MSattler 390 Posted November 28, 2016 Posted November 28, 2016 I've got one movie that seems to always remux DTS-HD 7.1. Which is odd since other BluRay's with DTS-HD 5.1 and True-HD just end up as PCM now. But in this case it seems to want to remux to AC-3? Any known reason for this? This is on a Shield. File info: General Unique ID : 221660691375488726574098230072291674655 (0xA6C24BDA67F862270E3125C7212CCA1F) Complete name : \\tower2\kids\Finding Dory (2016)\Finding Dory.mkv Format : Matroska Format version : Version 2 File size : 23.1 GiB Duration : 1h 37mn Overall bit rate mode : Variable Overall bit rate : 34.0 Mbps Movie name : Finding Dory Encoded date : UTC 2016-10-29 03:41:26 Writing application : MakeMKV v1.10.0 win(x64-release) Writing library : libmakemkv v1.10.0 (1.3.3/1.4.4) win(x64-release) Original source medium : Blu-ray Video ID : 1 ID in the original source medium : 4113 (0x1011) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Format settings, GOP : M=1, N=12 Codec ID : V_MPEG4/ISO/AVC Duration : 1h 37mn Bit rate mode : Variable Bit rate : 23.6 Mbps Maximum bit rate : 32.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.475 Stream size : 16.0 GiB (69%) Language : English Default : No Forced : No Audio #1 ID : 2 ID in the original source medium : 4352 (0x1100) Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 1h 37mn Bit rate mode : Variable / Constant Bit rate : 4 527 Kbps / 1 509 Kbps Channel(s) : 8 channels / 6 channels Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Frame rate : 93.750 fps (512 spf) Bit depth : 24 bits Compression mode : Lossless / Lossy Stream size : 3.07 GiB (13%) Title : Surround 7.1 Language : English Default : Yes Forced : No Audio #2 ID : 3 ID in the original source medium : 4352 (0x1100) Format : DTS Format/Info : Digital Theater Systems Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 1h 37mn Bit rate mode : Constant Bit rate : 1 509 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Frame rate : 93.750 fps (512 spf) Bit depth : 24 bits Compression mode : Lossy Stream size : 1.02 GiB (4%) Title : Surround 5.1 Language : English Default : No Forced : No Audio #3 ID : 4 ID in the original source medium : 4353 (0x1101) Format : DTS Format/Info : Digital Theater Systems Format profile : HRA / Core Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 1h 37mn Bit rate mode : Constant Bit rate : 2 046 Kbps / 1 509 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Frame rate : 93.750 fps (512 spf) Bit depth : 24 bits Compression mode : Lossy Stream size : 1.39 GiB (6%) Title : Surround 5.1 Language : English Default : No Forced : No Audio #4 ID : 5 ID in the original source medium : 4353 (0x1101) Format : DTS Format/Info : Digital Theater Systems Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 1h 37mn Bit rate mode : Constant Bit rate : 1 509 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Frame rate : 93.750 fps (512 spf) Bit depth : 24 bits Compression mode : Lossy Stream size : 1.02 GiB (4%) Title : Surround 5.1 Language : English Default : No Forced : No Audio #5 ID : 6 ID in the original source medium : 4354 (0x1102) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 1h 37mn Bit rate mode : Constant Bit rate : 320 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Frame rate : 31.250 fps (1536 spf) Compression mode : Lossy Stream size : 222 MiB (1%) Title : Stereo Language : English Default : No Forced : No Audio #6 ID : 7 ID in the original source medium : 4355 (0x1103) Format : AC-3 Format/Info : Audio Coding 3 Format profile : Dolby Digital Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 1h 37mn Bit rate mode : Constant Bit rate : 320 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Frame rate : 31.250 fps (1536 spf) Compression mode : Lossy Stream size : 222 MiB (1%) Title : Stereo Language : English Default : No Forced : No Text #1 ID : 8 ID in the original source medium : 4608 (0x1200) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1h 35mn Bit rate : 58.9 Kbps Count of elements : 3530 Stream size : 40.2 MiB (0%) Language : English Default : No Forced : No Text #2 ID : 10 ID in the original source medium : 4611 (0x1203) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1h 36mn Bit rate : 90.4 Kbps Count of elements : 4542 Stream size : 62.1 MiB (0%) Language : English Default : No Forced : No Menu 00:00:00.000 : en:Chapter 01 00:02:36.072 : en:Chapter 02 00:06:50.159 : en:Chapter 03 00:10:53.152 : en:Chapter 04 00:13:33.020 : en:Chapter 05 00:15:25.132 : en:Chapter 06 00:17:03.313 : en:Chapter 07 00:19:35.465 : en:Chapter 08 00:21:35.294 : en:Chapter 09 00:24:58.705 : en:Chapter 10 00:27:08.543 : en:Chapter 11 00:30:33.206 : en:Chapter 12 00:35:00.056 : en:Chapter 13 00:37:52.019 : en:Chapter 14 00:40:17.998 : en:Chapter 15 00:41:06.672 : en:Chapter 16 00:42:30.422 : en:Chapter 17 00:46:03.427 : en:Chapter 18 00:48:41.710 : en:Chapter 19 00:50:27.858 : en:Chapter 20 00:55:06.678 : en:Chapter 21 00:57:05.839 : en:Chapter 22 01:00:41.346 : en:Chapter 23 01:04:32.743 : en:Chapter 24 01:10:36.815 : en:Chapter 25 01:12:28.302 : en:Chapter 26 01:14:09.862 : en:Chapter 27 01:18:26.493 : en:Chapter 28 01:26:49.454 : en:Chapter 29 Log file from Emby: http://192.168.1.125:8096/emby/videos/f74481d415edd0fb205d6ad144fe57a2/stream.mkv?DeviceId=7825a196ae905b9b&MediaSourceId=f74481d415edd0fb205d6ad144fe57a2&VideoCodec=h264&AudioCodec=ac3,aac,mp3&AudioStreamIndex=1&VideoBitrate=39808000&AudioBitrate=192000&MaxAudioChannels=6&MaxFramerate=60&Level=51&Profile=high&PlaySessionId=ca46b7e2c16e4339bf1b95e6b4aa82cf&api_key=b2163c0ed2a443de85ea545e95b837da&CopyTimestamps=true&SubtitleMethod=Encode&TranscodingMaxAudioChannels=6&EnableSubtitlesInManifest=false&Tag=1ad4bde508745f51efe6c55e33041d91&EnableSplittingOnNonKeyFrames=false&RequireAvc=false {"Protocol":"File","Id":"f74481d415edd0fb205d6ad144fe57a2","Path":"\\\\tower2\\kids\\Finding Dory (2016)\\Finding Dory.mkv","Type":"Default","Container":"mkv","Name":"1080P/H264/DTS-HD MA","ETag":"1ad4bde508745f51efe6c55e33041d91","RunTimeTicks":58236800000,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1001/48000","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":34023990,"BitDepth":8,"RefFrames":4,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":23.97602,"RealFrameRate":23.97602,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"dca","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Surround 7.1","DisplayTitle":"Eng Surround 7.1","IsInterlaced":false,"ChannelLayout":"7.1","BitDepth":24,"Channels":8,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"DTS-HD MA","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"dca","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Surround 5.1","DisplayTitle":"Eng Surround 5.1","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":1536000,"BitDepth":24,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Profile":"DTS","Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"dca","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Surround 5.1","DisplayTitle":"Eng Surround 5.1","IsInterlaced":false,"ChannelLayout":"5.1","BitDepth":24,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Profile":"DTS-HD HRA","Type":"Audio","Index":3,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"dca","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Surround 5.1","DisplayTitle":"Eng Surround 5.1","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":1536000,"BitDepth":24,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Profile":"DTS","Type":"Audio","Index":4,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"ac3","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Stereo","DisplayTitle":"Eng Stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":320000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":5,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"ac3","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Stereo","DisplayTitle":"Eng Stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":320000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":6,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"PGSSUB","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/1000","DisplayTitle":"Eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":7,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"PGSSUB","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/1000","DisplayTitle":"Eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":8,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":34023990,"RequiredHttpHeaders":{}} B:\Users\Administrator\AppData\Roaming\Emby-Server\ffmpeg\20160410\ffmpeg.exe -fflags +genpts -i file:"\\tower2\kids\Finding Dory (2016)\Finding Dory.mkv" -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -copyts -avoid_negative_ts disabled -start_at_zero -map_metadata -1 -threads 0 -codec:a:0 ac3 -ac 6 -ab 192000 -af "aresample=async=1" -y "B:\Users\Administrator\AppData\Roaming\Emby-Server\transcoding-temp\transcoding-temp\a13ff2da4bfd822b4018ee0d0ba6c884.mkv" ffmpeg version N-79277-g0c90b2e Copyright © 2000-2016 the FFmpeg developers built with gcc 5.3.0 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib libavutil 55. 20.100 / 55. 20.100 libavcodec 57. 34.100 / 57. 34.100 libavformat 57. 32.100 / 57. 32.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 41.100 / 6. 41.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 [matroska,webm @ 00000000008f38a0] Could not find codec parameters for stream 7 (Subtitle: hdmv_pgs_subtitle): unspecified size Consider increasing the value for the 'analyzeduration' and 'probesize' options [matroska,webm @ 00000000008f38a0] Could not find codec parameters for stream 8 (Subtitle: hdmv_pgs_subtitle): unspecified size Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, matroska,webm, from 'file:\\tower2\kids\Finding Dory (2016)\Finding Dory.mkv': Metadata: title : Finding Dory encoder : libmakemkv v1.10.0 (1.3.3/1.4.4) win(x64-release) creation_time : 2016-10-29 03:41:26 Duration: 01:37:03.68, start: 0.000000, bitrate: 34023 kb/s Chapter #0:0: start 0.000000, end 156.072583 Metadata: title : Chapter 01 Chapter #0:1: start 156.072583, end 410.159750 Metadata: title : Chapter 02 Chapter #0:2: start 410.159750, end 653.152500 Metadata: title : Chapter 03 Chapter #0:3: start 653.152500, end 813.020542 Metadata: title : Chapter 04 Chapter #0:4: start 813.020542, end 925.132542 Metadata: title : Chapter 05 Chapter #0:5: start 925.132542, end 1023.313958 Metadata: title : Chapter 06 Chapter #0:6: start 1023.313958, end 1175.465958 Metadata: title : Chapter 07 Chapter #0:7: start 1175.465958, end 1295.294000 Metadata: title : Chapter 08 Chapter #0:8: start 1295.294000, end 1498.705542 Metadata: title : Chapter 09 Chapter #0:9: start 1498.705542, end 1628.543583 Metadata: title : Chapter 10 Chapter #0:10: start 1628.543583, end 1833.206375 Metadata: title : Chapter 11 Chapter #0:11: start 1833.206375, end 2100.056292 Metadata: title : Chapter 12 Chapter #0:12: start 2100.056292, end 2272.019750 Metadata: title : Chapter 13 Chapter #0:13: start 2272.019750, end 2417.998917 Metadata: title : Chapter 14 Chapter #0:14: start 2417.998917, end 2466.672542 Metadata: title : Chapter 15 Chapter #0:15: start 2466.672542, end 2550.422875 Metadata: title : Chapter 16 Chapter #0:16: start 2550.422875, end 2763.427333 Metadata: title : Chapter 17 Chapter #0:17: start 2763.427333, end 2921.710458 Metadata: title : Chapter 18 Chapter #0:18: start 2921.710458, end 3027.858167 Metadata: title : Chapter 19 Chapter #0:19: start 3027.858167, end 3306.678375 Metadata: title : Chapter 20 Chapter #0:20: start 3306.678375, end 3425.839083 Metadata: title : Chapter 21 Chapter #0:21: start 3425.839083, end 3641.346042 Metadata: title : Chapter 22 Chapter #0:22: start 3641.346042, end 3872.743875 Metadata: title : Chapter 23 Chapter #0:23: start 3872.743875, end 4236.815917 Metadata: title : Chapter 24 Chapter #0:24: start 4236.815917, end 4348.302292 Metadata: title : Chapter 25 Chapter #0:25: start 4348.302292, end 4449.862083 Metadata: title : Chapter 26 Chapter #0:26: start 4449.862083, end 4706.493458 Metadata: title : Chapter 27 Chapter #0:27: start 4706.493458, end 5209.454250 Metadata: title : Chapter 28 Chapter #0:28: start 5209.454250, end 5823.680000 Metadata: title : Chapter 29 Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1080 [sAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc Metadata: BPS-eng : 23638485 DURATION-eng : 01:37:03.651166666 NUMBER_OF_FRAMES-eng: 139628 NUMBER_OF_BYTES-eng: 17207786159 SOURCE_ID-eng : 001011 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.0 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2016-10-29 03:41:26 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream #0:1(eng): Audio: dts (DTS-HD MA), 48000 Hz, 7.1, s32p (24 bit) (default) Metadata: title : Surround 7.1 BPS-eng : 4526804 DURATION-eng : 01:37:03.658666666 NUMBER_OF_FRAMES-eng: 545968 NUMBER_OF_BYTES-eng: 3295320172 SOURCE_ID-eng : 001100 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.0 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2016-10-29 03:41:26 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream #0:2(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s Metadata: title : Surround 5.1 BPS-eng : 1509000 DURATION-eng : 01:37:03.658666666 NUMBER_OF_FRAMES-eng: 545968 NUMBER_OF_BYTES-eng: 1098487616 SOURCE_ID-eng : 001100 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.0 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2016-10-29 03:41:26 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream #0:3(eng): Audio: dts (DTS-HD HRA), 48000 Hz, 5.1(side), fltp Metadata: title : Surround 5.1 BPS-eng : 2046000 DURATION-eng : 01:37:03.658666666 NUMBER_OF_FRAMES-eng: 545968 NUMBER_OF_BYTES-eng: 1489400704 SOURCE_ID-eng : 001101 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.0 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2016-10-29 03:41:26 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream #0:4(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s Metadata: title : Surround 5.1 BPS-eng : 1509000 DURATION-eng : 01:37:03.658666666 NUMBER_OF_FRAMES-eng: 545968 NUMBER_OF_BYTES-eng: 1098487616 SOURCE_ID-eng : 001101 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.0 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2016-10-29 03:41:26 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream #0:5(eng): Audio: ac3, 48000 Hz, stereo, fltp, 320 kb/s Metadata: title : Stereo BPS-eng : 320000 DURATION-eng : 01:37:03.680000000 NUMBER_OF_FRAMES-eng: 181990 NUMBER_OF_BYTES-eng: 232947200 SOURCE_ID-eng : 001102 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.0 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2016-10-29 03:41:26 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream #0:6(eng): Audio: ac3, 48000 Hz, stereo, fltp, 320 kb/s Metadata: title : Stereo BPS-eng : 320000 DURATION-eng : 01:37:03.680000000 NUMBER_OF_FRAMES-eng: 181990 NUMBER_OF_BYTES-eng: 232947200 SOURCE_ID-eng : 001103 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.0 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2016-10-29 03:41:26 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream #0:7(eng): Subtitle: hdmv_pgs_subtitle Metadata: BPS-eng : 58945 DURATION-eng : 01:35:24.614729166 NUMBER_OF_FRAMES-eng: 3530 NUMBER_OF_BYTES-eng: 42180101 SOURCE_ID-eng : 001200 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.0 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2016-10-29 03:41:26 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Stream #0:8(eng): Subtitle: hdmv_pgs_subtitle Metadata: BPS-eng : 90382 DURATION-eng : 01:36:08.158229166 NUMBER_OF_FRAMES-eng: 4542 NUMBER_OF_BYTES-eng: 65167249 SOURCE_ID-eng : 001203 _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.0 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2016-10-29 03:41:26 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID Output #0, matroska, to 'B:\Users\Administrator\AppData\Roaming\Emby-Server\transcoding-temp\transcoding-temp\a13ff2da4bfd822b4018ee0d0ba6c884.mkv': Metadata: encoder : Lavf57.32.100 Chapter #0:0: start 0.000000, end 156.072583 Chapter #0:1: start 156.072583, end 410.159750 Chapter #0:2: start 410.159750, end 653.152500 Chapter #0:3: start 653.152500, end 813.020542 Chapter #0:4: start 813.020542, end 925.132542 Chapter #0:5: start 925.132542, end 1023.313958 Chapter #0:6: start 1023.313958, end 1175.465958 Chapter #0:7: start 1175.465958, end 1295.294000 Chapter #0:8: start 1295.294000, end 1498.705542 Chapter #0:9: start 1498.705542, end 1628.543583 Chapter #0:10: start 1628.543583, end 1833.206375 Chapter #0:11: start 1833.206375, end 2100.056292 Chapter #0:12: start 2100.056292, end 2272.019750 Chapter #0:13: start 2272.019750, end 2417.998917 Chapter #0:14: start 2417.998917, end 2466.672542 Chapter #0:15: start 2466.672542, end 2550.422875 Chapter #0:16: start 2550.422875, end 2763.427333 Chapter #0:17: start 2763.427333, end 2921.710458 Chapter #0:18: start 2921.710458, end 3027.858167 Chapter #0:19: start 3027.858167, end 3306.678375 Chapter #0:20: start 3306.678375, end 3425.839083 Chapter #0:21: start 3425.839083, end 3641.346042 Chapter #0:22: start 3641.346042, end 3872.743875 Chapter #0:23: start 3872.743875, end 4236.815917 Chapter #0:24: start 4236.815917, end 4348.302292 Chapter #0:25: start 4348.302292, end 4449.862083 Chapter #0:26: start 4449.862083, end 4706.493458 Chapter #0:27: start 4706.493458, end 5209.454250 Chapter #0:28: start 5209.454250, end 5823.680000 Stream #0:0: Video: h264 (H264 / 0x34363248), yuv420p, 1920x1080 [sAR 1:1 DAR 16:9], q=2-31, 23.98 fps, 23.98 tbr, 1k tbn, 1k tbc Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, 5.1, fltp (24 bit), 192 kb/s (default) Metadata: encoder : Lavc57.34.100 ac3 Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (dts (dca) -> ac3 (native)) Press [q] to stop, [?] for help frame= 230 fps=0.0 q=-1.0 size= 28668kB time=00:00:09.56 bitrate=24557.7kbits/s speed=18.8x frame= 442 fps=429 q=-1.0 size= 58380kB time=00:00:18.39 bitrate=25998.9kbits/s speed=17.9x frame= 636 fps=414 q=-1.0 size= 89055kB time=00:00:26.49 bitrate=27539.2kbits/s speed=17.3x frame= 850 fps=416 q=-1.0 size= 115893kB time=00:00:35.48 bitrate=26756.2kbits/s speed=17.4x frame= 1142 fps=447 q=-1.0 size= 138542kB time=00:00:47.57 bitrate=23853.8kbits/s speed=18.6x frame= 1374 fps=450 q=-1.0 size= 160929kB time=00:00:57.27 bitrate=23017.6kbits/s speed=18.7x frame= 1587 fps=446 q=-1.0 size= 190947kB time=00:01:06.20 bitrate=23627.9kbits/s speed=18.6x frame= 1820 fps=442 q=-1.0 size= 222032kB time=00:01:15.86 bitrate=23974.7kbits/s speed=18.4x frame= 2062 fps=446 q=-1.0 size= 253673kB time=00:01:26.01 bitrate=24160.7kbits/s speed=18.6x frame= 2301 fps=447 q=-1.0 size= 279608kB time=00:01:35.96 bitrate=23869.1kbits/s speed=18.6x frame= 2517 fps=442 q=-1.0 size= 307782kB time=00:01:44.95 bitrate=24023.2kbits/s speed=18.4x frame= 2755 fps=444 q=-1.0 size= 337044kB time=00:01:54.90 bitrate=24028.7kbits/s speed=18.5x frame= 2991 fps=446 q=-1.0 size= 363854kB time=00:02:04.73 bitrate=23897.0kbits/s speed=18.6x frame= 3205 fps=445 q=-1.0 size= 388767kB time=00:02:13.69 bitrate=23821.9kbits/s speed=18.6x frame= 3436 fps=446 q=-1.0 size= 414947kB time=00:02:23.29 bitrate=23722.7kbits/s speed=18.6x frame= 3728 fps=454 q=-1.0 size= 435954kB time=00:02:35.51 bitrate=22964.6kbits/s speed=18.9x frame= 4011 fps=459 q=-1.0 size= 458430kB time=00:02:47.29 bitrate=22448.6kbits/s speed=19.2x frame= 4217 fps=457 q=-1.0 size= 489849kB time=00:02:55.89 bitrate=22813.3kbits/s speed=19.1x frame= 4421 fps=453 q=-1.0 size= 521249kB time=00:03:04.37 bitrate=23159.2kbits/s speed=18.9x frame= 4697 fps=457 q=-1.0 size= 541509kB time=00:03:15.89 bitrate=22644.5kbits/s speed=19.1x frame= 4926 fps=457 q=-1.0 size= 576781kB time=00:03:25.43 bitrate=22999.9kbits/s speed=19.1x frame= 5114 fps=453 q=-1.0 size= 605352kB time=00:03:33.27 bitrate=23251.9kbits/s speed=18.9x frame= 5321 fps=451 q=-1.0 size= 636358kB time=00:03:41.88 bitrate=23494.6kbits/s speed=18.8x frame= 5592 fps=454 q=-1.0 size= 664181kB time=00:03:53.21 bitrate=23330.7kbits/s speed=18.9x frame= 5849 fps=456 q=-1.0 size= 689401kB time=00:04:03.99 bitrate=23146.3kbits/s speed= 19x frame= 6098 fps=450 q=-1.0 size= 714610kB time=00:04:14.33 bitrate=23017.6kbits/s speed=18.8x frame= 6351 fps=452 q=-1.0 size= 739923kB time=00:04:24.85 bitrate=22885.6kbits/s speed=18.8x frame= 6600 fps=453 q=-1.0 size= 767911kB time=00:04:35.32 bitrate=22848.5kbits/s speed=18.9x frame= 6820 fps=451 q=-1.0 size= 797289kB time=00:04:44.44 bitrate=22962.0kbits/s speed=18.8x frame= 7049 fps=451 q=-1.0 size= 826765kB time=00:04:54.04 bitrate=23033.6kbits/s speed=18.8x frame= 7311 fps=452 q=-1.0 size= 853673kB time=00:05:04.89 bitrate=22937.0kbits/s speed=18.8x frame= 7553 fps=451 q=-1.0 size= 882473kB time=00:05:14.97 bitrate=22952.0kbits/s speed=18.8x frame= 7796 fps=451 q=-1.0 size= 912124kB time=00:05:25.11 bitrate=22983.0kbits/s speed=18.8x frame= 8036 fps=452 q=-1.0 size= 941905kB time=00:05:35.16 bitrate=23021.9kbits/s speed=18.8x frame= 8249 fps=450 q=-1.0 size= 971876kB time=00:05:44.02 bitrate=23142.4kbits/s speed=18.8x frame= 8454 fps=449 q=-1.0 size= 1001023kB time=00:05:52.60 bitrate=23256.7kbits/s speed=18.7x frame= 8689 fps=449 q=-1.0 size= 1029317kB time=00:06:02.45 bitrate=23263.8kbits/s speed=18.7x frame= 8897 fps=448 q=-1.0 size= 1058584kB time=00:06:11.06 bitrate=23370.2kbits/s speed=18.7x frame= 9116 fps=447 q=-1.0 size= 1091809kB time=00:06:20.18 bitrate=23525.5kbits/s speed=18.6x frame= 9324 fps=446 q=-1.0 size= 1117750kB time=00:06:28.85 bitrate=23547.4kbits/s speed=18.6x frame= 9554 fps=446 q=-1.0 size= 1150035kB time=00:06:38.42 bitrate=23645.7kbits/s speed=18.6x frame= 9762 fps=444 q=-1.0 size= 1177642kB time=00:06:47.13 bitrate=23695.7kbits/s speed=18.5x frame=10021 fps=446 q=-1.0 size= 1203404kB time=00:06:57.94 bitrate=23587.4kbits/s speed=18.6x frame=10280 fps=447 q=-1.0 size= 1232117kB time=00:07:08.79 bitrate=23539.2kbits/s speed=18.7x frame=10495 fps=446 q=-1.0 size= 1258604kB time=00:07:17.72 bitrate=23554.8kbits/s speed=18.6x frame=10722 fps=446 q=-1.0 size= 1286428kB time=00:07:27.19 bitrate=23565.6kbits/s speed=18.6x frame=10945 fps=446 q=-1.0 size= 1313656kB time=00:07:36.57 bitrate=23570.2kbits/s speed=18.6x frame=11186 fps=446 q=-1.0 size= 1343381kB time=00:07:46.52 bitrate=23589.4kbits/s speed=18.6x frame=11408 fps=446 q=-1.0 size= 1370185kB time=00:07:55.86 bitrate=23587.6kbits/s speed=18.6x frame=11638 fps=446 q=-1.0 size= 1401208kB time=00:08:05.37 bitrate=23649.3kbits/s speed=18.6x frame=11874 fps=446 q=-1.0 size= 1429038kB time=00:08:15.25 bitrate=23637.5kbits/s speed=18.6x frame=12096 fps=446 q=-1.0 size= 1457616kB time=00:08:24.47 bitrate=23669.7kbits/s speed=18.6x frame=12318 fps=445 q=-1.0 size= 1485357kB time=00:08:33.75 bitrate=23684.5kbits/s speed=18.6x frame=12568 fps=446 q=-1.0 size= 1513380kB time=00:08:44.18 bitrate=23651.1kbits/s speed=18.6x frame=12817 fps=447 q=-1.0 size= 1536917kB time=00:08:54.55 bitrate=23553.1kbits/s speed=18.7x frame=13072 fps=448 q=-1.0 size= 1561061kB time=00:09:05.24 bitrate=23454.2kbits/s speed=18.7x frame=13321 fps=449 q=-1.0 size= 1584889kB time=00:09:15.54 bitrate=23370.5kbits/s speed=18.7x frame=13541 fps=449 q=-1.0 size= 1616440kB time=00:09:24.79 bitrate=23445.5kbits/s speed=18.7x frame=13754 fps=448 q=-1.0 size= 1644288kB time=00:09:33.62 bitrate=23482.2kbits/s speed=18.7x frame=13990 fps=448 q=-1.0 size= 1674031kB time=00:09:43.48 bitrate=23503.1kbits/s speed=18.7x frame=14212 fps=447 q=-1.0 size= 1703356kB time=00:09:52.76 bitrate=23540.4kbits/s speed=18.7x frame=14344 fps=447 q=-1.0 Lsize= 1720071kB time=00:09:58.23 bitrate=23554.0kbits/s speed=18.7x
ebr 16337 Posted November 28, 2016 Posted November 28, 2016 Since we can't pass DTS-HD it needs to transcode to convert it and our preferred target format is AC3 because that it the highest quality, most compatible format we can stream.
MSattler 390 Posted November 28, 2016 Author Posted November 28, 2016 Since we can't pass DTS-HD it needs to transcode to convert it and our preferred target format is AC3 because that it the highest quality, most compatible format we can stream. Interesting, I swear that for other DTS-HD BluRay rip's I end up getting PCM sent to the receiver. Will test when I get home. With the latest Shield updates I was pretty sure I saw either PCM or Dolby Digital Surround. Not AC3.
ebr 16337 Posted November 28, 2016 Posted November 28, 2016 It might be that something else about the item is causing a transcode.
MSattler 390 Posted November 28, 2016 Author Posted November 28, 2016 It might be that something else about the item is causing a transcode. Well looking at the log it is specifically a remux....
MSattler 390 Posted December 2, 2016 Author Posted December 2, 2016 Oh well. There seems no interest in getting truehd to work right so i will just stick with plex. It plays this movie without any issues.
foghat 65 Posted December 2, 2016 Posted December 2, 2016 (edited) Oh well. There seems no interest in getting truehd to work right so i will just stick with plex. It plays this movie without any issues. Ture HD? Your original post talks about DTS-HD. Either wayy, I doubt that is the case - pretty sure I've read they are working on hd audio pass-through. All of my moves have one audio track - either DTS HD or Dolby TrueHD. My dts hd 5.1 movies end up playing as PCM. I can't even play DTS HD 7.1 movies - gives me a player error (tried with 3 different dts hd 7.1 movies). If I had to guess, I'd say this is because ac-3 does not support 7.1. But who knows. In your case, I bet it isn't even playing your HD audio track - as AC3 does not support 7.1, it probably picks the one it can play most 'natively' which look like your track 2 - DTS 5.1. Though I thought emby could pass through DTS so strange it is showing as transcoding to ac-3. Do you have DTS pass-through turned on in the options? I bet not. Try turn it on and see if it plays as DTS. Bet you dollars to donuts that if you were to remove all audio tracks except the dts hd 7.1 track, you would end up with the same player error I am getting. Edit: from your log file: Stream #0:1 -> #0:1 (dts (dca) -> ac3 (native)) Pretty sure dts(dca) means it is just using the DTS track - track 2. Try turn on DTS pass through and see what happens. Edited December 2, 2016 by foghat 1
RanmaCanada 502 Posted December 2, 2016 Posted December 2, 2016 Have you tried using SPMC as an external player at all? It is the ONLY way to play HD files on android and get all your sound right.
foghat 65 Posted December 2, 2016 Posted December 2, 2016 Have you tried using SPMC as an external player at all? It is the ONLY way to play HD files on android and get all your sound right. Plex plays HD audio fine. At least as far as I can tell - only stated using it on my Shield as a stop gap until emby supports it.
MSattler 390 Posted December 2, 2016 Author Posted December 2, 2016 Plex passes TrueHd and DTSHD through with no issues. Emby for 5.1 TrueHD and DTSHD will just play PCM. Emby for 7.1 DTSHD will simply remux the audio to AC-3. Plex on the Shield right now works perfectly. No transcoding and HD audio passing through without issues. Maybe they are working on it, but if you have not been able to tell, the things that get worked on are things Eric and Luke want to work on, not things Emby needs to keep up with plex, or things the userbase want. If the current solution is good enough for them, then it wont get changed. I mean look at the release notes as of late. There is nothing groundbreaking here. In fact the latest blog was about adding local users. We have had that forever. It is not that i am ungrateful, it is simply that they have shunned all the 3rd party developers except for one. And they don't cater to what the users want. How long did it take for people to convince Luke that everything transcoding wasnt ok? He didn't see it as a problem so it wasn't worked on. Plex isn't perfect by any means. But for no transcode/no remux playback with hd audio, it simply works.
MSattler 390 Posted December 2, 2016 Author Posted December 2, 2016 Btw I offered to test HD audio when 3.3 was in beta for the shield. There was no interest from anyone.
foghat 65 Posted December 2, 2016 Posted December 2, 2016 Plex passes TrueHd and DTSHD through with no issues. Emby for 5.1 TrueHD and DTSHD will just play PCM. Emby for 7.1 DTSHD will simply remux the audio to AC-3. Plex on the Shield right now works perfectly. No transcoding and HD audio passing through without issues. Maybe they are working on it, but if you have not been able to tell, the things that get worked on are things Eric and Luke want to work on, not things Emby needs to keep up with plex, or things the userbase want. If the current solution is good enough for them, then it wont get changed. I mean look at the release notes as of late. There is nothing groundbreaking here. In fact the latest blog was about adding local users. We have had that forever. It is not that i am ungrateful, it is simply that they have shunned all the 3rd party developers except for one. And they don't cater to what the users want. How long did it take for people to convince Luke that everything transcoding wasnt ok? He didn't see it as a problem so it wasn't worked on. Plex isn't perfect by any means. But for no transcode/no remux playback with hd audio, it simply works. Not that it really makes a difference one way or the other (as HD audio is just not supported right now), but as I noted above, the log file you provided is showing that the 7.1 HD track is not being played at all. Emby is selecting DTS track and transcoding to ac3 - probably because you don't have the dts pass-through option selected in the app. Offering to beta test HD audio is great, but if it isn't ready to be tested, it isn't ready to be tested. Grass is always greener..... I have been spending a decent amount of time in the plex forums over the past couple of days. You talk about not caring what users want - there are threads, 100s of posts long and years old (and still active) requesting a proper collection implementation. General consensus is: don't hold your breath and, generally speaking, Plex has gone 'corporate' and doesn't seem to care at all about what the 'hard core' users (i.e the plex pass holders who post to the forum) want. I think it awesome the Luke and ebr are so active in these forums and more often than not are genuinely trying to get issues peopel are having figured out.
mastrmind11 722 Posted December 2, 2016 Posted December 2, 2016 I have no issue passing HD audio through on my Shield w/ passthrough enabled and using SPMC as my player. Give it a try.
MSattler 390 Posted December 2, 2016 Author Posted December 2, 2016 (edited) Not that it really makes a difference one way or the other (as HD audio is just not supported right now), but as I noted above, the log file you provided is showing that the 7.1 HD track is not being played at all. Emby is selecting DTS track and transcoding to ac3 - probably because you don't have the dts pass-through option selected in the app. Offering to beta test HD audio is great, but if it isn't ready to be tested, it isn't ready to be tested. Grass is always greener..... I have been spending a decent amount of time in the plex forums over the past couple of days. You talk about not caring what users want - there are threads, 100s of posts long and years old (and still active) requesting a proper collection implementation. General consensus is: don't hold your breath and, generally speaking, Plex has gone 'corporate' and doesn't seem to care at all about what the 'hard core' users (i.e the plex pass holders who post to the forum) want. I think it awesome the Luke and ebr are so active in these forums and more often than not are genuinely trying to get issues peopel are having figured out. Pass through is selected in the app. All 5.1 movies play fine with PCM instead of transcoding. It's only 7.1 movies that I can duplicate it. While Plex isn't perfect, they are good at the main thing Plex is supposed to do. Play back content to it's fullest capability. It's great that Emby has so many bells and whistles and features, but if you cannot get the basics right, who cares about the bells and whistles? At least Plex sold out and that is the cause for not listening, they made money off the product, and it works for 90% of the people. Emby on the other hand has 2 developers who make their living off of the product, but have no real desire to listen to the users. The fact that we are still talking about the lack of HD Audio Passthrough is an issue. There simply is no interest in fixing it because it isn't an issue for the dev's. That is my whole point on this. If Luke see's something he wants to fix, it's fixed immediately. If it's not something that concerns him, he doesn't bother with it. Just take a look at the beta releases. How many times has he put out a beta release that forces someone to reinstall, or immediately fail back because it was not fully tested. Because he only tests it for what he uses it for. I mean, take the Player Info sticky in this forum for instance. It was last updated in June. What good is a sticky when it is 6 months old, and there have been numerous client changes along the way..... Edited December 2, 2016 by MSattler
mata7 45 Posted December 2, 2016 Posted December 2, 2016 (edited) i give up on the HD Audio on emby, they dont even coments on what the problems is or what they are doing to fix it, i dont think hey will fix it cause they just dont care, adding hallowing theme, 5 sec of speed, apps for devices that no1 cares looks like more important for them, i stop using emby and using plex and recommend plex to all my friends and family now, wait for xmas and you will see another xmas movies recommend theme, cause that is really amazing and important lol see this is what get fix because is really important https://emby.media/community/index.php?/topic/41660-emby-icon-on-android-tv-optimization/ btw i dont like to say never again, but i believe this is my last comments about shield hd audio, it is pointless Edited December 2, 2016 by mata7
foghat 65 Posted December 2, 2016 Posted December 2, 2016 (edited) Pass through is selected in the app. All 5.1 movies play fine with PCM instead of transcoding. It's only 7.1 movies that I can duplicate it. While Plex isn't perfect, they are good at the main thing Plex is supposed to do. Play back content to it's fullest capability. It's great that Emby has so many bells and whistles and features, but if you cannot get the basics right, who cares about the bells and whistles? At least Plex sold out and that is the cause for not listening, they made money off the product, and it works for 90% of the people. Emby on the other hand has 2 developers who make their living off of the product, but have no real desire to listen to the users. The fact that we are still talking about the lack of HD Audio Passthrough is an issue. There simply is no interest in fixing it because it isn't an issue for the dev's. That is my whole point on this. If Luke see's something he wants to fix, it's fixed immediately. If it's not something that concerns him, he doesn't bother with it. Just take a look at the beta releases. How many times has he put out a beta release that forces someone to reinstall, or immediately fail back because it was not fully tested. Because he only tests it for what he uses it for. But again, the 7.1 DTS HD track is not even being played according to your log. The track being played is the 5.1 DTS track. Which probably makes sense since HD Audio is not supported. Though it is strange that it is transcodiing to AC3 - if you have the DTS pass-through enabled as you say. Try removing all audio tracks except the 7.1 DTS HD track from your movie - I bet it doesn't play at all (none of mine do), which obviously is not great. Or maybe I am reading the log wrong and the 7.1 hd track is playing. I don't know. I want to see HD Audio support on the Shield app very badly (and I believe it will come). But given, I bet, that the Shield app user base is likely much smaller than probably any other app user base, and, as you say, there seems to just be Luke and ebr (for the most part), I understand why it may not be a priority them (as disappointing as this is to me). Plus, need to keep in mind, the app isn't using a custom built video player - not sure if it is still the case, but at one point the player being used did not even support HD audio pass-through - in which case there is nothing ebr or Luke can do. Short of changing to a supported player, which probably opens up a whole lot of other complexities/work. Edited December 2, 2016 by foghat
MSattler 390 Posted December 5, 2016 Author Posted December 5, 2016 But again, the 7.1 DTS HD track is not even being played according to your log. The track being played is the 5.1 DTS track. Which probably makes sense since HD Audio is not supported. Though it is strange that it is transcodiing to AC3 - if you have the DTS pass-through enabled as you say. Try removing all audio tracks except the 7.1 DTS HD track from your movie - I bet it doesn't play at all (none of mine do), which obviously is not great. Or maybe I am reading the log wrong and the 7.1 hd track is playing. I don't know. I want to see HD Audio support on the Shield app very badly (and I believe it will come). But given, I bet, that the Shield app user base is likely much smaller than probably any other app user base, and, as you say, there seems to just be Luke and ebr (for the most part), I understand why it may not be a priority them (as disappointing as this is to me). Plus, need to keep in mind, the app isn't using a custom built video player - not sure if it is still the case, but at one point the player being used did not even support HD audio pass-through - in which case there is nothing ebr or Luke can do. Short of changing to a supported player, which probably opens up a whole lot of other complexities/work. I'm done with this, and have switched to Plex at home. Family members are still using Emby for now, but it just makes zero sense for me to keep dicking with this.
Luke 42244 Posted December 7, 2016 Posted December 7, 2016 The latest beta version of the Emby app offers all the HD Audio pass-through you need. Check out the beta thread for more details: https://emby.media/community/index.php?/topic/42239-android-tv-beta-13x/ We think you'll enjoy the next update to the stable channel. Thanks !
