acnp77 67 Posted April 7, 2023 Posted April 7, 2023 (edited) Please correct me if I am wrong, but the main purpose of the ET client is to play media/movies. As far as I have found, electron stands in the way here when it comes to supporting different architectures. It also presents a lot of overhead, which is not typical for a Linux app. What criteria have been considered when deciding to build ET on electron? Edited April 9, 2023 by acnp77
acnp77 67 Posted April 9, 2023 Posted April 9, 2023 Hi. I used the official 32-bit Raspberry Pi OS 2023-02-21 release and managed to get HW decoded playback in the emby web app in chromium browser on a rpi 400, 4gb. During extensive use of the in-movie emby-gui, I got a maximum of 3 frames dropped while playing a h.264 1080p 20 mbps movie, which I consider a good performance. But then, after 5 minutes the playback froze. But with the ET I can not find ANY combination of settings/images/packages to makie it work. If some one could tell me that the ET app is not yet capable of hw playback on rpi 4(00), at least I could give up for now, so I am looking for any clear statments here: Is is possible at the moment, has anyone managed to get hw playback on rpi4 and ET? I really want to make this work. BTW: ET .deb package on a Intel Xeon E3-1240 with NVIDIA Quadro K2200 is really great. CHEERS
0x086A 0 Posted June 4, 2023 Posted June 4, 2023 Should we be reporting issues with Emby Theater Linux to the Emby-Theater-Electron repo (https://github.com/MediaBrowser/emby-theater-electron) on Github? I recently upgraded to Debian (12.0) Bookworm and found that Emby Theater Linux has stopped working, even on a fresh install. The application will launch and I can connect to my emby server but if I try to play to play video/audio files, it either hangs forever or gives me a playback error. Using the web client through Chrome on these same hosts has worked out fine, it's just the Ember Theater client that doesn't seem to be working. I was hoping to troubleshoot myself I bit more, but was unable to find any log files related to Emby Theater, does it log information to a file? The hosts are all amd64/x86_64 running Mate desktop.
alucryd 318 Posted June 9, 2023 Posted June 9, 2023 @0x086AYes I believe that repo is the right place, but here is fine as well. I'll create a bookworm VM to see what's going on.
starisme 5 Posted June 20, 2023 Posted June 20, 2023 Probably a super edge case but I tried installing the emby theater flatpak to steamdeck and it works but Chinese characters render as just blank boxes. I have east asian fonts installed and if I access my Emby server through Firefox in the steamdeck the characters are fine. Not sure what the issue is.
alucryd 318 Posted June 21, 2023 Posted June 21, 2023 Hmm, sounds like a fontconfig issue, will need to check how electron handles east asian fonts.
screamor 0 Posted August 1, 2023 Posted August 1, 2023 (edited) Hi i am just setting up a Emby Theater on Debian. I got everything running, but there is no way the Emby-theater plays anything without ran in sudo. Error log without sudo /usr/bin/emby-theater: 10: ldconfig: not found readlink: fehlender Operand „readlink --help“ liefert weitere Informationen. /usr/bin/emby-theater: 10: [: -gt: unexpected operator libGL error: MESA-LOADER: failed to open iris: /opt/emby-theater/extra/lib/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/dri/iris_dri.so) (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: iris libGL error: MESA-LOADER: failed to open iris: /opt/emby-theater/extra/lib/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/dri/iris_dri.so) (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: iris libGL error: MESA-LOADER: failed to open swrast: /opt/emby-theater/extra/lib/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/dri/swrast_dri.so) (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: swrast Initializing cec-client... { cecExePath: 'cec-client', cecEmitter: EventEmitter { _events: [Object: null prototype] {}, _eventsCount: 0, _maxListeners: undefined }, cecHdmiPort: 'null' } cec-client exited with code 1 UDP Client listening on 0.0.0.0:39420 starting udp receive timer with timeout ms: 1000 Message from: xxxxxxxxxxx ServerDiscovery message received Server discovery json: {"Address":"http://xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"} ServerDiscovery message received cec-client exited with code 1 timer expired 2 servers received [ { Address: 'http://xxxxxxxxxxxxx Id: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx Name: 'xxxxxxxxx EndpointAddress: 'xxxxxxxxxxxx }, with sudo: Initializing cec-client... { cecExePath: 'cec-client', cecEmitter: EventEmitter { _events: [Object: null prototype] {}, _eventsCount: 0, _maxListeners: undefined }, cecHdmiPort: 'null' } UDP Client listening on 0.0.0.0:39420 starting udp receive timer with timeout ms: 1000 Message from: xxxxxxxxxxxxx ServerDiscovery message received Server discovery json: {"Address":"http://xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"} ServerDiscovery message received cec-client exited with code 1 timer expired 2 servers received [ { Address: 'http://xxxxxxxxxxxxx Id: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx Name: 'xxxxxxxxx EndpointAddress: 'xxxxxxxxxxxx }, Anybody an idea how to run this without sudo? Edited August 1, 2023 by screamor
alucryd 318 Posted August 5, 2023 Posted August 5, 2023 What debian version is that? It looks like debian hides the ldconfig binary from normal users, because debian...... That's very unfortunate. Are you able to locate that binary and look at the permissions on it? As root you should be able to do that with `ls -lah $(which ldconfig)`
flower1024 1 Posted October 11, 2023 Posted October 11, 2023 Hello, I am using Emby Theather as a flatpak on NixOS with KDE with multiple screens. Whenever i maximize the emby app to fullscreen I can't focus any other windows. Well I kinda can focus them (they come to the front) but i can't type. Keyboard focus stays within emby theater. Any solution for this?
them8os235 47 Posted November 1, 2023 Posted November 1, 2023 (edited) Hey there all. Reaching out for assistance. Has anyone here successfully run the latest 3.0.19 (or even any previous version if you did) of Emby Theater OS image (the 1Gig image) on a Raspberry Pi (3 or 4) along with a DAC HAT (my case it's a HiFiBerry DAC2 Pro) and importantly along with video out to an official 7" display, not HDMI? (p.s., in these turn-key devices I'm making for a friend I'm using Emby Theater in this case for only music, absolutely no music videos, movies, live TV, etc.) I've run into an issue I can't get past, documented here where I requested assistance by Luke, but happy to get anyone's assistance: https://emby.media/community/index.php?/topic/122644-how-to-send-emby-theater-for-rpi-audio-to-my-dac-hat-shell-access/&do=findComment&comment=1294146 Additional background in the posts above. In a nutshell if I output video to HDMI my configurations to output audio via the DAC HAT works. However if I use the 7" display (which is mandatory in this use case), no audio is output by the DAC HAT ... even though the "green activity light" on the DAC lights up when I play music and goes off when I stop it, and aplay -l lists the only sound card is my DAC, and /usr/bin/pactl list shows the song and correct "stats" I am playing by emby-theater, and alsamixer all looks good, etc. There is a lot of experience across the board here. So hopping someone may know what needs to go into the "special sauce" in configuring the OS/ ALSA / PulseAudio / whatever else, so that I can use EmbyTheater along my DAC HATs along with a 7" display the same as when I use an HDMI display. Here and eager to supply any additional info anyone needs to assist; my config.txt is already shared at that link above. Thanks much for all replies. Edited November 1, 2023 by them8os235 typos
them8os235 47 Posted November 4, 2023 Posted November 4, 2023 (edited) Please disregard the post immediately above this. The frig'n HiFiBerry's analog output buffer sections failed! On both of my DAC2 Pros! That's why I wasn't getting audio out! More here if desired. I also provide the config.txt I'm using to run Emby Theater as a turn-key music player on a 2 Gig RPi4 using an official 7" display with audio output thru an Allo Boss DAC HAT, if anyone would like to do the same easily. Edited November 4, 2023 by them8os235 1
them8os235 47 Posted November 19, 2023 Posted November 19, 2023 At risk of cross posting, I would like to place a request for assistance rotating the Emby Theater display on a Raspberry Pi, which I posted here in the Raspberry Pi section: https://emby.media/community/index.php?/topic/123305-cant-get-emby-theater-display-to-rotate-need-help/ Hoping to get more eyeballs on it from people that may frequent or follow this thread but not the RPi section. Thanx
Luke 42242 Posted November 19, 2023 Posted November 19, 2023 2 hours ago, them8os235 said: At risk of cross posting, I would like to place a request for assistance rotating the Emby Theater display on a Raspberry Pi, which I posted here in the Raspberry Pi section: https://emby.media/community/index.php?/topic/123305-cant-get-emby-theater-display-to-rotate-need-help/ Hoping to get more eyeballs on it from people that may frequent or follow this thread but not the RPi section. Thanx Hi, we’ll help you in your topic. Thanks.
adrianwi 279 Posted November 26, 2023 Posted November 26, 2023 Does anyone have this working on a Raspberry Pi 5 running Raspberry Pi OS Bookworm? I've followed the Debian Arm64 instructions and the App installs but fails to launch.
alucryd 318 Posted November 26, 2023 Posted November 26, 2023 This will probably need some additional work on our end to get RPi 5 support, it's a new SoC with a new GPU so hardware acceleration will most likely not work with the current packages. 1
electricwildflower 17 Posted December 10, 2023 Posted December 10, 2023 Just a quick shout out for support but Emby Theatre on Linux Mint seems to be a little slow when loading music IE i select a song and about 5/10/15/20 seconds later it will start the song. Also when i do the following and go to shut down from the menu i get the following error. Exiting, signing out etc seems to work fine though just shutdown that's the issue.
Luke 42242 Posted December 10, 2023 Posted December 10, 2023 12 hours ago, electricwildflower said: Just a quick shout out for support but Emby Theatre on Linux Mint seems to be a little slow when loading music IE i select a song and about 5/10/15/20 seconds later it will start the song. Also when i do the following and go to shut down from the menu i get the following error. Exiting, signing out etc seems to work fine though just shutdown that's the issue. Hi, we'll take a look at that. Thanks for reporting.
KeithA 5 Posted March 29, 2024 Posted March 29, 2024 Hello, I have installed Emby Theater on a PC running Ubuntu 22.04 LTS. ET runs fine however I have ran into an issue I have been unable to solve. It involves the use of Alsa for Pass-through. It would seem that MPV is configured improperly. I have been successful using pass-through on this system using Kodi. When Kodi is playing a file I have verified the device in use. Are there any special settings I should be entering into mpv.conf? I have already tried the audio-device parameter choosing from the list of devices generated by MPV (see below) however it always produces an error stating "failed to initialize audio driver". Any suggestions to get this working are appreciated. Thanks List of detected audio devices: 'auto' (Autoselect device) 'alsa' (Default (alsa)) 'alsa/samplerate' (Rate Converter Plugin Using Samplerate Library) 'alsa/speexrate' (Rate Converter Plugin Using Speex Resampler) 'alsa/jack' (JACK Audio Connection Kit) 'alsa/oss' (Open Sound System) 'alsa/upmix' (Plugin for channel upmix (4,6,8)) 'alsa/vdownmix' (Plugin for channel downmix (stereo) with a simple spacialization) 'alsa/plughw:CARD=NVidia,DEV=3' (HDA NVidia, HDMI 0/Hardware device with all software conversions) 'alsa/plughw:CARD=NVidia,DEV=7' (HDA NVidia, HDMI 1/Hardware device with all software conversions) 'alsa/plughw:CARD=NVidia,DEV=8' (HDA NVidia, HDMI 2/Hardware device with all software conversions) 'alsa/plughw:CARD=NVidia,DEV=9' (HDA NVidia, HDMI 3/Hardware device with all software conversions) 'alsa/hdmi:CARD=NVidia,DEV=0' (HDA NVidia, HDMI 0/HDMI Audio Output) 'alsa/hdmi:CARD=NVidia,DEV=1' (HDA NVidia, HDMI 1/HDMI Audio Output) 'alsa/hdmi:CARD=NVidia,DEV=2' (HDA NVidia, HDMI 2/HDMI Audio Output) 'alsa/hdmi:CARD=NVidia,DEV=3' (HDA NVidia, HDMI 3/HDMI Audio Output) 'alsa/dmix:CARD=NVidia,DEV=3' (HDA NVidia, HDMI 0/Direct sample mixing device) 'alsa/dmix:CARD=NVidia,DEV=7' (HDA NVidia, HDMI 1/Direct sample mixing device) 'alsa/dmix:CARD=NVidia,DEV=8' (HDA NVidia, HDMI 2/Direct sample mixing device) 'alsa/dmix:CARD=NVidia,DEV=9' (HDA NVidia, HDMI 3/Direct sample mixing device) 'alsa/usbstream:CARD=NVidia' (HDA NVidia/USB Stream Output)
pmsys 0 Posted March 30, 2024 Posted March 30, 2024 Hello, I tried to use the this version of ET for Raspberry Pi: https://github.com/MediaBrowser/emby-theater-electron/releases/download/3.0.16/emby-theater-rpi_3.0.16_arm64.img.xz. But I got the same error here: And in addition to this, I can't play any video files. (Mostly encoded with H264). It gets stuck at the spinner right after playback starts. I used RPI 3/4 and a wired network connection. How can I solve this? And btw.: Is ET still in development? The last release is more than one year ago and the GitHub repo seems to only get chore commits. Thanks
pmsys 0 Posted April 8, 2024 Posted April 8, 2024 Hello, I got ET running. What I did: - Install official latest RasbianOS - Follow this guide: https://emby.media/emby-theater-linux.html#deb - Setup autologin and autostart of ET (everything is done in the raspi-config GUI) So, that means (at least for me): The official ET RPI images are broken. (https://emby.media/emby-theater-rpi.html) But my question remains: Is ET still in development? Greetz
them8os235 47 Posted April 8, 2024 Posted April 8, 2024 (edited) @pmsys, can I ask perhaps a silly question? Why did you go with version 3.0.16 of ET when the latest bug fixed version is 3.0.19? I recently built a few ET 'kiosk' style devices using Raspberry PI 4 w/the official 7" display and DAC HATs successfully (they are intended as music players, not planned for use viewing video). Though there were a few times when it didn't initialize correctly on first boot and I needed to start over and re-burn the SD and re-customize the config file; can't explain the reason for that. But all in all, I had good success with with the current build of Emby Theater, 3.0.19: https://github.com/MediaBrowser/emby-theater-electron/releases/tag/3.0.19 Edited April 8, 2024 by them8os235
pmsys 0 Posted April 9, 2024 Posted April 9, 2024 Hi @them8os235, I used the official .deb file. In my first attempt, I setup RaspianOS with nodejs and clones the ET git repo. But this didn't work out for me... Couldn't play any video files. Therefore I used the official ET .deb files. And the latest here is 3.0.16. So, for me it's ok for now.
Luke 42242 Posted April 14, 2024 Posted April 14, 2024 On 4/9/2024 at 4:47 AM, pmsys said: Hi @them8os235, I used the official .deb file. In my first attempt, I setup RaspianOS with nodejs and clones the ET git repo. But this didn't work out for me... Couldn't play any video files. Therefore I used the official ET .deb files. And the latest here is 3.0.16. So, for me it's ok for now. Hi, where exactly do you see 3.0.16 as the latest?
pmsys 0 Posted April 15, 2024 Posted April 15, 2024 On 4/14/2024 at 11:12 PM, Luke said: Hi, where exactly do you see 3.0.16 as the latest? Exactly here: https://emby.media/emby-theater-rpi.html -> Link: "Emby Theater RPI for Arm64" is pointing to: https://github.com/MediaBrowser/emby-theater-electron/releases/download/3.0.16/emby-theater-rpi_3.0.16_arm64.img.xz And this is, what I need for the RPI 4.
Luke 42242 Posted May 8, 2024 Posted May 8, 2024 On 4/15/2024 at 6:43 PM, pmsys said: Exactly here: https://emby.media/emby-theater-rpi.html -> Link: "Emby Theater RPI for Arm64" is pointing to: https://github.com/MediaBrowser/emby-theater-electron/releases/download/3.0.16/emby-theater-rpi_3.0.16_arm64.img.xz And this is, what I need for the RPI 4. OK yes the RPI image is on 3.0.16 as some elements of that need to be reworked, but the other builds are all up to date.
