msgonz 4 Posted March 8, 2015 Share Posted March 8, 2015 I just moved MB from Windows to FreeNAS I'm using several Roku 3. One thing that happen using Roku with FreeNAS is the the indicator on the right top corner of the cover art no longer shows a check-mark or number of unwatched shows. All I get is a green circle but no check mark or number. If I switch back to the Windows MB on the same Roku everything is fine. Both Windows and FreeNAS are running 3.0.5518.7. Also in the web ui or android client it works fine on ether Windows or FreeNAS. Any ideas? Thanks 1 Link to comment Share on other sites More sharing options...
