spongygr 3 Posted April 18, 2020 Posted April 18, 2020 Hi, I just got a new box and having problems with the app emby for android tv The Model is the A95X F3 Air TV-Box with S905X3 SoC the firmware i m running is the latest https://androidpctv.com/firmware-a95x-f3-air-update-rom/ the android version is 9 and the kernel version is 4.9.113 I tried with both the 1.7.92g from play and the 1.7.78.g and 1.7.99g. The problem i m experiencing is that after i enter my username and password it moves to the next screen where its loading without showing any media its not responding and then it crashes. i have also installed the emby for android and it works just fine. my emby version is 4.4.0.40 attached the log file
serpi 82 Posted April 18, 2020 Posted April 18, 2020 (edited) On these boxes it's often a problem, that they are not real AndroidTV boxes. You could try to use the normal Emby fpr Android, as this now also has a TV view. Maybe this version runs better, I don't think it needs any spcial AndroidTV functions. Ciao, Alfred Edited April 18, 2020 by serpi
ebr 16338 Posted April 18, 2020 Posted April 18, 2020 Hi. Yes, more than likely, you are running a non-Android TV rom. If you can find a suitable rom for the device it may work. @@clarkss12
CBers 7554 Posted April 18, 2020 Posted April 18, 2020 @@spongygr Try the Android Auto version of the Emby for Android app here: https://emby.media/community/index.php?/topic/82319-android-auto-testing/ It might work on your device, it might not.
spongygr 3 Posted April 18, 2020 Author Posted April 18, 2020 Thank you all for the quick reply. Didnt know that emby for android has an TV view option now. I removed emby for android tv and installed emby for android. Enabled the tv view and its working like a charm. Tnx again. 1
clarkss12 304 Posted April 19, 2020 Posted April 19, 2020 That is a very popular box, lots of options for it.
