tymanthius 18 Posted March 22, 2017 Share Posted March 22, 2017 So, I'd like a little help with diag'ing this. I have Iron Fist (nevermind the reviews, I'm testing stuff) and when I go to play it on my Roku Ultra, it stops/stutters, is generally horrible. I'm running the current emby-beta on debian available via apt-get (which is 1 release behind stable right now I think), and the emby beta roku channel. It's in an LXC, 4 cores, 8G memory, and cpu usage only hits about 80% at most. If I try the same thing in chrome on my linux laptop, it won't play at all. But it plays ok if I copy the file and play directly in vlc. The Roku is connected by wifi, and should be getting at least 50m thru - my phone gets that according to the unifi controller tests. I'm at work, so don't have the logs & such, but I'll try to dig them up this evening. Anyone have any thoughts? Link to comment Share on other sites More sharing options...
tymanthius 18 Posted March 23, 2017 Author Share Posted March 23, 2017 It's at least partly a bandwidth issue I've determined. Messed w/ my unifi ap settings and it's helped. Link to comment Share on other sites More sharing options...
Luke 30057 Posted March 23, 2017 Share Posted March 23, 2017 Thanks for reporting back. Link to comment Share on other sites More sharing options...
Solution tymanthius 18 Posted March 31, 2017 Author Solution Share Posted March 31, 2017 Finally got some more time to work on this. Was fully bandwidth issues as Roku wasn't connecting to 5Ghz radio. Forced that and now it's much better. Might buffer once or twice on a bad day. Link to comment Share on other sites More sharing options...
