moddie 2 Posted August 25, 2016 Posted August 25, 2016 The Open option has been removed. You can just click on the poster. acknowleged otherwise, thanks and keep up the great work
BinaryShrub 3 Posted August 25, 2016 Posted August 25, 2016 It works for me now, verified a few different series' Thanks! 1
bozrdnag 75 Posted August 27, 2016 Author Posted August 27, 2016 It works for me in both the Beta and Stable versions. Larger series still have a slight delay (5 seconds for 18 seasons) but no where near what I previously getting. I would love to see it basically instantaneous but this good enough for me to consider it fixed. Thanks so much!
iBoss 31 Posted August 28, 2016 Posted August 28, 2016 Many Thanks Luke. Great job Version 3.1.126.0 15 seconds to load all seasons (17 seasons 740 eps) Do you need any log?
Fieperskaivu 1 Posted September 1, 2016 Posted September 1, 2016 This will be fixed in Emby Server beta 3.1.121, along with the next stable release. Hi, is 3.0.6400 the stable release you were referring to or is it still forthcoming? I am still having this issue, if it's going to be a while I'll try the beta otherwise I'm fine waiting for now. Thanks for all your work.
Luke 42287 Posted September 1, 2016 Posted September 1, 2016 Yes, 3.0.6400 and/or the latest beta. If you're still seeing an issue, please provide the information requested in how to report a problem. Thanks!
pr3dict 33 Posted October 13, 2016 Posted October 13, 2016 How do I delete my like database so that emby relooks for stuff? I have the TV series library pointed to \Myserver\mediaserver\TV Shows\ The only folder that is next is \TV\ Then its \Series\Season\Tvshow.file For some reason Emby thinks that \TV\ is a series and is making everything after that a part of that series and now showing any of them in the emby library. BUT the metadata manager does see all of folders that are supposed to be there so IDK what the issue is.
Luke 42287 Posted October 13, 2016 Posted October 13, 2016 You should add \Myserver\mediaserver\TV Shows\TV as your TV library.
pr3dict 33 Posted October 13, 2016 Posted October 13, 2016 You should add \Myserver\mediaserver\TV Shows\TV as your TV library. Ok done. The shows are there but all the meta data keeps coming in wrong. I don't even have a show called revelations.
twos50 9 Posted October 13, 2016 Posted October 13, 2016 (edited) Im having a very similar issue as well since upgrading to 3.0.8000.0. All of my shows are showing up under that generic "Catfish" show heading. However all the metadata for all of my tv shows shows up in the metadata report. It behaves exactly like pr3dict describe it. There was never an issue with how my library was structured before installing the latest 3.0.8000.0 update. So if we have to change it then something was changed with how the server interprets where the shows are located. Edited October 13, 2016 by twos50
pr3dict 33 Posted October 13, 2016 Posted October 13, 2016 Im having a very similar issue as well since upgrading to 3.0.8000.0. All of my shows are showing up under that generic "Catfish" show heading. However all the metadata for all of my tv shows shows up in the metadata report. It behaves exactly like pr3dict describe it. There was never an issue with how my library was structured before installing the latest 3.0.8000.0 update. So if we have to change it then something was changed with how the server interprets where the shows are located. I'm re "indentifiying" all of the shows now in the metadata manager and it seems to be fixing it but I am going 1 by 1 to every show.
twos50 9 Posted October 13, 2016 Posted October 13, 2016 (edited) My parent TV directory structure is as follows: \\mysever\TV Recordings\recordings\TV\..... Is this how it's not suppose to be?? If so then we need a better explanation and not just some tedious workaround especially if someone has 1000+ TV shows. I've tried re-scanning, but "re-identiying" is not a viable option. Edited October 13, 2016 by twos50
Luke 42287 Posted October 13, 2016 Posted October 13, 2016 My parent TV directory structure is as follows: \\mysever\TV Recordings\recordings\TV\..... Is this how it's not suppose to be?? If so then we need a better explanation and not just some tedious workaround especially if someone has 1000+ TV shows. I've tried re-scanning, but "re-identiying" is not a viable option. Looks like it should be fine. S oyou added \\mysever\TV Recordings\recordings\TV with content type TV? Can we see a screenshot of the contents of that folder? thanks.
diaz1510 154 Posted October 13, 2016 Posted October 13, 2016 Ahh looks like another person with this issue since upgrading to 3.0.8000 Check out: https://emby.media/community/index.php?/topic/40195-all-tv-shows-only-in-1-folder/ https://emby.media/community/index.php?/topic/40192-308000-library-issue/ I still haven't gotten this to work....emby has pretty much become unusable right now...I just want to go back to the previous build, lol...
twos50 9 Posted October 13, 2016 Posted October 13, 2016 removing the tvshow.nfo file from the parent TV directory worked for me. Here is the link: https://emby.media/community/index.php?/topic/40195-all-tv-shows-only-in-1-folder/
Luke 42287 Posted October 13, 2016 Posted October 13, 2016 That DID NOT work for me.... I think your issue is that you flipped the content type and now you can't flip it back based on what i said earlier. We'll have the content type selection restored for the next release.
diaz1510 154 Posted October 13, 2016 Posted October 13, 2016 I think you a re right....that was my mistake for that. How soon can we expect this release? I can't even really use emby right now, nor can any of my users, as it's so jumbled up...
Luke 42287 Posted October 13, 2016 Posted October 13, 2016 I think you a re right....that was my mistake for that. How soon can we expect this release? I can't even really use emby right now, nor can any of my users, as it's so jumbled up... Can we please limit communication to the thread you opened? It is not necessary to post the same responses in three topics. Thanks.
