js28194 41 Posted March 4 Posted March 4 Do you know how to attach the file? Specifically the EmbyServer.txt file? I am assuming you do since you know how to use a puter to take a screen shot. It's the big "Drag Files here to attach" right below where you are posting. I'm not sure why you haven't so far. See the screen shot below.
Zenith Media 8 Posted March 4 Author Posted March 4 I sent the screen shot of the files within the log folder because I don't know which one to attach. I appreciate the help, but sarcasm is not needed. As you can see on the screenshot I've attached there is not a specific file labeled "EmbyServer.txt".
js28194 41 Posted March 4 Posted March 4 Hi yes, it's the very top file. You do not display file extensions so in your case it's just called "embyserver"
Lessaj 484 Posted March 4 Posted March 4 Try deleting the ACdb plugin and then start the server. C:\Users\jason\AppData\Roaming\Emby-Server\programdata\plugins\ACdb.dll
Zenith Media 8 Posted March 4 Author Posted March 4 It is still not working after deleting both of the ACdb.dll files.
Luke 42208 Posted March 5 Posted March 5 5 hours ago, Zenith Media said: There is no new log. If you restarted the server then there would be a new log file. Are you sure that you did that?
Zenith Media 8 Posted March 5 Author Posted March 5 Yes. I can not login to emby, I restarted it from the hidden icons area of the pc.
Zenith Media 8 Posted March 5 Author Posted March 5 When I try to open a browser with emby, it shows up the same as the screenshots that I posted originally.
Luke 42208 Posted March 5 Posted March 5 2 minutes ago, Zenith Media said: Yes. I can not login to emby, I restarted it from the hidden icons area of the pc. What exactly happens when you try?
Luke 42208 Posted March 5 Posted March 5 6 minutes ago, Zenith Media said: Right and I asked you a question earlier, which of those 4 bullet point options do you intend to proceed with? For example, try clicking the link in the first one.
Apotropaic 51 Posted March 5 Posted March 5 56 minutes ago, Zenith Media said: Yes. I can not login to emby, I restarted it from the hidden icons area of the pc. I’m assuming you are on a windows machine and you’re talking about the taskbar icon in the bottom right hand side… What happens when you right select on the emby server icon like you did when you rebooted the server but select ‘Configure Emby’ instead? This should open up a browser using the local host and the configured Emby port. If this doesn’t open then there’s potentially something seriously wrong with your local firewall or anti-malware software. There was also a windows update back in October 2025 (KB5066835) that caused some local host issues for HTTP/2
Zenith Media 8 Posted March 5 Author Posted March 5 Yes, correct. I did that and it still came up with errors. Went into the firewall and un-selected emby saved. Went back in and selected emby. Nothing has changed. My Plex server is working fine.
Neminem 1605 Posted March 5 Posted March 5 Did you network change from privat to public? It needs to be set to privat. 1
ebr 16310 Posted March 5 Posted March 5 7 hours ago, Apotropaic said: right select on the emby server icon like you did when you rebooted the server but select ‘Configure Emby’ instead? Please show us exactly what happens when you do this.
Neminem 1605 Posted March 5 Posted March 5 17 minutes ago, Zenith Media said: It is not showing anymore. Does that mean you fixed it
Neminem 1605 Posted March 5 Posted March 5 Do you see the Emby-server running in task manager? Is those screenshots from you localhost / pc / server? Where you open browser and type in http://localhost:8096
