MongooseMan 31 Posted September 25, 2015 Posted September 25, 2015 (edited) Latest version installed by IP, and working fine on UA50HU7000 Country: South Africa TV software version: 1037 (I think, not sure where to find another number?) Edited September 25, 2015 by MongooseMan
CBers 7554 Posted September 25, 2015 Author Posted September 25, 2015 There's a new BETA version updated by @ available here.
fluffykiwi 50 Posted September 25, 2015 Posted September 25, 2015 (edited) Installed via hub / ip since v0.580 Current v0.592. UK UE55HU8500 Firmware Version 1270 Would Prefer 1080p version if possible. Current Issues Undefined error within genre option Spelling error within Show Larger Icons: across. Love this app. Edited September 26, 2015 by fluffykiwi 1
FrostByte 5453 Posted September 25, 2015 Posted September 25, 2015 Current Issues Recent Apps Icon still old blue version. Green icon correct within app and in featured apps. Try shutting down and powering back up. That fixed the icon for others
fluffykiwi 50 Posted September 25, 2015 Posted September 25, 2015 (edited) Switch off and on changed icon in featured apps view, but not within recent apps bar where I'd pinned the app. Update: simply had to delete pinned app from recent app bar, restart tv, then load Emby. Could then repin new icon within recent apps bar. Thanks for the help. Recent update to samsung tv firmware 1270 did make all these recent app icons huge and I wish there was a way to revert to older style. Edited September 26, 2015 by fluffykiwi 1
sh0rty 727 Posted September 26, 2015 Posted September 26, 2015 Recent update to samsung tv firmware 1270 did make all these recent app icons huge and I wish there was a way to revert to older style. No chance m8. But I also hate the new design... 1
cmcg 876 Posted September 26, 2015 Posted September 26, 2015 @@fluffykiwi do subtitles display ok for you with version 0.592?
mitelman 3 Posted September 26, 2015 Posted September 26, 2015 (edited) UN50H5203 Canada Firmware 1125 Cannot use IP method. Sideload of the app works once until the TV is powered off. Need to replug the USB for the app to be seen again. Edited September 26, 2015 by mitelman
cmcg 876 Posted September 27, 2015 Posted September 27, 2015 @@fluffykiwi Undefined error within genre optionSpelling error within Show Larger Icons: across. Both fixed. Will be in 0.593. Many thanks. 1
fluffykiwi 50 Posted September 27, 2015 Posted September 27, 2015 (edited) Subtitles seem alright, although I have very few to test. Dawn of the planet of the apes 3d version definitely working for ape bits. I'll grab some more subtitles for films and test more. Edit Subtitles seem fine here. Edited September 29, 2015 by fluffykiwi
gogreenpower 26 Posted September 30, 2015 Posted September 30, 2015 UA60H7000, FW:2141, Australia 0.593b installed from the internet and player/subtitles work as expected. Keep up the good work. Green. 2
rblackhaw 3 Posted October 2, 2015 Posted October 2, 2015 UN60H6350, FW 2138, US 0.590 installed from IP. Anytime I have installed this app, I have to unplug TV for a few seconds before it will load but works fine after. When I get a chance I'll try to install beta. 1
FrostByte 5453 Posted October 2, 2015 Posted October 2, 2015 I don't think anyone who was having problems installing the app from IP has responded yet. Not sure they are still having the issue, but I can go back and find their posts if needed.
syran 10 Posted October 3, 2015 Posted October 3, 2015 Installed and working on UE40H5500 The only issue is that I have to enable AAC transcoding to Dolby Digital or media with AAC audio doesn't play at all Same goes for version 0.590 stable
Spaceboy 2573 Posted October 3, 2015 Posted October 3, 2015 (edited) firmware 1040 and in the uk, now on 0.593f Edited October 3, 2015 by Spaceboy
Xzener 729 Posted October 4, 2015 Posted October 4, 2015 Not working on my UN40H5203AF. The app installs, but when launched, I get the Embry loading screen for a minute or so... Then nothing, goes back to previously channel watched.
cmcg 876 Posted October 4, 2015 Posted October 4, 2015 Hi @@Xzener Perhaps you'd like to try the latest beta (v0.593i)? It doesn't sound like it could be much worse! 1
Xzener 729 Posted October 4, 2015 Posted October 4, 2015 Brilliant work @@cmcg, the app is loading now. Although playback is a bit jerky. My collection consists of DVDs and Blurays converted to MKV. Are these directly playing? I'd probably have better results on a wired network.
cmcg 876 Posted October 5, 2015 Posted October 5, 2015 Since the TV can not access a Windows share the server creates a stream, which is the next best thing. The file is still sent to the TV in its current format as long as the TV supports is, otherwise it is transcoded. Hence you only ever see either Direct Streaming or Transcoding but never Direct Playing. I'd recommend wired Ethernet. All apps, not just Emby, are improved for me by wired networking. Your milage may vary of course.
socalredneck 11 Posted October 9, 2015 Posted October 9, 2015 Sorry, I haven't checked back for a while. I have two tv's in the US that won't load via IP, and only load via USB, they are: UN32H5203AFXZA - f/w 1125 UN50H6201AFXZA - f/w 1126
FrostByte 5453 Posted October 9, 2015 Posted October 9, 2015 Sorry, I haven't checked back for a while. I have two tv's in the US that won't load via IP, and only load via USB, they are: UN32H5203AFXZA - f/w 1125 UN50H6201AFXZA - f/w 1126 Is that still true with the latest beta 593m?
cmcg 876 Posted October 9, 2015 Posted October 9, 2015 I imagine so. I think it blocked in firmware isn't it?
FrostByte 5453 Posted October 9, 2015 Posted October 9, 2015 Yes, I believe he said in the other thread that it stopped installing after a firmware update from Samsung and that it would remove the old version and never finish the install process for the new version. Just sort of hoping since you made some minor fixes for H users recently that something in the SDK was fixed on Samsung's side
socalredneck 11 Posted October 10, 2015 Posted October 10, 2015 Yes, I've tried the 0.593m, but no change.
cmcg 876 Posted October 10, 2015 Posted October 10, 2015 Yup. Samsung locked it down (or broke it). Annoying. Are you ok with the USB method?
