Riggs 312 Posted October 8, 2019 Posted October 8, 2019 (edited) Btw and Fyi. With the new OMV v5 the plugins going to start to migrate to docker and many going to not be supported anymore. So if you are using the plugins is better that you migrate to Docker. Edited October 8, 2019 by HRSCR
Andythediver 0 Posted November 2, 2019 Posted November 2, 2019 Hi - having enjoyed emby on my laptop, and finally getting round to creating a NAS - running xpenology 6.1, i cannot for the life of me get Emby to work. If i just install it from the repository, it continuously jumps between asking be to run - then install it. Much reading later, i discover its something to do with the way xpenology hides its hardware from synology?? More reading and ive finally created a running emby from within a docker. but after hours and hours of searching forums and trying different mount point paths, i cannot get emby to find any multimedia. ive followed the link to docker instructions [from installation instructions here] - to be hit with :- The container can be run using the following command: docker run -d \--volume /path/to/programdata:/config \ # This is mandatory--volume /path/to/share1:/mnt/share1 \ # To mount a first share--volume /path/to/share2:/mnt/share2 \ # To mount a second share--device /dev/dri:/dev/dri \ # To mount all render nodes for VAAPI/NVDEC/NVENC--runtime=nvidia \ # To expose your NVIDIA GPU--publish 8096:8096 \ # To expose the HTTP port--publish 8920:8920 \ # To expose the HTTPS port--env UID=1000 \ # The UID to run emby as (default: 2)--env GID=100 \ # The GID to run emby as (default 2)--env GIDLIST=100 \ # A comma-separated list of additional GIDs to run emby as (default: 2)emby/embyserver:latest Please adapt the UID, GID and GIDLIST values to match the owner of your media files. GIDLIST is also needed to grant access to VAAPI/NVDEC/NVENC render nodes. now as I'm an avid film watcher, not a rocket scientist, can someone translate the above into layman's english - or alternatively post explicite instructions - in terms of 1 syllable at a time, for me to follow. Thanks in advance Andy this is my last hope as Plex works straight out of the box - its just that ive tried both in windows and find emby far superior. If i cant sort this this weekend - im afraid its back to plex and i will be gutted
Luke 42243 Posted November 3, 2019 Author Posted November 3, 2019 Hi - having enjoyed emby on my laptop, and finally getting round to creating a NAS - running xpenology 6.1, i cannot for the life of me get Emby to work. If i just install it from the repository, it continuously jumps between asking be to run - then install it. Much reading later, i discover its something to do with the way xpenology hides its hardware from synology?? More reading and ive finally created a running emby from within a docker. but after hours and hours of searching forums and trying different mount point paths, i cannot get emby to find any multimedia. ive followed the link to docker instructions [from installation instructions here] - to be hit with :- The container can be run using the following command: docker run -d \ --volume /path/to/programdata:/config \ # This is mandatory --volume /path/to/share1:/mnt/share1 \ # To mount a first share --volume /path/to/share2:/mnt/share2 \ # To mount a second share --device /dev/dri:/dev/dri \ # To mount all render nodes for VAAPI/NVDEC/NVENC --runtime=nvidia \ # To expose your NVIDIA GPU --publish 8096:8096 \ # To expose the HTTP port --publish 8920:8920 \ # To expose the HTTPS port --env UID=1000 \ # The UID to run emby as (default: 2) --env GID=100 \ # The GID to run emby as (default 2) --env GIDLIST=100 \ # A comma-separated list of additional GIDs to run emby as (default: 2) emby/embyserver:latest Please adapt the UID, GID and GIDLIST values to match the owner of your media files. GIDLIST is also needed to grant access to VAAPI/NVDEC/NVENC render nodes. now as I'm an avid film watcher, not a rocket scientist, can someone translate the above into layman's english - or alternatively post explicite instructions - in terms of 1 syllable at a time, for me to follow. Thanks in advance Andy this is my last hope as Plex works straight out of the box - its just that ive tried both in windows and find emby far superior. If i cant sort this this weekend - im afraid its back to plex and i will be gutted @@Andythediver, what exactly are you having trouble with? What can we help clarify? Thanks !
Andythediver 0 Posted November 4, 2019 Posted November 4, 2019 (edited) Everything i find onine in terms of help with docker all consist of typed commands [similar to dos prompts] however in exppenology/docker - i have no idea how or where to find this prompt. my main issue is pointing emby inside docker to media folders outside of docker as - while i can get emby to run, there is no content. im using the gui that synology/docker launches - and the window that im sure is causing the issue is the volumes setting tab add file/folders - im pointing at the folder that contains my media eg storage pool:- volume1/movies but the second part - mount path - when ive guessed what to put in there is either incorrect syntax - or , after hours of trying and guesswork from text scripts ive added usr/share/ movies-mb this at least goes in. when i then run emby from a web interface, i point the library folder at the movies-mb folder - which it accepts, then when i run emby and browse the library - nothing there!! I'm honestly pulling my hair out! during my research, i keep seeing references to the config folder too - do i need to set one of those up in the volumes tab too? hence my original question - is there a step by step guide - in picture form - NO DOS PROMPTS!!!! - just literally step by step with examples to get emby running - inside docker on an xpenology built synology dsm? Ive tried running the installer direct to dsm but it runs then stops then asks for installation again. sorry its long - but so is this steep learning curve lol. Annoyingly, plex worked straight out of the box - i just prefer the way emby handles metadata etc Edited November 4, 2019 by Andythediver
Luke 42243 Posted November 4, 2019 Author Posted November 4, 2019 Everything i find onine in terms of help with docker all consist of typed commands [similar to dos prompts] however in exppenology/docker - i have no idea how or where to find this prompt. my main issue is pointing emby inside docker to media folders outside of docker as - while i can get emby to run, there is no content. im using the gui that synology/docker launches - and the window that im sure is causing the issue is the volumes setting tab add file/folders - im pointing at the folder that contains my media eg storage pool:- volume1/movies but the second part - mount path - when ive guessed what to put in there is either incorrect syntax - or , after hours of trying and guesswork from text scripts ive added usr/share/ movies-mb this at least goes in. when i then run emby from a web interface, i point the library folder at the movies-mb folder - which it accepts, then when i run emby and browse the library - nothing there!! I'm honestly pulling my hair out! during my research, i keep seeing references to the config folder too - do i need to set one of those up in the volumes tab too? hence my original question - is there a step by step guide - in picture form - NO DOS PROMPTS!!!! - just literally step by step with examples to get emby running - inside docker on an xpenology built synology dsm? Ive tried running the installer direct to dsm but it runs then stops then asks for installation again. sorry its long - but so is this steep learning curve lol. Annoyingly, plex worked straight out of the box - i just prefer the way emby handles metadata etc Have you checked out our Docker setup guide? https://emby.media/docker-server.html Please note, we are not testing this on Synology, so for best results I would use our native Synology package. https://emby.media/nas-server.html Why not do that?
Andythediver 0 Posted November 4, 2019 Posted November 4, 2019 Have you checked out our Docker setup guide? https://emby.media/docker-server.html Please note, we are not testing this on Synology, so for best results I would use our native Synology package. https://emby.media/nas-server.html Why not do that? 1. yes i have - thats whee all the script mumbo jumbo came from - no graphical explanations at all 2. yes - i tried this first - it point blank doesnt work! will not load - at least the docker method runs and i can access it remotely - albeit without any media.
Luke 42243 Posted November 4, 2019 Author Posted November 4, 2019 1. yes i have - thats whee all the script mumbo jumbo came from - no graphical explanations at all 2. yes - i tried this first - it point blank doesnt work! will not load - at least the docker method runs and i can access it remotely - albeit without any media. Please report your issue in the Synology section and we''ll be happy to help. Thanks.
badous 17 Posted November 5, 2019 Posted November 5, 2019 Hello, here is the video that helped me to install emby on docker. Even if this is an install in OpenMediaVault, I think that it will help you. Give it a try and tell us if it helped.
Luke 42243 Posted November 5, 2019 Author Posted November 5, 2019 @@badous, that's fantastic, thank you ! did you make that video?
badous 17 Posted November 5, 2019 Posted November 5, 2019 @@badous, that's fantastic, thank you ! did you make that video? You are welcome. No I am not TechnoDadLife. He knows way more things than I do. I like his videos, he explains everything step by step. And thanks to him I was able to install several things on Docker. I hope it help others as it helped me.
BAlGaInTl 288 Posted November 6, 2019 Posted November 6, 2019 I used a lot of his videos when I was using OMV.
Eddie 12 Posted November 6, 2019 Posted November 6, 2019 (edited) I know this is a silly question but i wanted to make sure i am doing this right --env GIDLIST=100 \ # A comma-separated list of additional GIDs to run emby as (default: 2) The following command gives me a value of "44" getent group video | cut -d: -f3 so the correct command should be --env GIDLIST=100,44 Is this correct? How do i confirm this is working as it should be on my intel system CPU > Intel® Core i3-2105 CPU @ 3.10GHz https://ark.intel.com/content/www/us/en/ark/products/55448/intel-core-i3-2105-processor-3m-cache-3-10-ghz.html Motherboard > ASROCK Z68 Extreme3 Gen3 https://www.asrock.com/mb/Intel/Z68%20Extreme3%20Gen3/index.asp Thanks in Advance Edited November 6, 2019 by Eddie
Riggs 312 Posted November 6, 2019 Posted November 6, 2019 (edited) @@badous, that's fantastic, thank you ! did you make that video? I published that video some topics ago Edited November 6, 2019 by HRSCR
Riggs 312 Posted November 6, 2019 Posted November 6, 2019 I know this is a silly question but i wanted to make sure i am doing this right --env GIDLIST=100 \ # A comma-separated list of additional GIDs to run emby as (default: 2) The following command gives me a value of "44" getent group video | cut -d: -f3 so the correct command should be --env GIDLIST=100,44 Is this correct? How do i confirm this is working as it should be on my intel system CPU > Intel® Core i3-2105 CPU @ 3.10GHz https://ark.intel.com/content/www/us/en/ark/products/55448/intel-core-i3-2105-processor-3m-cache-3-10-ghz.html Motherboard > ASROCK Z68 Extreme3 Gen3 https://www.asrock.com/mb/Intel/Z68%20Extreme3%20Gen3/index.asp Thanks in Advance how root type: id user where "user" is the user you want to know the ID why you want to add a secondary user id? is not needed emby can run in your default use id example with defaults ID's: UID 1000 GID 100 GIDLIST 100 Hope helps
badous 17 Posted November 6, 2019 Posted November 6, 2019 Ok I did as if I was installing emby in docker. If you follow this you should have it running I hope. For the second picture, I chose to limit the use of my processor and ram use because it is a weak server, but you can chose not to tick it if your server is powerful enough. I have 8go of ram and I set it at 6go limit. But as I said change depending your server. Then press advanced parameters. On the first tab, tick the first box On volume tab, you need to add the folders on the left For the share forlder, use your media folder and on the access you have to type /mnt/share1. And for the config folder, create an emby folder under the docker folder and use this one to be mounted. You can choose to grant read only access to your media folder if you want. Like that you won't have a problem with your medias being modified by emby. In this pic I chose to let Emby have write rights, by not ticking the box on the right. Tick the little box in the network tab. Don't change the two next tabs. Now on the last tab put your UID, GID and GIDLIST and hit apply. Same this here, tick the box and apply. Now your Emby should be running, to access it write your server ip address in your browser with :8096 as port and you should be able to enjoy emby. Hope this will help you.
Andythediver 0 Posted November 6, 2019 Posted November 6, 2019 thank you so - much - this is exactly the kind if thing i was looking for. just a couple more questions please......1. the folder for the /config mountpoint - in your example was docker/emby - i have nothing inside the docker folder - so chose docker - is this ok or have i missed something? and the big one - where do i find my UID, GID and GIDLIST ? im sure this has brought me far closer than any other help and look forward with great grattude for your reply - thank you in advance
badous 17 Posted November 6, 2019 Posted November 6, 2019 (edited) thank you so - much - this is exactly the kind if thing i was looking for. just a couple more questions please......1. the folder for the /config mountpoint - in your example was docker/emby - i have nothing inside the docker folder - so chose docker - is this ok or have i missed something? and the big one - where do i find my UID, GID and GIDLIST ? im sure this has brought me far closer than any other help and look forward with great grattude for your reply - thank you in advance You are welcome, Here, follow this tutorial to access your xpenology with ssh, and when you are in, type in id user1 and then press enter. it will give you the uid and gid. the gidlist you can put the same as gid. In the example below, user1 is the name of my user, if yours is different type the name of your user. ex : id badous and then enter. Yes, create a folder wherever you want for the config. I created mine in the folder docker, to find it easily. but create a folder and name it as you like to be able to find it another time. edit: sorry forgot to past the youtube link and wrote a bad command. Fixed now Edited November 7, 2019 by badous
Andythediver 0 Posted November 7, 2019 Posted November 7, 2019 BADOUS - YOU ARE A LEGEND - IVE BEEN STRUGGLING WITH THIS FOR ALMOST THREE WEEKS - EVERY NIGHT. JUST 1 DAY AFTER YOUR POST, AND ONLY A FEW MINUTES OF STUDY - IM UP AND RUNNING WITH MY LIBRARY POPULATING AS I'M TYPING!!!!! Having now got a populating Movie library, do i need to add more volumes for tv shows and movies etc? and mount them as share2 share3 etc? [i'd normally just experiment but i dont want to damage what you have done for me thus far } once again, thank you so much
badous 17 Posted November 7, 2019 Posted November 7, 2019 You are welcome. I am happy that it worked for you. In my media folder I have created several folders such as movies, TV shows, music... So I only needed to mount one folder, the media folder. But yes, you could mount a share for each folder if you want. Just stop your docker, save the settings in case something doesn't work as planned (so that you can always revert to something working), and make your changes.
sebasmiles 8 Posted November 21, 2019 Posted November 21, 2019 I am running emby docker on Unraid. When I came home it indicated there was a docker update, so I hit the update button. Afterwards it seemed to be consuming a lot of CPU, apparently it wiped my entire database... Any idea what happened? any way to recover the database? I have included the one that seems to be before the update (ending in 65), the one after the update (69), I did try to restart at one point since it seemed to be hung but the embyserver.txt is the very last version. hardware_detection-63709872273.txt embyserver-63709872265.txt embyserver-63709872769.txt embyserver.txt
badous 17 Posted November 21, 2019 Posted November 21, 2019 It happened to others too. You can follow the discussions in this topic https://emby.media/community/index.php?/topic/79481-43025-path-for-tv-shows-lost/?view=getnewpost 1
Haxy 11 Posted November 28, 2019 Posted November 28, 2019 @@Luke Can’t find docker image on docker hub for the newest 4.3.0.30. Can you trigger the build?
Luke 42243 Posted November 28, 2019 Author Posted November 28, 2019 @@Luke Can’t find docker image on docker hub for the newest 4.3.0.30. Can you trigger the build? Try pulling the latest.
Haxy 11 Posted November 28, 2019 Posted November 28, 2019 Try pulling the latest. I never use latest image version, this is not a good practise(more when googling: "docker why not to use latest images"). Please create a image with proper version tag as before.
