How to connect Emby through Qnap LetsEncrypt Certificate ?
jillybean
@schogobong I found a saved copy of my script which is slightly different to the original I posted.  I think the main change (based on a post by Jibest that suggested the key didn't change) was to alter the 'find' to look at the time on the cert file rather than the key file - so:
[[ -z `find cert -mmin -60` ]]     rather than   [[ -z `find key -mmin -60` ]]
  • 1 year later...
On 1/21/2019 at 6:09 PM, Jibest said:
I've managed to answer most of those questions myself. You can automate the password when running the cmd by using -passout in the cmd.
To have no password add the following:
openssl pkcs12 -export -out certificate.pfx -inkey key -in cert -passout :pass
if you want a password then use
openssl pkcs12 -export -out certificate.pfx -inkey key -in cert -passout :passmypassword
I've decided to re-generate the PFX twice a month to avoid it expiring but need to wait and see if there are any issues. To do this I wrote a simple script to run the cmd and then added the following to Crontab:
0 0 */15 * 6 /share/CE_CACHEDEV6_DATA/Files/Scripts/Create_Cert.sh
Touch wood this will now take care if itself.
Thank you for this post. It helped me to figure out how to create it with no typo in regards to -inkey
But there is a typo when it comes to :pass and it should be pass: if no password, and pass:myPassWord if one wants a password
To have no password:
sudo openssl pkcs12 -export -out certificate.pfx -inkey key -in cert -passout pass:
To have password:
sudo openssl pkcs12 -export -out certificate.pfx -inkey key -in cert -passout pass:MyPassWord
Thanks
