was the problem for which when playing a movie on my Nvidia Shield, it stopped as if by magic.However, last night, the same thing happened. The film (whatever it is) stops after a while of watching it (more or less at 50min- 1 hour).Today I checked the log on the server, which matches the time and I can see several errors there, however, I do not know what they refer to.I do not know if it is a configuration problem of my Fedora installation or if it is a bug.Honestly, and in appearance, everything is perfect in the functioning of the server, I do not find anything unusual. The problem is when it comes to playing from the Nvidia Shield. It seems that the socket closes or something like that.I thank you in advance to review the log and help me with this.Thank you embyserver-6368809600.txt Edited March 22, 2019 by HRSCR
Riggs 312 Posted March 22, 2019 Posted March 22, 2019 BTW. I check for updates all days for my system This is the log today, a new ffmpeg was installed Total 2.0 MB/s | 8.8 MB 00:04 Delta RPMs reduced 9.0 MB of updates to 8.8 MB (2.1% saved)Running transaction checkTransaction check succeeded.Running transaction testTransaction test succeeded.Running transaction Preparing : 1/1 Upgrading : gstreamer1-plugins-good-1.14.4-2.fc29.x86_64 1/11 Installing : gstreamer1-plugins-good-qt-1.14.4-2.fc29.x86_64 2/11 Upgrading : gstreamer1-plugins-good-gtk-1.14.4-2.fc29.x86_64 3/11 Upgrading : ffmpeg-libs-4.0.3-4.fc29.x86_64 4/11 Upgrading : zchunk-libs-1.0.4-1.fc29.x86_64 5/11 Upgrading : gnome-characters-3.30.0-2.fc29.x86_64 6/11 Cleanup : gstreamer1-plugins-good-gtk-1.14.4-1.fc29.x86_64 7/11 Cleanup : gstreamer1-plugins-good-1.14.4-1.fc29.x86_64 8/11 Cleanup : ffmpeg-libs-4.0.3-3.fc29.x86_64 9/11 Cleanup : zchunk-libs-1.0.3-1.fc29.x86_64 10/11 Cleanup : gnome-characters-3.30.0-1.fc29.x86_64 11/11 Running scriptlet: gnome-characters-3.30.0-1.fc29.x86_64 11/11 Verifying : gstreamer1-plugins-good-qt-1.14.4-2.fc29.x86_64 1/11 Verifying : gnome-characters-3.30.0-2.fc29.x86_64 2/11 Verifying : gnome-characters-3.30.0-1.fc29.x86_64 3/11 Verifying : gstreamer1-plugins-good-1.14.4-2.fc29.x86_64 4/11 Verifying : gstreamer1-plugins-good-1.14.4-1.fc29.x86_64 5/11 Verifying : gstreamer1-plugins-good-gtk-1.14.4-2.fc29.x86_64 6/11 Verifying : gstreamer1-plugins-good-gtk-1.14.4-1.fc29.x86_64 7/11 Verifying : zchunk-libs-1.0.4-1.fc29.x86_64 8/11 Verifying : zchunk-libs-1.0.3-1.fc29.x86_64 9/11 Verifying : ffmpeg-libs-4.0.3-4.fc29.x86_64 10/11 Verifying : ffmpeg-libs-4.0.3-3.fc29.x86_64 11/11Upgraded: gnome-characters-3.30.0-2.fc29.x86_64 gstreamer1-plugins-good-1.14.4-2.fc29.x86_64 gstreamer1-plugins-good-gtk-1.14.4-2.fc29.x86_64 zchunk-libs-1.0.4-1.fc29.x86_64 ffmpeg-libs-4.0.3-4.fc29.x86_64 Installed: gstreamer1-plugins-good-qt-1.14.4-2.fc29.x86_64 Complete!
Q-Droid 1011 Posted March 22, 2019 Posted March 22, 2019 (edited) I have the same problem. It might not be your server or configuration. Do you have any other playback devices or do you have the same problem in a browser? The issue is random, sometimes it freezes multiple times and others not at all. There are a some discussions around playback freezing on Nvidia Shield, one is below. https://emby.media/community/index.php?/topic/66681-nvidia-shield-tv-playback-will-pause-constantly/ Edited March 22, 2019 by Q-Droid 1
Riggs 312 Posted March 22, 2019 Posted March 22, 2019 I have the same problem. It might not be your server or configuration. Do you have any other playback devices or do you have the same problem in a browser? The issue is random, sometimes it freezes multiple times and others not at all. There are a some discussions around playback freezing on Nvidia Shield, one is below. https://emby.media/community/index.php?/topic/66681-nvidia-shield-tv-playback-will-pause-constantly/ Oh men, thank you very much! I never watch movies in the browser, so i can't tell you. I just using the Nvidia Shield at this moment. Maybe in the weekend i can test my Roku Ultra. The issue is that, in my case, it matches the date I put the server in Fedora and deleted the Windows server. That's why I opened this topic, thinking that it was the server. Thanks again!
Q-Droid 1011 Posted March 22, 2019 Posted March 22, 2019 I'm in the same boat. It could very well be something about the server or any part of the chain. In my case I had just completed a motherboard and CPU swap and kernel upgrade when I started to notice the issue. The same OS before and after, CentOS. But there are enough people with the problem that I'm keeping my eyes on it to see if they identify something. On top of that I had completed the Emby upgrade to 4.0.2 like a week or two before then. Too much has changed for me and there's no going back now.
ebr 16338 Posted March 23, 2019 Posted March 23, 2019 i send logs "HRS" since two days ago. Hi. Logs of what? The issue this thread is about is a known problem in the recent Nvidia firmware.
Luke 42246 Posted March 23, 2019 Posted March 23, 2019 And an ffmpeg log? Please also submit an in-app log from the Nvidia Shield app and @@ebr will review. Thanks. 1
Riggs 312 Posted March 23, 2019 Posted March 23, 2019 (edited) Hi. Logs of what? The issue this thread is about is a known problem in the recent Nvidia firmware. @@ebr Well, I'm sorry, I also have the latest firmware. Let me tell you something, a few hours ago I ran the application on Nvidia Shield and the problem is still there. So, I do not intend to go back to Plex because this problem, then, I installed Kodi and Embycon and ... Guess what? I did not experience any problems of cuts, or problems of any kind, we just saw three movies and none presented problems. Nothing. In short, the Emby application is failing at some point (Houston, EmbyAPP have a problem), as simple as that. About your appointment "Logs of what?" Excuse me, with all respect. These kind of meaningless questions that you usually ask me and I do not know how to interpret them. Man, what records can I send to the developer from the Android TV application? Is there any other record that I can send? I do not understand why you always ask me that kind of questions. If you do not want the reports to be sent to you, simply remove the option from the APP and thus, no person will ever send you reports again. Sometimes I wonder why beta versions exist, and why every time I report something, if I am not from the "personal forum partners" group, you simply ignore me or ask me a pointless question to evade response. I've always thought that anything anyone posts here is to help each other, as a community. However lately, your personal treatment towards your consumers is not pleasant, or do you have something that you do not like about me or the people that you do not like? At least that's the impression I read in every forum I visit, many times I refrain from publishing something to prevent you or Luke from bullying me. We are not all experts in your product, I am not, and I apologize for that. Thank you. Edited March 23, 2019 by HRSCR
