Emby Emby Emby Learn
  • Emby Home
  • Video
  • Audio
  • Media Files
    • Subtitles and captions
    • Photos and images
    • Metadata and discovery
    • Playback and streaming
    • Media hardware acceleration
    • Displays and AV connections
    • Live TV and recording
  1. Emby Learn
  2. Subtitles and captions
  3. Subtitle formats
  4. Bitmap subtitle formats
  5. DVB subtitles (DVBSub)
Search Results for
    Show / Hide Table of Contents
    DVBSub carries broadcast subtitle services using timed page, region, object and colour-table segments in a transport stream.
    DVB subtitles, often called DVBSub, are a broadcast subtitling system defined by ETSI EN 300 743. Their common graphical mode assembles subtitles from indexed-pixel objects, regions and a timed page composition.
    The system can support character-code objects under local agreements as well. It should therefore be described as a graphics-oriented subtitle system with defined additional modes, rather than as proof that every possible DVB subtitle contains only bitmap runs.
    Transport identity and subtitle-service identity
    DVB subtitle data travels in PES packets within an MPEG transport stream. The PES timing supplies presentation timestamps. Transport packets use a PID to identify the carrying stream.
    A single such stream can carry more than one subtitle service. Signaling identifies the intended language/type and the composition page ID, with an ancillary page ID when applicable. The PID alone can therefore be insufficient to choose the desired caption service.
    An Emby recording retaining the broadcast transport can preserve those relationships. When a tool extracts or repackages a subtitle track, it must keep the service configuration needed to interpret its data.
    A page is built from regions and objects
    A DVB subtitle page places regions, while each region places objects and selects its colour-table interpretation.
    The roles form a hierarchy:
    Role Purpose
    Page composition Selects regions, their positions and page state
    Region composition Defines region dimensions, depth, colour-table identity and placed objects
    Object data Supplies graphical content or the applicable alternative coding
    Colour lookup table, CLUT Resolves indexed values to colour/transparency
    Display definition Establishes display geometry where provided
    Objects can be updated without replacing the whole page. Regions can move or become visible through a page update. The stored data is therefore a sequence of state changes, not necessarily a collection of independent screenshots.
    Adding the two levels of position
    Suppose a region begins at (100,500) on a 720 × 576 display plane. An object begins at (20,15) within that region. Its plane position is:
    x = 100 + 20 = 120
    y = 500 + 15 = 515
    For a 500 × 40 object, its extent reaches x = 620 and y = 555, within this illustrative plane. The region must also be large enough to contain the object. Confusing the region-relative position with the page-relative position would put the graphic in another location.
    The CLUT and pixel-depth interpretation complete the picture. A valid object run decoded with the wrong colour-table state is not the intended subtitle.
    Tuning and seeking require an acquisition state
    An update in the middle of a service may assume that earlier objects or regions are already known. A live receiver tuning into that stream needs an acquisition point containing the information required for the next page. A recording seek has a comparable need to reconstruct state.
    The page composition also supplies a timeout in seconds. If the page is not replaced or redefined, it eventually ceases to be valid and should be erased. This prevents a stale caption from remaining indefinitely after a lost update.
    A timeout is a recovery bound, not a universal substitute for exact authored cue endings. Later display updates provide the normal intended progression.
    See Also
    • Bitmap subtitles
    • Blu-ray subtitles (PGS)
    • MPEG Transport Stream: TS and M2TS
    • Streams and Tracks
    References
    • ETSI EN 300 743 V1.6.1: DVB subtitling
    • Matroska: Subtitle storage and codec mappings
    • ETSI EN 300 468 V1.19.1: DVB service information and subtitling descriptor
    On this Page
    Back to Top
