Bluray Folder Audio Problem
Go to solution Solved by mata7,
Angelblue05
Hmmmmm...... Interesting.... Ok, give me a few to ponder. Because I would think it should be able to locate the file, the path seems to be correct now...
nice nice thank you, got my hope up
Angelblue05
@@mata7
Can you install this build, I've removed the verification to see where it's failing ok?
Just let me know if you are able to playback the file with the build and we'll go from there. Thanks
i will, please give a few hours the wife arrive and have to to someting we her, happy wife happy life :)
  • Like 1
dint work, i got cant fiend next item to play message
01_KODI.log
  • Like 1
Angelblue05
Interesting.... Kodi throws an error when trying to open your file. I thought the problem may lie in the add-on path verification, but Kodi still doesn't open the fie.
Ok, next step: Enable Kodi debug (in settings > system > debugging). Then try to play the file again and post that log. Sorry for the many steps, this is a weird one... I do not use nfs personally, but hopefully Kodi will tell us why it's not able to open your file at the location:
ERROR: CDVDPlayer::OpenInputStream - error opening [nfs://192.168.1.103/VOLUME1/TV Series/Africa (2013)/Season 1/S01E01.mkv]
Edited by Angelblue05
dont worrie about, im grateful at you for help me out, here are the log let me know if you need anyting else, sorry if i dont awnser fast the wife is on top of me lol
http://goo.gl/SEgM3f
Angelblue05
Doh. your log is incorrect. Can you enabled the Kodi debug in settings > system > debugging (set the add-on log level back to Info). I'm trying to get the error message for why Kodi can't open a path that seems valid....
Angelblue05
Ok....What the heck? There's no other error messages, no reasons behind why it would fail... it just does.... Hm, are you able to test using smb instead of nfs?
i try the smb on kodi but im getting this error trying to browse the library SMB to my nas Operation no permite
Angelblue05
Ok so sounds like it's a permission issue. You can enter the network credentials in the add-on settings, have you tried? Earlier when you tried to navigate to your content via NFS in Kodi, did it ask you to put in a password at any time?
It almost looks as if it's a file permission issue. Because Kodi seems to be able to see the files, but when it comes to opening it, it fails.
kodi never ask me for any password, do you think unraid server could be the problem?
Edited by mata7
i fix the Operation no permite problem now everything is ok and i can browse my library wiht kodi on SMB, but emby still give me the same problem files dont play, just for the sick of it i install plexbmc and every file play fine from my plex server is the same folders config like on emby, so i really dont know what to think any more, i really appreciated all you help you been more then nice helping me on this, i know is no that much but im gone to donate 10.00 so you can get a cup of coffe on me, but for now im give up on this with emby
take care and again thanks for all you help Angel
Angelblue05
So it's direct playing with plexbmc? Can I see the kodi log to compare? I hope plexbmc shows info in log that will help. At this point, I have no idea why it's not behaving correctly, it's really weird...
yeah direct play, ok i will give one more try lol, how do i get the log from plex, the same way?
here is the log, for some reason kodi log uploader was give me some problems
kodi.log
Angelblue05
Nope, it's not direct playing either:
DVDPlayer: Opening: http://192.168.1.100:32400/library/parts/90/file.mkv
wow i dont know then, so what that mean transcoding? because the mkv play with full bitrate and the audio is the DTS-MA nikita
Angelblue05
Something in your permissions is messed up. You'll need to figure it out to be able to direct play. Until then, you can enable play from http - direct stream is the next best thing after direct play. It just allows you to bypass network issues, but keeps the file intact so you can get the same results as direct play.
ok buddy thanks again for everyting have a good night
  • Solution
angel can you please check this log for me and tell me if is Direct Playing, i think i got it, i dont get any playback error any more
here is what i change
/mnt/disks/NASSERVER_TV_Series
To
smb://192.168.1.100/NASSERVER_TV_Series
thanks in advanced
  • Like 1
Angelblue05
Great job @@mata7
It is indeed direct playing now. Kodi is able to locate your content now. :)
  • Like 1
good god finally, thanks a lot for everything, you help me a lot, never give up lol
  • Like 2
Guest
