herki 3 Posted August 11, 2020 Posted August 11, 2020 Hi there, I have a log file - but not sure If I'm comfortable exposing user IP addresses in the file. The log is huge - if that is all that would be exposed I guess I can post it here. Otherwise can I PM someone?
herki 3 Posted August 11, 2020 Author Posted August 11, 2020 2 minutes ago, herki said: Hi there, I have a log file - but not sure If I'm comfortable exposing user IP addresses in the file. The log is huge - if that is all that would be exposed I guess I can post it here. Otherwise can I PM someone? A lot of this - *** Error Report *** Version: 4.4.3.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.19.6.64 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 12 Program data path: /config Application directory: /system MediaBrowser.Common.Extensions.ResourceNotFoundException: MediaBrowser.Common.Extensions.ResourceNotFoundException: 271048 does not have an image of type Art at MediaBrowser.Api.Images.ImageService.GetImage(ImageRequest request, Int64 itemId, BaseItem item, Boolean isHeadRequest) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Api TargetSite: Void MoveNext()
Luke 42246 Posted August 11, 2020 Posted August 11, 2020 Hi there, please attach the complete emby server log. thanks.
herki 3 Posted August 11, 2020 Author Posted August 11, 2020 (edited) removed. Edited August 12, 2020 by herki
herki 3 Posted August 11, 2020 Author Posted August 11, 2020 Also some context if it helps. After running smooth for months - was getting some buffering reported by some of my users and myself. Initially gave Emby container a restart but didn't fix. Then I upgraded Emby to latest and did notice that the library images (The 2 "My Media") Posters changed the posters in there. All the metadata still seemed to be there - but everything has been slow since the first report of buffering now.
herki 3 Posted August 11, 2020 Author Posted August 11, 2020 1 hour ago, Luke said: Hi there, please attach the complete emby server log. thanks. Sorry not sure if I pinged you correctly.
Luke 42246 Posted August 11, 2020 Posted August 11, 2020 Try shutting down the software called Ombi, then leave it shut down and see if your Emby Server performs better. Thanks.
Happy2Play 9814 Posted August 11, 2020 Posted August 11, 2020 (edited) More then likely the same as here. https://emby.media/community/index.php?/topic/84072-emby-ombi-massive-slowndown/ Please attach log files instead of copy and paste to the forum next time, thanks. Edited August 11, 2020 by Happy2Play
