Luke 42234 Posted June 19, 2018 Author Posted June 19, 2018 well for starters, can you manually update to the latest emby server beta? (unless you don't want to use beta releases).
adrianwi 279 Posted June 19, 2018 Posted June 19, 2018 I'll hold fire on the beta releases for now, but thanks
makarai 109 Posted June 21, 2018 Posted June 21, 2018 In the meantime i updated to 5.10, so far no problems. However the securechannel bug still seems to be present. I can upload a logfile if it is still necessary Log.txt
Luke 42234 Posted June 21, 2018 Author Posted June 21, 2018 I think the answer to that is there will be some configuration required to the mono environment. Just don't know what yet.
makarai 109 Posted June 21, 2018 Posted June 21, 2018 (edited) I think the answer to that is there will be some configuration required to the mono environment. Just don't know what yet. Super fast reply thanks! i just finished updating my beta server to the latest release (.14 to .17) to check if there was a change. Since you are apparently awak, do you have an idea what the reason is that i get all these mono issues with the fstab mounted folders? Log17.txt Edited June 21, 2018 by makarai
makarai 109 Posted June 21, 2018 Posted June 21, 2018 What issues? its not really an issue it just bugs me, i get this error message 2018-06-21 08:59:34.950 Info HttpClient: HttpClientManager GET: https://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog 2018-06-21 08:59:35.005 Error LibraryMonitor: Error in Directory watcher for: /multimedia01/movies *** Error Report *** Version: 3.4.1.16 Command line: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -os freebsd -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 11.1.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.47 (5.10.1.47 Tue Jun 19 22:44:14 UTC 2018) Processor count: 8 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server System.IO.IOException: persistent kevent() error, error code = '0' at System.IO.KqueueMonitor.Monitor () [0x00121] in <e3522e62e36242f6a6fa346cea2d7450>:0 at System.IO.KqueueMonitor.DoMonitor () [0x0003f] in <e3522e62e36242f6a6fa346cea2d7450>:0 System.IO.IOException at System.IO.KqueueMonitor.Monitor () [0x00121] in <e3522e62e36242f6a6fa346cea2d7450>:0 at System.IO.KqueueMonitor.DoMonitor () [0x0003f] in <e3522e62e36242f6a6fa346cea2d7450>:0
Luke 42234 Posted June 21, 2018 Author Posted June 21, 2018 Turn off the real-time monitor for your libraries.
makarai 109 Posted June 22, 2018 Posted June 22, 2018 (edited) Turn off the real-time monitor for your libraries. ahh ok, so this is due to real-time monitor. Is there a reason realtime monitoring of fstab mounted devices wont work on freebsd ? EDIT: Sorry i just googled and a bunch of threads came up, ill do some reading first. Edited June 22, 2018 by makarai
adrianwi 279 Posted June 22, 2018 Posted June 22, 2018 @@Josh got the real-time monitoring to work in the FreeNAS plugin, but I think the patch that needed to be applied to Mono hasn't been updated since about 4.8, which I assume is one of the reasons the plugin is starting to fall behind. I prefer the performance improvements and having to run a manual scan every now and then but running the latest stable version.
Luke 42234 Posted June 22, 2018 Author Posted June 22, 2018 For what it's worth, when we build our package we will be using whatever is available in freebsd ports. Patching changes into the mono runtime is not something we're going to be looking at.
makarai 109 Posted June 23, 2018 Posted June 23, 2018 fYI: https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=229247 1
Luke 42234 Posted June 23, 2018 Author Posted June 23, 2018 Ah yes that's good. That's a pretty big problem. Hopefully that doesn't take too long to get resolved.
makarai 109 Posted July 1, 2018 Posted July 1, 2018 (edited) Ah yes that's good. That's a pretty big problem. Hopefully that doesn't take too long to get resolved. https://www.freshports.org/lang/mono i updateed to _3 with pkg install portmaster portsnap fetch extract #(replace extract with update if you've already run extract) portmaster -ai and everything runs smoothly Edited July 2, 2018 by makarai 2
MRobi 161 Posted July 4, 2018 Posted July 4, 2018 Mono 5.10.1.47_3 is now updating with the usual pkg update pkg upgrade commands so should be straight forward for all to update
Luke 42234 Posted July 6, 2018 Author Posted July 6, 2018 Update: We are beginning development on packages for both FreeBSD and FreeNAS. Hopefully by the end of the month we'll have builds ready for testing. If all goes well perhaps sooner. Also if you follow this: https://github.com/dotnet/corefx/issues/1626 .NET Core for BSD appears to be getting closer, so it's possible that our time with mono will be short lived (we're hoping at least). Thanks everyone. 4
Luke 42234 Posted July 13, 2018 Author Posted July 13, 2018 https://emby.media/community/index.php?/topic/60728-new-freebsd-package-for-testing/
Luke 42234 Posted July 21, 2018 Author Posted July 21, 2018 New FreeNAS package tor testing: https://emby.media/community/index.php?/topic/60971-new-freenas-package-for-testing/ Enjoy guys, thanks !
Luke 42234 Posted August 3, 2018 Author Posted August 3, 2018 I'm moving the install instructions for the new package to our website as we're happy with the results. Thanks everyone for testing.
embytestit 1 Posted September 15, 2018 Posted September 15, 2018 Hi, I am running FreeBSD 10.4 Release amd64 and tried to install Ember server today with the command mentioned here: pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/3.5.2.0/emby-server-freebsd_3.5.2.0_amd64.txz RESULT: Fetching emby-server-freebsd_3.5.2.0_amd64.txz: 100% 16 MiB 3.3MB/s 00:05 Installing emby-server-3.5.2.0_1... pkg: wrong architecture: FreeBSD:11:amd64 instead of FreeBSD:10:amd64 Newer FreeBSD version for package emby-server: To ignore this error set IGNORE_OSVERSION=yes - package: 1102000 - running kernel: 1004000 Allow missmatch now?[Y/n] Do you provide version 3.5.2.0 only for FreeBSD 11? With a normal "pkg add emby-server" under FreeBSD 10.4-Release only Ember server version 3.3.1.0_1 is installed. What can I do?Ist the only solution for me to build 3.5.2.0 with the ports? Best regards embytestit
Luke 42234 Posted September 15, 2018 Author Posted September 15, 2018 Hi, sorry, yes you will need 11.1+.
embytestit 1 Posted September 15, 2018 Posted September 15, 2018 Thanks, but can I build 3.5.2.0 for FreeBSD 10.4 Release by help of the ports for 10.4? Thanks and regards embytestit
