DrJekle 4 Posted May 29, 2017 Posted May 29, 2017 Just started with the new update, live TV Audio will get out of sync. Only way to fix is stop playback and restart. I'm just heading out the door so can't attach log file. All settings are on default. 1
DrJekle 4 Posted May 31, 2017 Author Posted May 31, 2017 here are log files from last night where it occurred. it was so bad that my video was a full commercial ahead of the audio. ffmpeg-transcode-4d4c6312-fad7-4578-a5f9-b8de6e3dcb7c.txt ffmpeg-transcode-32edb439-23b1-4331-bd23-2a16a125bdc6.txt ffmpeg-transcode-c0e042d5-8d4d-41e6-86c0-e1a93f9b3754.txt server-63631612800.txt theater-63631773169.txt
Luke 42243 Posted May 31, 2017 Posted May 31, 2017 serverwmc has a dts option that you may want to consult with @@krustyreturns about setting to false.
krustyreturns 191 Posted June 1, 2017 Posted June 1, 2017 This workaround assumes your streams are h264 encoded. In serverwmc's setting file, search for GenerateDTS_h264 and set it to false, ex: <GenerateDTS_h264>false</GenerateDTS_h264> then save the file and restart serverwmc. you can read more about the workaround in this thread: https://emby.media/community/index.php?/topic/46592-live-tv-out-of-sync-video-running-double-time/ @@Luke has given me a way to make the above workaround unnecessary but I haven't had time to implement and test it yet. Sorry about that. Its definitely on my todo list.
Luke 42243 Posted June 1, 2017 Posted June 1, 2017 Ok, his streams are mpeg so it won't matter in this case.
PrincessClevage 175 Posted June 1, 2017 Posted June 1, 2017 Just started with the new update, live TV Audio will get out of sync. Only way to fix is stop playback and restart. I'm just heading out the door so can't attach log file. All settings are on default. add to this live tv crashing for some streams since the latest server update
Luke 42243 Posted June 1, 2017 Posted June 1, 2017 add to this live tv crashing for some streams since the latest server update We're very sorry to hear about this. In order for us to best help you, please make sure to provide the information requested in how to report a media playback issue. thanks !
DrJekle 4 Posted June 1, 2017 Author Posted June 1, 2017 Ok, his streams are mpeg so it won't matter in this case. Well wonder what my next step should be? Is it possible when the madVR option is available that it may fix this issue?
DrJekle 4 Posted June 1, 2017 Author Posted June 1, 2017 So far it hasn't acted up in the web player. By now in ET it would be completely out of sync
PrincessClevage 175 Posted June 2, 2017 Posted June 2, 2017 (edited) We're very sorry to hear about this. In order for us to best help you, please make sure to provide the information requested in how to report a media playback issue. thanks !Logs attached,I have enable interlace set to yes but interlace lines seem very bad in the latest stable version. Was running live tv fine in previous server versions and ET 2.7.8 Edit odd that it seems stable now and interlacing is also gone after I toned down some security software:-/ Thanks Luke Edited June 2, 2017 by PrincessClevage
DrJekle 4 Posted June 13, 2017 Author Posted June 13, 2017 I have just done a fresh install of ET 2.7.9 and this issue is still creeping up. I notice it on NBC and ABC. Is this something that madVR and reclock will fix once those are available again?
DrJekle 4 Posted June 14, 2017 Author Posted June 14, 2017 Playback works just fine in WMC without the audio getting out of sync.
Luke 42243 Posted June 17, 2017 Posted June 17, 2017 @@DrJekle, please try the test build here and let me know if it makes any difference: https://emby.media/community/index.php?/topic/46763-theater-mpv-test/ Thanks !
DrJekle 4 Posted June 17, 2017 Author Posted June 17, 2017 Thanks @@Luke, I will download and test when I am home tomorrow
DrJekle 4 Posted June 18, 2017 Author Posted June 18, 2017 So far I have been playing NBC for an hour straight and no audio delay observed. I have done this with default settings and other settings. Is madVR suppose to work with live TV? I know in the past it did but since this was a tester wasn't sure
DrJekle 4 Posted June 19, 2017 Author Posted June 19, 2017 It seems to be fine now I'll be keeping an eye on it
Luke 42243 Posted July 16, 2017 Posted July 16, 2017 The latest release of the app has audio delay settings that can help with audio being out of sync.
