richardap1
Has Anything changed in the latest .81+ releases that might have broken pseudotv.   Before the upgrade it seemed to work fine, now however it just says it can't play any files then crashes out.  I don't have the logs at the moment as i am away. I was just wondering if anyone else had used / noticed this?
Thanks
I was using PseudoTV and was having problems with it.... have you tried the LazyTV addon?
richardap1
Thanks, no i've not heard of that. Will give it a try.
Guest
