Remote Play from Web Client
techchad
techchad
I'm having a problem getting the Remote Play to work with XBMB3C.  I've checked all SMB shares, I am using the UNC path substitution instead of E:\path.  Remote Play does work for my Media Portal Client.
Here's a snippet of the XBMC.log when i hit play:
11:05:48 T:3444  NOTICE: Thread LanguageInvoker start, auto delete: false
11:05:48 T:3444  NOTICE: -->Python Interpreter Initialized<--
11:05:48 T:3444  NOTICE: ===== XBMB3C START =====
11:05:48 T:3444  NOTICE: XBMB3C -> running Python: sys.version_info(major=2, minor=7, micro=5, releaselevel='final', serial=0)
11:05:48 T:3444  NOTICE: XBMB3C -> running XBMB3C: 0.9.530
11:05:48 T:3444  NOTICE: 13.2 Git:20140817-0f3db05
11:05:48 T:3444  NOTICE: XBMB3C -> Platform: Windows
11:05:48 T:3444  NOTICE: XBMB3C -> LogLevel:  0
11:05:48 T:3444  NOTICE: XBMB3C 0 -> Version : 13.2 - {u'major': 13, u'tag': u'stable', u'minor': 2, u'revision': u'20140817-0f3db05'}
11:05:48 T:3444  NOTICE: PLAY ACTION URL PARTS : ['10.0.0.110:8096', '487b0bfd48694b1f2a6cc083b183a056', '-1']
11:05:48 T:3444  NOTICE: PLAY ACTION URL AUTO RESUME : -1
11:05:48 T:3444   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                             - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
                                            Error Type: <type 'exceptions.NameError'>
                                            Error Contents: global name '__language__' is not defined
                                            Traceback (most recent call last):
                                              File "C:\Users\htpc\AppData\Roaming\XBMC\addons\plugin.video.xbmb3c\default.py", line 2630, in <module>
                                                PLAY(param_url, pluginhandle)
                                              File "C:\Users\htpc\AppData\Roaming\XBMC\addons\plugin.video.xbmb3c\default.py", line 826, in PLAY
                                                userid = downloadUtils.getUserId()
                                              File "C:\Users\htpc\AppData\Roaming\XBMC\addons\plugin.video.xbmb3c\resources\lib\DownloadUtils.py", line 78, in getUserId
                                                return_value = xbmcgui.Dialog().ok(__language__(30045),__language__(30045))
                                            NameError: global name '__language__' is not defined
                                            -->End of Python script error report<--
Link to comment
Share on other sites
im85288
It looks like it's failing to find your userid.
I fixed the error above and will put a fix version out later on. You can try the latest on github if you would like to test it quicker.
  • Like 1
Link to comment
techchad
Yup that cleared up that error, now I'm just getting a Username not found error...username is configured correctly in settings.  Tested credentials from web session and all seems well there.
Link to comment
Guest
