Missing guide entry and channel in Emby
guide channel
  • Please log in to reply
2 replies to this topic
#1 BillBill3 OFFLINE
BillBill3
    Newbie
  • Members
  • 2 posts
  • Local time: 02:14 AM
Posted 16 January 2017 - 06:11 PM
Perhaps someone can help with this...
I'm using WMC on Win 10, Serverwmc, Emby. Haupauge quad tuner. I just changed from ASTC to clear QAM cable. WBZ HD (channel 4.1 CBS boston) displays fine on WinTV8 and WMC, and the guide displays fine on WMC. Neither the channel nor the guide will display on Emby. Only this channel is affected.
Any ideas?
Thanks
Bill
#2 krustyreturns OFFLINE
krustyreturns
    Advanced Member
  • Developers
  • 1329 posts
  • Local time: 11:14 PM
  • Locationaptos, ca
Posted 16 January 2017 - 07:02 PM
In wmc look at your channel list and make sure you don't have a bad channel with the same channel number  (usually the channel is called 'drama', its left over from when wmc had internet channels), if its there just disable it.
If that's not the problem, post your serverwmc log (see debug tab) after trying to play the problem channel.
#3 BillBill3 OFFLINE
BillBill3
    Newbie
  • Members
  • 2 posts
Posted 16 January 2017 - 09:35 PM
Thats it, thanks!
Also tagged with one or more of these keywords: guide, channel
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
