MediaMogal 19 Posted September 13, 2020 Share Posted September 13, 2020 Since you don't seem to have a forum section for reporting when the web interface seems to be down I'm just going to report it here. I just logged in and with in second I got a failure to connect screen when I attempted to access one of my libraries. Has anyone else else been having issues with the portal? when I enter http://10.0.0.85:8096/web/ on Down for everyone or just me https://downforeveryoneorjustme.com I get the below. Thanks Uh oh! There was an error: It doesn't look like you entered a valid domain or service name. Note: we can't check IP addresses (http://1.2.3.4) directly. Please enter a domain name (http://example.com). Link to comment Share on other sites More sharing options...
MediaMogal 19 Posted September 13, 2020 Author Share Posted September 13, 2020 Just made sure the srervices are running. sudo systemctl start emby-server.service sudo systemctl enable emby-server.service http://10.0.0.85:8096/web/ Link to comment Share on other sites More sharing options...
mark-in-dallas 86 Posted September 13, 2020 Share Posted September 13, 2020 (edited) http://10.0.0.85:8096/web/ that is the I.P. address of your local server within the LAN and would not be reachable from outside of your local network, which is why downforeveryoneorjustme.com couldn't access it. After starting and enabling Emby are you able to access it now? Edited September 13, 2020 by mark-in-dallas 1 Link to comment Share on other sites More sharing options...
MediaMogal 19 Posted September 13, 2020 Author Share Posted September 13, 2020 http://10.0.0.85:8096/web/index.html#!/home the page I'm taken to in my browser after I click the shortcut I created with http://10.0.0.85:8096/web/ as the url in it. As for starting the service I'm pretty sure that the site was just down for a short while cause when I first click my shortcut I was able to login in to the web portal. It went down seconds after landing on my main server page. That tells me the service was running here. Thanks for the quick reply. If it happens again I'll then assume the service crashed for some reason and post my logs. Thanks again. Link to comment Share on other sites More sharing options...
