Mael 5 Posted May 17, 2022 Posted May 17, 2022 Apologies for the newb question, but FreeBSD isn't my strong suit. I've switched from the TrueNAS plugin to emby manually installed in a Truenas jail using these instructions: https://emby.media/freebsd-server.html Everything is running as expected, but I wanted to know how I should upgrade. So when I did the install, I obviously installed the dependences and then ran pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.7.0.40/emby-server-freebsd13_4.7.0.40_amd64.pkg When the next release comes out, do I simply run pkg upgrade && pkg update and then re-run the same pkg add command, but with the updated release?
Luke 42237 Posted May 17, 2022 Posted May 17, 2022 HI, generally speaking, for our manual installs, you go back and run the same install process again over the top of your existing installation. For those FreeBSD instructions that means the entire process, including the dependency installs.
Mael 5 Posted May 17, 2022 Author Posted May 17, 2022 (edited) Thanks. I'm assuming it won't overwrite any of the configuration stuff that's backed up with the Server Configuration Backup Plugin. Is this correct? Edited May 17, 2022 by Mael
KZWings 5 Posted May 19, 2022 Posted May 19, 2022 (edited) On 5/17/2022 at 2:08 PM, Mael said: pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.7.0.40/emby-server-freebsd13_4.7.0.40_amd64.pkg pkg upgrade && pkg update I performed these exact steps and Emby no longer loads. Stopped/Restarted jail and service. TrueNAS 12.0-U6.1 Emby jail 12.2-RELEASE-p15 Updated from Emby 4.6.6.0 Able to ping Emby server, but does not load in browser or Android app. Edited May 19, 2022 by KZWings 1
Luke 42237 Posted May 19, 2022 Posted May 19, 2022 43 minutes ago, KZWings said: I performed these exact steps and Emby no longer loads. Stopped/Restarted jail and service. TrueNAS 12.0-U6.1 Emby jail 12.2-RELEASE-p15 Updated from Emby 4.6.6.0 Able to ping Emby server, but does not load in browser or Android app. Hi, you're going to have to configure the jail to enable mlock: Please let us know if this helps. Thanks. 1
KZWings 5 Posted May 19, 2022 Posted May 19, 2022 Thanks, that worked! I think because running from TrueNAS shell, I'm already root, so i didn't need to sudo iocage set allow_mlock=1 <jailname> 1 1
Jerren 18 Posted May 23, 2022 Posted May 23, 2022 Had the same problem and this fixed it so ty KZWings! 1
dolphin 17 Posted August 11, 2022 Posted August 11, 2022 On 5/17/2022 at 8:29 PM, Luke said: HI, generally speaking, for our manual installs, you go back and run the same install process again over the top of your existing installation. For those FreeBSD instructions that means the entire process, including the dependency installs. It'd be awesome if we found this information along with the installation instructions, so we didn't have to look up the community forum!
dolphin 17 Posted August 11, 2022 Posted August 11, 2022 On 5/17/2022 at 8:29 PM, Luke said: HI, generally speaking, for our manual installs, you go back and run the same install process again over the top of your existing installation. For those FreeBSD instructions that means the entire process, including the dependency installs. Mmmh, I just did that but instead of upgrading the existing emby-server jail, it created a new one called emby-server_1... how do I force it to do an in place upgrade?
Luke 42237 Posted August 11, 2022 Posted August 11, 2022 5 hours ago, dolphin said: Mmmh, I just did that but instead of upgrading the existing emby-server jail, it created a new one called emby-server_1... how do I force it to do an in place upgrade? Looks like you were able to update based on the other topic. Thanks.
