rodainas 191 Posted November 23, 2020 Posted November 23, 2020 Multiepisodes arent showing up on emby. i.e. Episode two is missing on emby: Files: Emby: What am I doing wrong, I thought I was using the correct naming scheme.
Happy2Play 9799 Posted November 23, 2020 Posted November 23, 2020 Naming is correct. I had no issue testing this multi-episode file. What is your metadata provider order on the library? What are your library language settings? Did Emby create that nfo file?
rodainas 191 Posted November 23, 2020 Author Posted November 23, 2020 (edited) Am using local metadata, am scrapping my media with tinymediamanager before adding it to the library folders. Maybe the contents or format of the nfo created by tmm is different than the nfo created by emby and that difference could be the cause? Metadata order, although not activated because am using local: Library language: Global Library language setting: Edited November 23, 2020 by rodainas
Solution Happy2Play 9799 Posted November 23, 2020 Solution Posted November 23, 2020 I am guessing here but would assume your nfo does not contain the episodenumberend tag. Is it a option in TMM? Can you post the nfo. <episode>1</episode> <episodenumberend>2</episodenumberend> <season>4</season>
Happy2Play 9799 Posted November 23, 2020 Posted November 23, 2020 (edited) Also a wild guess but could be the same as this topic. 1 file multiple episodes not being recognised - General/Windows - Emby Community Edited November 23, 2020 by Happy2Play
rodainas 191 Posted November 23, 2020 Author Posted November 23, 2020 Yeah it doesnt have the episodenumberend tag, I dont see an option to add that tag on tmm settings. I'll check that post. Nfo contents: <?xml version="1.0" encoding="UTF-8" standalone="yes"?> <!--created on 2020-11-23 10:56:54 - tinyMediaManager 3.1.10--> <episodedetails> <title>Scylla, el libro negro</title> <originaltitle/> <showtitle>Prison Break</showtitle> <season>4</season> <episode>1</episode> <displayseason>-1</displayseason> <displayepisode>-1</displayepisode> <id>7056889</id> <uniqueid default="true" type="tvdb">7056889</uniqueid> <ratings/> <userrating>0.0</userrating> <plot>Michael venga la muerte de Sara, pero recibe una noticia inesperada. Michael y Lincoln reciben una oferta.</plot> <runtime>45</runtime> <thumb>https://artworks.thetvdb.com/banners/episodes/360115/7056889.jpg</thumb> <mpaa/> <premiered>2008-09-01</premiered> <aired>2008-09-01</aired> <watched>false</watched> <playcount/> <studio>FOX</studio> <credits>Matt Olmstead</credits> <director>Kevin Hooks</director> <trailer/> <dateadded>2020-11-23 10:42:23</dateadded> <epbookmark/> <code/> <fileinfo> <streamdetails> <video> <codec/> <aspect>0.0</aspect> <width>0</width> <height>0</height> <durationinseconds>0</durationinseconds> <stereomode/> </video> </streamdetails> </fileinfo> <!--tinyMediaManager meta data--> <source>UNKNOWN</source> <original_filename>Prison Break S04E01-E02 [GDRIVELatinoHD.SITE].mkv</original_filename> <user_note/> </episodedetails> <episodedetails> <title>La incursión</title> <originaltitle/> <showtitle>Prison Break</showtitle> <season>4</season> <episode>2</episode> <displayseason>-1</displayseason> <displayepisode>-1</displayepisode> <id>7056891</id> <uniqueid default="true" type="tvdb">7056891</uniqueid> <ratings/> <userrating>0.0</userrating> <plot>Para obtener una copia de la tarjeta Scylla, el equipo entra en la casa de un nuevo miembro de la Compañía. T-Bag llega a los extremos.</plot> <runtime>45</runtime> <thumb>https://artworks.thetvdb.com/banners/episodes/360115/7056891.jpg</thumb> <mpaa/> <premiered>2008-09-01</premiered> <aired>2008-09-01</aired> <watched>false</watched> <playcount/> <studio>FOX</studio> <credits>Zack Estrin</credits> <director>Bobby Roth</director> <trailer/> <dateadded>2020-11-23 10:42:23</dateadded> <epbookmark/> <code/> <fileinfo> <streamdetails> <video> <codec/> <aspect>0.0</aspect> <width>0</width> <height>0</height> <durationinseconds>0</durationinseconds> <stereomode/> </video> </streamdetails> </fileinfo> <!--tinyMediaManager meta data--> <source>UNKNOWN</source> <original_filename>Prison Break S04E01-E02 [GDRIVELatinoHD.SITE].mkv</original_filename> <user_note/> </episodedetails>
Happy2Play 9799 Posted November 23, 2020 Posted November 23, 2020 Until Emby supports this newer multiple episodedetails you will not see multi-episodes as linked above. And primary link Reading and writing of nfo for multi-part episodes is wrong - General/Windows - Emby Community @Luke any update on multiple episodedetails support?
rodainas 191 Posted November 23, 2020 Author Posted November 23, 2020 I now understand, thank you so much for the explanation.
