hsran 0 Posted March 8, 2018 Posted March 8, 2018 @@hsran, please log into your emby server dashboard. Is the remote address displayed here the same one that you used when manually entering the static ip and port? Thanks. Yes the remote WAN has the same ip:port.
Luke 42243 Posted March 8, 2018 Posted March 8, 2018 In your emby server dashboard, does your user have a cloud icon showing?
hsran 0 Posted March 8, 2018 Posted March 8, 2018 (edited) In your emby server dashboard, does your user have a cloud icon showing? Yes and I can see the server after logging into my Emby Connect account. edit: Re-installing Emby server sorted it out. Cheers! Edited March 10, 2018 by hsran
computerprep 149 Posted March 30, 2018 Posted March 30, 2018 Would it be possible to add a refresh button to the Android app on the Home page? Like a page pull refresh? @@Luke, you said you like this idea last year... any updates? Should we start a new feature request thread for this?
computerprep 149 Posted March 30, 2018 Posted March 30, 2018 @@jh3ss3000, show your support over here. https://emby.media/community/index.php?/topic/57556-pull-down-refresh-behavior-in-android-mobile-app/
Luke 42243 Posted July 6, 2018 Posted July 6, 2018 2.9.96: https://emby.media/community/index.php?/topic/60521-emby-for-android-2996/
grizlyadams 19 Posted August 8, 2018 Posted August 8, 2018 (edited) Can anyone explain this ? I was wondering why it was taking over 4days to download one episode.... seems it was downloading one episode 5 times and it's not done yet. [emoji15] Sent from my ONEPLUS A6003 using Tapatalk Edited August 8, 2018 by grizlyadams
Luke 42243 Posted August 8, 2018 Posted August 8, 2018 There probably was a failure during the download. There are still some improvements we need to make in responding to this better with large downloads. Thanks.
grizlyadams 19 Posted August 12, 2018 Posted August 12, 2018 I had about 20 TV episodes from different series set to download...after the mess with the first one above, the Emby-offline Android client appears to have decided it's had enough and hasn't downloaded anything after that..... Sent from my ONEPLUS A6003 using Tapatalk
Luke 42243 Posted August 13, 2018 Posted August 13, 2018 This topic has grown to a point where it's not an efficient place for troubleshooting anymore. Please see how to report a problem we'll be happy to help. Thanks ! 1
grizlyadams 19 Posted August 13, 2018 Posted August 13, 2018 This topic has grown to a point where it's not an efficient place for troubleshooting anymore. Please see how to report a problem we'll be happy to help. Thanks !Sorry, not really here to spend a load of time collating logs and time frames. I'm travelling and am having problems with the app - I'm not going to schedule some time when I get back to recreate the problem so I can accurately figure the time frame. Nor am I trying to raise a fault ticket that needs answering. Maybe if the app was free I'd find the time to do that - given your first response, I'm just reporting what's happening for info. Sent from my ONEPLUS A6003 using Tapatalk 1
grizlyadams 19 Posted September 6, 2018 Posted September 6, 2018 So, trying again to download in the android app (glutton for punishment but hoping something has been done to make downloads better.) I tentatively set 4 episodes to download... was going well, there was a progress bar in the notification area indicating the progress of 3 of the downloads. I'm sitting in the same seat, neither the phone or me have moved, the WiFi signal is 100%. Each download got about half way thru and the progress indicator in the notification area disappeared. I looked at the downloads in the app - only 1 downloading and is at 0% !!!!!!! Then 10 minutes later the progress bar appears again the the notification area again . Please, can we just have a download now button. As in, right now, high priority, with progress bar. Not in the background at some point with no control. Remove the intelligence and make it simple and manual? 4
Luke 42243 Posted September 7, 2018 Posted September 7, 2018 We are working on improving the download feature, thanks.
grizlyadams 19 Posted September 10, 2018 Posted September 10, 2018 We are working on improving the download feature, thanks.Any kind of ETA ?
s7relok 1 Posted November 6, 2018 Posted November 6, 2018 Music sync is broken again. Checked server, checked phone, authorizations, nor the download nor sync option works. I now have a nice empty (i deleted the already synced musics thinking it was the problem) music folder for my travels, well... Still have space on phone (14Gb in internal memory, I don't think my about 40 songs to sync takes such place) Things changed, I can't even have the choice where in the internal space i want to download my files. No logs in com.mb android folder, logs on the server, I saw nothing about sync error. I'm on 4G so enough bandwith (speedtest gives me about 30Mb). Tried to launch manually by clicking on convert media planned task, but nothing on the phone and the download status stays on "ready for transfer (SO DL IF IT'S READY FFS)" And it all begins by a track that I want to synchronize with the already existent ones. This is not the 1st time since I use emby and i'm beginning to be pissed of to monthly pay for an option that does not work...
Luke 42243 Posted November 6, 2018 Posted November 6, 2018 Please try again with the next update to the app. Thanks.
s7relok 1 Posted November 6, 2018 Posted November 6, 2018 Please try again with the next update to the app. Thanks. And there's no workaround? (instead of manually grab the files and copying them myself?)
s7relok 1 Posted November 6, 2018 Posted November 6, 2018 (edited) And there's no workaround? (instead of manually grab the files and copying them myself?) Found one. Downgraded to a working version (august one) It downloads...to the android/data/com.mb.android folder... without choice to a custom path. So my default phone player can't reach the files, as VLC.... Finally found the option to have a custom path. It's transfering. Edited November 6, 2018 by s7relok
Gamblec673 0 Posted February 14, 2020 Posted February 14, 2020 It's the first one to see some app for the new stuff.
elpoolet 26 Posted March 18, 2020 Posted March 18, 2020 Hi the EmbyTeam It seems the App isn't available for all countries. I live in Guadeloupe, a French Territory in the Carribean, but the PlayStore tells me that the "article isn't availabble in my country". Please, can you publish the app for all countries without restrictions ? Many Thanks
Luke 42243 Posted March 18, 2020 Posted March 18, 2020 I thought we had already but we'll take a look. The apks are also available on our website.
homelabsol 0 Posted April 30, 2020 Posted April 30, 2020 Can anyone help me on my problem. I have been posting my incident since yesterday, however, no one is attending to it. Can u please help me?? https://emby.media/community/index.php?/topic/85735-unable-to-connect-to-emby-server-using-android-and-ios-devices/.
Luke 42243 Posted April 30, 2020 Posted April 30, 2020 Can anyone help me on my problem. I have been posting my incident since yesterday, however, no one is attending to it. Can u please help me?? https://emby.media/community/index.php?/topic/85735-unable-to-connect-to-emby-server-using-android-and-ios-devices/. Hi, yes we will respond to you in your topic. Thanks.
Guest Posted August 12, 2020 Posted August 12, 2020 Is there a wake on lan option for Emby? Read there is on android mobile but I see no option when selecting server
