Sysyphus666 1 Posted November 22, 2016 Share Posted November 22, 2016 Hello, I have an error on Emby for Kodi. I updated my server and Emby for Kodi, and since, all features of Emby for Kodi doesn't work... I tried with Beta and stable versions of Kodi for Emby with the same result. I reset all settings and emby database : same things... I tried many settings but nothing works. I have no more idea. Please can you help me. In the log, the problem seem on Emby.Database. It's alway the same kind of error : Value: 'ascii' codec can't decode byte 0xc3 in position 1: ordinal not in range(128) The complet log is here : https://drive.google.com/file/d/0B6yElq_-gIiRMUxZOF94b1VLdG5qTzg1ODNCOUpwRURNTkdV/view?usp=sharing Thank you for helping. Link to comment Share on other sites More sharing options...
Angelblue05 4127 Posted November 22, 2016 Share Posted November 22, 2016 (edited) Hey there, do you have special characters in your device name or server name or user name? Sent from my iPhone using Tapatalk Edited November 22, 2016 by Angelblue05 Link to comment Share on other sites More sharing options...
Sysyphus666 1 Posted November 23, 2016 Author Share Posted November 23, 2016 (edited) Hello, I don't have a special character on user credential and server name Possibly I have a special character on a folder binded in Emby for Video for Video library (folder name : Vidéos) Yesterday I rollback to version 2.2.19 of Emby for Kodi and It work fine. I tried a new version (3.2) and I alway have the same bug Thanks Edited November 23, 2016 by Sysyphus666 Link to comment Share on other sites More sharing options...
Sysyphus666 1 Posted November 25, 2016 Author Share Posted November 25, 2016 Hello, Where I can check the device name ? Is-it the server name ? And why with previous version all work find ? Sound like a regression bug ? Thank you for the help Link to comment Share on other sites More sharing options...
Solution Angelblue05 4127 Posted November 25, 2016 Solution Share Posted November 25, 2016 In the addon settings, if it use alternate device name is unchecked, verify in the kodi settings > service Sent from my iPhone using Tapatalk 1 Link to comment Share on other sites More sharing options...
Angelblue05 4127 Posted November 25, 2016 Share Posted November 25, 2016 Yeah well, I need to know which is giving the issue so I can resolve it thanks. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Sysyphus666 1 Posted November 28, 2016 Author Share Posted November 28, 2016 Hello; Sorry for my respond time, I wil check that I I respond to you. But I reset all addons settings many time for testing so you can consider that I have default settings. Do you need more information for your help ? Thank very much for your help. Link to comment Share on other sites More sharing options...
Angelblue05 4127 Posted November 28, 2016 Share Posted November 28, 2016 (edited) I'll need the information I asked for previously. You are the only person to ever report this issue. Thanks. Sent from my iPhone using Tapatalk Edited November 28, 2016 by Angelblue05 Link to comment Share on other sites More sharing options...
Sysyphus666 1 Posted November 28, 2016 Author Share Posted November 28, 2016 Hello You've right. You have found the issue. I have the deviname set to Télévision. I have changed to TV and all seem to work fine. Thank you very much for the help 1 Link to comment Share on other sites More sharing options...
Angelblue05 4127 Posted November 28, 2016 Share Posted November 28, 2016 Thanks for reporting back. Glad you resolved the situation. A fix will be made for this. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
