herstl22 1 Posted May 11, 2021 Author Posted May 11, 2021 4 hours ago, cayars said: Hi, If you setup your account with the optional Emby Connect username and then logging using Emby Connect you shouldn't have to enter an IP as Emby Connect will find the server for you. Have you tried this? https://support.emby.media/a/solutions/articles/44001160340 I guess I did. When i signed in to this Community
Guest Posted May 11, 2021 Posted May 11, 2021 Actually the two are not the same thing. EMBY Connect is different from the community and the accounts you set up inside EMBY, while this Forum is on another site as well.. The only two things that are connected would be the EMBY Connect account and the Account on your EMBY server. The features you keep mentioning in Plex and EMBY.. You should go through the settings as Admin and set things up.. each devices you sign in with will also need setup.. even within the same account as users have multiple devices. All this should take is proper setup.
Carlo 4561 Posted May 11, 2021 Posted May 11, 2021 Yes, they are two different platforms and do authentication quite differently. With Plex you have no choice but to authenticate against their cloud servers (users belong to Plex) and never against your own server (no passwords or anything on the server). In Emby there is no mandated central cloud authentication and only local authentication on the server. That requires logging in directly to the Emby Server. HOWEVER, Emby has a slick function that allows you the server admin to connect an Emby Connect account (same as a forum account) to a user on your system. So through Emby connect it can put the person who has already authenticated on your server via trust delegation which works very similar to logging into other websites with a Google or Microsoft account. But it's strictly optional and the Emby admin has complete control over this.
herstl22 1 Posted May 11, 2021 Author Posted May 11, 2021 Ok. Thank you. Hope it works because I still get no external connection.
herstl22 1 Posted May 11, 2021 Author Posted May 11, 2021 (edited) I tried to sign up but I get always back to the community Edited May 11, 2021 by herstl22
Guest Posted May 11, 2021 Posted May 11, 2021 Okay so what you would need to do now is go to your server and connect your account in EMBY Server to the email address you use to log in to the forum.. You have to enable the feature for the user.. and it will use the same credentials.
Carlo 4561 Posted May 11, 2021 Posted May 11, 2021 (edited) On 5/12/2021 at 2:59 AM, herstl22 said: I tried to sign up but I get always back to the community So to make this simple "herstl22" is your Emby Connect login name. Your Emby Connect password is the same as you used to login here (one and the same). You then type in this EC username in the optional field on this form https://s3.amazonaws.com/cdn.freshdesk.com/data/helpdesk/attachments/production/2043066401865/original/CPVAqeg6vPjV64l8_o-gwTkKh5AXc1eWgw.png?1574721474 Assuming you didn't setup SSL/Cert when setting up your Emby Server to be remotely accessible you then go to http://app.emby.media Follow the prompts to login to your server If you did setup a cert and have this working then you give your users https://app.emby.media (has the "s" for secure) You can check to make sure your server is setup for remote use by going to www.canyouseeme.org and running a test to port 8096 and/or 8920 (or whatever port is forwarded on your router). If this fails or you didn't setup remote use of your server then START FIRST here https://emby.media/support/articles/Connectivity.html Let us know how you make out. Edited November 6, 2025 by GrimReaper KB article link updated
herstl22 1 Posted May 11, 2021 Author Posted May 11, 2021 Now I get it. This is in the settings. I have 4 users but never used the option emby connect. Hope the external connection works than. If it works on Plex it must work with emby as well. Thank you
Carlo 4561 Posted May 11, 2021 Posted May 11, 2021 You may need to set this up manually in Emby but it's all spelled out in the link I gave you. If you get stuck or don't understand something, send me a PM and I can personally help you with the setup. 1
Luke 42237 Posted May 20, 2021 Posted May 20, 2021 @herstl22 were you able to link up with @cayars and resolve this?
herstl22 1 Posted June 19, 2021 Author Posted June 19, 2021 It worked for a while. Power is out and the same thing again
Luke 42237 Posted June 21, 2021 Posted June 21, 2021 @herstl22 are you still having an issue with this? Has your WAN ip address changed?
