Raspberry - emby dont start after reboot
ibizista
Go to solution Solved by ibizista,
Hello,
I have a Raspberry Pi 3, with raspbian
 pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
I've installed emby-server
wget https://github.com/MediaBrowser/Emby.Releases/releases/download/4.4.2.0/emby-server-deb_4.4.2.0_armhf.deb
sudo dpkg -i emby-server-deb_4.4.2.0_armhf.deb
sudo service emby-server start
Until here, all works fine.
I can use the config web
http://localhost:8096
But if I restart the service or reboot the raspberry, the service don't start.
pi@raspberrypi:~ $ sudo systemctl status emby-server
● emby-server.service - Emby Server is a personal media server with apps on just about every device.
   Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled)
   Active: failed (Result: signal) since Thu 2020-04-23 15:45:01 CEST; 5s ago
  Process: 916 ExecStart=/opt/emby-server/bin/emby-server (code=killed, signal=ABRT)
 Main PID: 916 (code=killed, signal=ABRT)
abr 23 15:45:00 raspberrypi systemd[1]: Started Emby Server is a personal media server with apps on just about every device..
abr 23 15:45:01 raspberrypi systemd[1]: emby-server.service: Main process exited, code=killed, status=6/ABRT
abr 23 15:45:01 raspberrypi systemd[1]: emby-server.service: Unit entered failed state.
abr 23 15:45:01 raspberrypi systemd[1]: emby-server.service: Failed with result 'signal'.
If I try to run emby with the command:
pi@raspberrypi:~ $ sudo /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_armhf.deb
sudo: unable to execute /opt/emby-server/system/EmbyServer: No such file or directory
But the file exist
pi@raspberrypi:~ $ ls -ltrh /opt/emby-server/system/EmbyServer
-rwxr-xr-x 1 root root 76K ago 22  2017 /opt/emby-server/system/EmbyServer
If i reinstall emby-server, the first time that I run it, it works, but the second and above, don't work.
Thanks
Link to post
Share on other sites
  • Solution
I've reinstalled the reaspberry with the last version of raspbian (debian 10 buster lite) and now all works fine.
Linux raspberrypi 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l GNU/Linux
  • Like 1
Link to post
