Chalklands 27 Posted June 4, 2021 Author Posted June 4, 2021 1 hour ago, cayars said: So you only see this problem on the FireTV? Yes only on the Firestick
Chalklands 27 Posted June 10, 2021 Author Posted June 10, 2021 Hi, Any update on this? Still got the same issue.
ebr 16338 Posted June 10, 2021 Posted June 10, 2021 It still works as expected for me so I'm just not sure what is happening for you yet.
Chalklands 27 Posted June 10, 2021 Author Posted June 10, 2021 Hi ebr. Thanks for the reply. I'm not sure either. I even tried uninstalling and reinstalling emby on my Firestick. No change. Do you think doing the same on my laptop might help? It was all working fine until about a week or so. Totally confused here.
ebr 16338 Posted June 10, 2021 Posted June 10, 2021 No, I don't think that will matter. It has to be something related either to the specific media setup or, possibly, settings. Just can't figure it out yet...
Chalklands 27 Posted June 10, 2021 Author Posted June 10, 2021 Thanks for the reply, I appreciate it.
Chalklands 27 Posted June 10, 2021 Author Posted June 10, 2021 FYI, I've just tried a different laptop but the same issue occurs.
Chalklands 27 Posted June 10, 2021 Author Posted June 10, 2021 Hi, Thanks for the reply Luke. It is, I just thought I'd try just in case it was a windows issue, it isn't.
Chalklands 27 Posted June 10, 2021 Author Posted June 10, 2021 Yes, via Chromecast. It plays just fine.
Chalklands 27 Posted June 11, 2021 Author Posted June 11, 2021 Forgot to say, playing the web version of EMBY on my laptop works fine as well.
Luke 42246 Posted June 14, 2021 Posted June 14, 2021 What version of the Fire TV app are you up to now?
Chalklands 27 Posted June 14, 2021 Author Posted June 14, 2021 Hi Luke, Version 2.0.21a, the server laptop version is 4.6.2.0
Luke 42246 Posted June 16, 2021 Posted June 16, 2021 @Chalklands as a test, can you try installing the Emby standard Android app on the same device and see how it compares? https://emby.media/emby-for-android.html Thanks !
Chalklands 27 Posted June 16, 2021 Author Posted June 16, 2021 Hi Luke, Excuse my ignorance, but install on where? My mobile, Firestick or Laptop? Thanks Pete
Chalklands 27 Posted June 16, 2021 Author Posted June 16, 2021 I've followed the link and tried to download but it isn't compatible with my Firestick.
Chalklands 27 Posted June 17, 2021 Author Posted June 17, 2021 Hi Yes. The 'Available at Amazon' link.
Carlo 4561 Posted June 17, 2021 Posted June 17, 2021 This link? https://emby.media/emby-for-fire-tv.html
Chalklands 27 Posted June 17, 2021 Author Posted June 17, 2021 Hi, Yes installed on my firestick. No change I'm afraid
