Hi,
I couldn't find this in the search but on anime with subs that are set to be on the bottom and top of the screen at the same time, it just places both subs at the bottom. It overwrites the previous one which results in the subs just going by incredibly fast. Is there anything I can do to fix this?
I know in the normal web player on a computer it has them in the correct places.
Thanks
Guest
