Fnordje 3 Posted June 10, 2016 Posted June 10, 2016 (edited) To the person who couldn't get to play certain files due to missing libmp3lame: apt-get install libmp3lame-dev cd /usr/src/ffmpeg ./configure --enable-libmp3lame make make install apt-get remove libmp3lame-dev # optional One may also want to clean /usr/src/ffmpeg from their system Also, I got some questions. What packages have people been able to purge from their system and still keep Emby working? I got all kind of shit on my system. Not a whole X Window System but just generally all kind of packages. If I remove them, its trying to remove Mono (and Emby) as well. Furthermore, will this be automatically utilized when I compile this support in: --enable-omx-rpi enable encoding via OpenMAX IL for Raspberry Pi [no] And, I think the guide should include the above I wrote about libmp3lame. Which other dependancies should we recommend? Last but not least perhaps we could just build a .deb package and distribute that instead? When overwriting it to /usr we can just use a newer version that the current ffmpeg. Although I don't even have ffmpeg installed via .deb on my current system My final options were: apt-get install libmp3lame-dev libomxil-bellagio-dev ./configure --arch=armel --target-os=linux --enable-gpl --enable-libx264 --enable-libmp3lame --enable-omx-rpi --disable-debug --enable-version3 --enable-nonfree make -j4 # compiled ffmpeg in 28m3s make # compiled ffmpeg in 59m13s Edited June 10, 2016 by Fnordje
Fnordje 3 Posted June 10, 2016 Posted June 10, 2016 What kind of output do people use for the RPi? Are you using Kodi with X on the Pi itself? Chromecast?
wisepass 0 Posted June 11, 2016 Posted June 11, 2016 Server-side everything looks normal. I would ensure you're using an up to date browser. Firefox 35 should be fine, but i haven't tested it lately so it's always possible an issue has crept up on us. You were right! Strangly Firefox 35 would not load the wizard but was working fine on my (older) version of windows Emby. I used IE 11 to set the wizard then strangely Firefox 35 worked fine from there onward. Yet more strange is the newest version of Chrome didn't work at all. The setup wasn't as complex as I first thought it was just complicated by which browser I used. Now it's all setup on a Pi 3 and it works great as part setup with Kodi and Native paths - since there's no transcoding there's no performance issues at all even with a pretty huge library I have. Thanks for the help Luke - I assumed it was the Pi setup and would have been stuck
Luke 42245 Posted June 12, 2016 Author Posted June 12, 2016 i think something else must be at play because i can't imagine there would be an issue with the newest version of Chrome. Thanks for the report though.
Fnordje 3 Posted June 14, 2016 Posted June 14, 2016 emby 25225 11.9 60.6 718420 604816 ? Ssl 14:37 9:16 /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh Is it normal Mono is using 605 MB of memory? That's 62% of all memory. Its also slowly increasing. Now it is already at 64,8% / 650 MB.
Fnordje 3 Posted June 15, 2016 Posted June 15, 2016 (edited) Webbrowsers can only play MP4 with H264 video and AAC stereo audio you need to convert your files or use a client (like MB Theater) and setup (SMB) sharing Is this a bug? Is this being looked into? Emby for Android also doesn't seem to be able to deal with MKV. Edited June 15, 2016 by Fnordje
Luke 42245 Posted June 15, 2016 Author Posted June 15, 2016 Is this a bug? Is this being looked into? Emby for Android also doesn't seem to be able to deal with MKV. Emby for Android direct plays most mkv's, no problem. If you're having an issue, please see how to report a media playback issue. Thanks!
Fnordje 3 Posted June 15, 2016 Posted June 15, 2016 Emby for Android direct plays most mkv's, no problem. If you're having an issue, please see how to report a media playback issue. Thanks! Digged through logs and figured my error was: [h264_qsv @ 00000000027147a0] Error initializing an internal MFX session, I googled around and from ffmpeg it seemed related to Intel Quick Sync so I disabled that. So sorry for the false alarm. 1
Raspi2 Server 0 Posted June 17, 2016 Posted June 17, 2016 I just reinstalled Emby on a fresh install of Raspbian Jessie and it all works fine. I used the original guide on page 8 of this thread. Android phones/tablets and Chromecast all work. Even the browser interface on Firefox 47.0 works perfect. I plan to purchase the lifetime license so that I can stream to all my devices. Time and money well spent. Thanks everyone!
Evlo 1 Posted July 5, 2016 Posted July 5, 2016 (edited) I tried that guide too, everything seemed to work, but then error. I tried it on raspbian lite not full raspbian with gui etc. I wonder if i did something wrong or if the issues is in mono, as there are weir lines like Use of uninitialized value $_ in scalar chomp at /usr/share/cli-common/runtimes.d/mono line 275. But i'm total linux, apt, debian and even rPI noob. Full log: pi@raspberrypi:~ $ sudo apt-get install emby-server Reading package lists... Done Building dependency tree Reading state information... Done emby-server is already the newest version. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 10 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Do you want to continue? [Y/n] Setting up libnunit-core-interfaces2.6.3-cil (2.6.3+dfsg-1) ... Y* Installing 1 assembly from libnunit-core-interfaces2.6.3-cil into Mono Illegal instruction Use of uninitialized value $_ in scalar chomp at /usr/share/cli-common/runtimes.d/mono line 275. Use of uninitialized value $fullname in concatenation (.) or string at /usr/share/cli-common/runtimes.d/mono line 225. Illegal instruction E: installing Assembly /usr/lib/cli/nunit.core.interfaces-2.6.3/nunit.core.interfaces.dll failed E: Installation of libnunit-core-interfaces2.6.3-cil with /usr/share/cli-common/runtimes.d/mono failed dpkg: error processing package libnunit-core-interfaces2.6.3-cil (--configure): subprocess installed post-installation script returned error exit status 132 dpkg: dependency problems prevent configuration of libnunit-core2.6.3-cil: libnunit-core2.6.3-cil depends on libnunit-core-interfaces2.6.3-cil; however: Package libnunit-core-interfaces2.6.3-cil is not configured yet. dpkg: error processing package libnunit-core2.6.3-cil (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libnunit-util2.6.3-cil: libnunit-util2.6.3-cil depends on libnunit-core-interfaces2.6.3-cil; however: Package libnunit-core-interfaces2.6.3-cil is not configured yet. libnunit-util2.6.3-cil depends on libnunit-core2.6.3-cil; however: Package libnunit-core2.6.3-cil is not configured yet. dpkg: error processing package libnunit-util2.6.3-cil (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libnunit-console-runner2.6.3-cil: libnunit-console-runner2.6.3-cil depends on libnunit-core-interfaces2.6.3-cil; however: Package libnunit-core-interfaces2.6.3-cil is not configured yet. libnunit-console-runner2.6.3-cil depends on libnunit-core2.6.3-cil; however: Package libnunit-core2.6.3-cil is not configured yet. libnunit-console-runner2.6.3-cil depends on libnunit-util2.6.3-cil; however: Package libnunit-util2.6.3-cil is not configured yet. dpkg: error processing package libnunit-console-runner2.6.3-cil (--configure): dependency problems - leaving unconfigured Setting up libnunit-framework2.6.3-cil (2.6.3+dfsg-1) ... * Installing 1 assembly from libnunit-framework2.6.3-cil into Mono Illegal instruction Use of uninitialized value $_ in scalar chomp at /usr/share/cli-common/runtimes.d/mono line 275. Use of uninitialized value $fullname in concatenation (.) or string at /usr/share/cli-common/runtimes.d/mono line 225. Illegal instruction E: installing Assembly /usr/lib/cli/nunit.framework-2.6.3/nunit.framework.dll failed E: Installation of libnunit-framework2.6.3-cil with /usr/share/cli-common/runtimes.d/mono failed dpkg: error processing package libnunit-framework2.6.3-cil (--configure): subprocess installed post-installation script returned error exit status 132 dpkg: dependency problems prevent configuration of libnunit-mocks2.6.3-cil: libnunit-mocks2.6.3-cil depends on libnunit-framework2.6.3-cil; however: Package libnunit-framework2.6.3-cil is not configured yet. dpkg: error processing package libnunit-mocks2.6.3-cil (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libnunit-cil-dev: libnunit-cil-dev depends on libnunit-console-runner2.6.3-cil (= 2.6.3+dfsg-1); however: Package libnunit-console-runner2.6.3-cil is not configured yet. libnunit-cil-dev depends on libnunit-core2.6.3-cil (= 2.6.3+dfsg-1); however: Package libnunit-core2.6.3-cil is not configured yet. libnunit-cil-dev depends on libnunit-core-interfaces2.6.3-cil (= 2.6.3+dfsg-1); however: Package libnunit-core-interfaces2.6.3-cil is not configured yet. libnunit-cil-dev depends on libnunit-framework2.6.3-cil (= 2.6.3+dfsg-1); however: Package libnunit-framework2.6.3-cil is not configured yet. libnunit-cil-dev depends on libnunit-mocks2.6.3-cil (= 2.6.3+dfsg-1); however: Package libnunit-mocks2.6.3-cil is not configured yet. libnunit-cil-dev depends on libnunit-util2.6.3-cil (= 2.6.3+dfsg-1); however: Package libnunit-util2.6.3-cil is not configured yet. dpkg: error processing package libnunit-cil-dev (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libmono-cil-dev: libmono-cil-dev depends on libnunit-cil-dev (>= 2.4); however: Package libnunit-cil-dev is not configured yet. dpkg: error processing package libmono-cil-dev (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of mono-devel: mono-devel depends on libmono-cil-dev (= 4.2.1.102-0xamarin1); however: Package libmono-cil-dev is not configured yet. dpkg: error processing package mono-devel (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of emby-server: emby-server depends on mono-devel (>= 1.0); however: Package mono-devel is not configured yet. dpkg: error processing package emby-server (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: libnunit-core-interfaces2.6.3-cil libnunit-core2.6.3-cil libnunit-util2.6.3-cil libnunit-console-runner2.6.3-cil libnunit-framework2.6.3-cil libnunit-mocks2.6.3-cil libnunit-cil-dev libmono-cil-dev mono-devel emby-server E: Sub-process /usr/bin/dpkg returned an error code (1) EDIT: oh, i see now http://emby.media/community/index.php?/topic/27793-errors-while-installing-on-rasbianjessie/ . So i guess rPI1 is not usefull at all anymore Edited July 5, 2016 by Evlo
Fnordje 3 Posted November 3, 2016 Posted November 3, 2016 Hey guys, We have an experimental deployment for Emby Server on Raspberry Pi. Please try it out and report your results. Raspberry Pi Instructions: wget -qO - http://download.opensuse.org/repositories/home:emby/xUbuntu_14.04/Release.key | sudo apt-key add - sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ /' >> /etc/apt/sources.list.d/emby-server.list" sudo apt-get update sudo apt-get install mono-runtime mediainfo libsqlite3-dev imagemagick-6.q8 libmagickwand-6.q8-2 libmagickcore-6.q8-2 sudo apt-get install emby-server If Running Raspbian: Please enter the following commands: echo "deb-armhf http://ports.ubuntu.com/ trusty main restricted universe multiverse" > /etc/apt/sources.list.d/trusty.list Followed by: cat << EOF | sudo tee -a /etc/apt/prefereces.d/trusty.pref Package: * Pin: release a=trusty Pin-Priority: 10 EOF You're missing an 'n' in 'preferences'. Spellchecker caught it as well whilst I was quoting you. As for the ports.ubuntu.com line. I got that part working by removing '-armhf'
Luke 42245 Posted December 20, 2016 Author Posted December 20, 2016 Raspberry Pi fans might also enjoy trying Emby Theater: https://emby.media/community/index.php?/topic/42760-emby-theater-on-raspberry-pi/ Enjoy.
Strudo76 7 Posted January 22, 2017 Posted January 22, 2017 Hope this is the right place for this? I have just purchased a Raspberry Pi 3, and I'm not a Linux user by any means, but I know how to get around an operating system. I have installed the Emby server on my Pi 3 using the instructions ARM devices official instructions as the instructions at Emby Server for Linux gave me errors. Just thought I'd mention that, since the latter seems to be the more accessible of the two. The instructions I used then indicate I should install ffmpeg, and the link provided here contains links for static builds, but the page also mentions it's highly recommended to use Git builds. I have only a limited idea as to what this means, and no idea how, or if I should, do that. Any chance someone could explain the advantage of using the Git builds, and how I'd go about setting that up in regards to the Emby server installation. Or would the static builds be sufficient. I am using SSH to connect to the Pi, so terminal access is readily available. I have also done some searching and found some instructions here regarding Git installation. Do these instructions make sense and can they be used for a Emby server installation? Regards, Simon
Luke 42245 Posted January 22, 2017 Author Posted January 22, 2017 Hi, the static builds are the static git builds available for download at the top of the page, so they're the same thing. does that help?
Strudo76 7 Posted January 22, 2017 Posted January 22, 2017 Hi, the static builds are the static git builds available for download at the top of the page, so they're the same thing. does that help? I assumed they'd be generally up to date. I just wasn't sure if building from Git would be easier to keep things updated, or if the statics are generally sufficient. I guess they are good until something crops up that causes an issue, then get new ones. If using the static builds, do I just put them in a folder and point the wizard there? I had a quick look at the wizard page, but didn't give it a proper read as I'm just playing and trying things out at the moment. Thanks for the quick reply too. Appreciate it!
obieq 0 Posted January 23, 2017 Posted January 23, 2017 (edited) Please, look at screen is it normal ? I have some problem desrcibed here I am not sure if it is connected with emby or not https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=171122 Edited January 23, 2017 by obieq
Luke 42245 Posted January 23, 2017 Author Posted January 23, 2017 Hi @@obieq, can you please attach the complete emby server log, as well as discuss the Emby issues you are having? thanks.
hurricanehrndz 149 Posted January 23, 2017 Posted January 23, 2017 In the default conf there is information about tweaking mono's memory footprint Sent from my ONEPLUS A3000 using Tapatalk
obieq 0 Posted January 23, 2017 Posted January 23, 2017 I am not sure this will be correct log corresponding excaly screenshot issues because I have tried few times copying file but you can check that something is wrong. http://pastebin.com/CfK2iBDU Its shortcuted due to looped Library monitor
Luke 42245 Posted January 23, 2017 Author Posted January 23, 2017 It's only a 3-minute log. is there any more? try disabling the realtime monitor.
obieq 0 Posted January 23, 2017 Posted January 23, 2017 http://www5.zippyshare.com/v/8rNwWQOD/file.html password: obieqEmby 6 log files
hurricanehrndz 149 Posted January 23, 2017 Posted January 23, 2017 @@Luke can we please lock this thread and refer everyone to the ARM sticky.
Luke 42245 Posted January 24, 2017 Author Posted January 24, 2017 For instructions on Emby Server for Raspberry Pi, please see here: https://emby.media/community/index.php?/topic/43166-arm-devices-official-instructions/ If you have any questions or issues, please open a new topic. Thanks !
