BillOatman 597 Posted August 21, 2020 Posted August 21, 2020 (edited) Hi. his picture is my setup. I have channels sorted by channel number. You can see I have channels 2-4 defined. But I do not see channels 2 and 3 in the guide. What can I do to get them to show? They all 3 share the sane guide info. It has been several days since I added these channels and they are still not showing up. I have looked in the web player, Android TV app, and firetv app. They show up and work in other applications. Thanks. Edited August 21, 2020 by BillOatman Added plaeyrs tested.
Carlo 4561 Posted August 21, 2020 Posted August 21, 2020 (edited) Hi, You need to review your mapping. Channels 2 through 4 are all mapped to channel 1 in that picture. Edited August 21, 2020 by cayars
Carlo 4561 Posted August 21, 2020 Posted August 21, 2020 (edited) Here is one of our Knowledge base articles on mapping channels: https://emby.media/support/articles/Live-TV-Channel-Mapping.html Here is the master article for Live TV Setup: https://emby.media/support/articles/Live-TV.html Edited November 6, 2025 by GrimReaper KB articles links updated
BillOatman 597 Posted August 21, 2020 Author Posted August 21, 2020 (edited) @cayars Thanks for all the information. It looks to me that the mapping stuff in Emby is mapping channels to guide data. And my intent was to have those 3 BBC1 channels use the same guide data since they are the same channel just different streams. Sorry if I am misunderstanding something simple, but is that not possible in Emby? EDIT: Yes that seems to be the case. I changed the mapping to different guide entries and those channels now show up in my listing ... albeit with 2 channels now having the wrong guide data. What do I have to do, somehow get the guide data duplicated 2 more times to work properly? Edited August 21, 2020 by BillOatman
Carlo 4561 Posted August 21, 2020 Posted August 21, 2020 I don't believe there is an easy way to do this currently in Emby but in the new Live TV project this will be much easier to handle this type of thing and a whole lot more. The way I personally handle this type of thing with IPTV is run it all through xTeVe and remove the duplicate channels.
Solution BillOatman 597 Posted August 21, 2020 Author Solution Posted August 21, 2020 Thanks again @cayars. But in this case I want the 3 different streams in case 1 or 2 of them are down at any given time. I used IPTVBoss to get 3 different correct BBC1 guide entries and mapped 1 each. Klunky and a very odd restriction for Emby to have, but it is working. Thanks again!
Carlo 4561 Posted August 21, 2020 Posted August 21, 2020 OK glad you got it working in a way that benefits you.
