LookyLooky 0 Posted February 17, 2020 Posted February 17, 2020 Hi, after adding some new Films I recogniced that they weren't added like they used to be before. Poorly I made the mistake to remove the old bib and create a new one before reading here. I seems to be a common problem at this time: https://emby.media/community/index.php?/topic/81482-error-scanning-files/ Can someone tell me a working solution please?
Luke 42246 Posted February 18, 2020 Posted February 18, 2020 Hi there, can you please go over an example? Thanks.
LookyLooky 0 Posted February 18, 2020 Author Posted February 18, 2020 For exampleA complete scan only scans a part of TV shows. Rest is not scanned. embyserver.txt
LookyLooky 0 Posted February 21, 2020 Author Posted February 21, 2020 There are many errors in the log: Error HttpServer: Error processing request Error App: Error in TheMovieDb Error ProviderManager: Error in metadata saver The server worked well for a long time. I regularly install the updates. This is really annoying!
Luke 42246 Posted February 21, 2020 Posted February 21, 2020 There are many errors in the log: Error HttpServer: Error processing request Error App: Error in TheMovieDb Error ProviderManager: Error in metadata saver The server worked well for a long time. I regularly install the updates. This is really annoying! Did you see this? 2020-02-18 14:10:45.724 Error ProviderManager: Error in metadata saver *** Error Report *** Version: 4.3.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.19.0.8 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.IO.IOException: System.IO.IOException: Read-only file system Specifically it says: Read-only file system Why do you feel this is an Emby problem?
LookyLooky 0 Posted February 21, 2020 Author Posted February 21, 2020 Did you see this? 2020-02-18 14:10:45.724 Error ProviderManager: Error in metadata saver *** Error Report *** Version: 4.3.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.19.0.8 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system Yes I saw it. Like I already said: I am running this server about two years without problems. I didn't change anything at the file-system: ls -al /opt/emby-server/ drwxr-xr-x 8 root root 4096 Feb 21 22:51 . drwxr-xr-x 3 root root 4096 Feb 21 22:51 .. drwxr-xr-x 2 root root 4096 Feb 21 22:51 bin drwxr-xr-x 4 root root 4096 Feb 21 22:51 etc drwxr-xr-x 4 root root 16384 Feb 21 22:51 lib drwxr-xr-x 30 root root 4096 Feb 21 22:51 licenses drwxr-xr-x 3 root root 4096 Feb 21 22:51 share drwxr-xr-x 5 root root 20480 Feb 21 22:51 system ls -al /var/lib/emby/ insgesamt 48 drwxr-xr-x 9 emby emby 4096 Feb 21 22:54 . drwxr-xr-x 25 root root 4096 Feb 21 22:51 .. -rw-r--r-- 1 emby emby 220 Apr 18 2019 .bash_logout -rw-r--r-- 1 emby emby 3526 Apr 18 2019 .bashrc drwxr-xr-x 6 emby emby 4096 Feb 21 22:56 cache drwxr-xr-x 4 emby emby 4096 Feb 21 22:51 config drwxr-xr-x 4 emby emby 4096 Feb 21 22:56 data drwxr-xr-x 2 emby emby 4096 Feb 21 22:56 logs drwxr-xr-x 3 emby emby 4096 Feb 21 22:54 metadata drwxr-xr-x 2 emby emby 4096 Feb 21 22:51 plugins -rw-r--r-- 1 emby emby 807 Apr 18 2019 .profile drwxr-xr-x 3 emby emby 4096 Feb 21 22:51 root ls -al /datenbank/ insgesamt 64 drwxr-xr-x 11 emby emby 4096 Feb 21 00:10 . drwxr-xr-x 23 root root 4096 Feb 9 06:05 .. drwxr-xr-x 16 emby emby 4096 Feb 15 19:48 cache drwxr-xr-x 9 emby emby 4096 Feb 17 00:10 'Emby Backup - 2020-02-17 00.10.0 - Auto' drwxr-xr-x 9 emby emby 4096 Feb 18 00:10 'Emby Backup - 2020-02-18 00.10.0 - Auto' drwxr-xr-x 9 emby emby 4096 Feb 19 00:10 'Emby Backup - 2020-02-19 00.10.0 - Auto' drwxr-xr-x 9 emby emby 4096 Feb 20 00:10 'Emby Backup - 2020-02-20 00.10.0 - Auto' drwxr-xr-x 9 emby emby 4096 Feb 21 00:10 'Emby Backup - 2020-02-21 00.10.0 - Auto' drwx------ 2 root root 16384 Aug 12 2018 lost+found drwxr-xr-x 5 emby emby 4096 Aug 15 2018 metadata drwxr-xr-x 2 emby emby 12288 Feb 18 22:14 transcoding-temp Why do you feel this is an Emby problem? I just installed emby server on a new clean system just to compare file permissions - no difference
Luke 42246 Posted February 21, 2020 Posted February 21, 2020 It appears you enabled saving of nfo files but the server does not have write access to your media folders.
LookyLooky 0 Posted February 22, 2020 Author Posted February 22, 2020 It appears you enabled saving of nfo files but the server does not have write access to your media folders. Saving of NFO is enabled, but not saving in media folders. Like I already said: I didn't make any changes since installation. Only updates of system and emby itself.
Happy2Play 9814 Posted February 22, 2020 Posted February 22, 2020 Saving of NFO is enabled, but not saving in media folders. Like I already said: I didn't make any changes since installation. Only updates of system and emby itself. If you enabled Metadata savers NFO, then it is saved with media. With the option disabled info is only written to database.
Luke 42246 Posted February 24, 2020 Posted February 24, 2020 Saving of NFO is enabled, but not saving in media folders. Because of the read-only file system error that is filling up your log files. The server is trying to save the nfo files to your media directories, but your system is not allowing it. Does this address your concern?
mprecup 0 Posted February 25, 2020 Posted February 25, 2020 I'm also having this error. I've read through a couple of threads similar and have a couple of questions. Which directory is the server having the issues with? /opt/emby-server is root root and /TV is emby emby. The server can create a folder in /TV. So, is it trying to save the nfo files in /opt/emby-server/ somewhere? Also, is saving nfo files to the media directories necessary? Thank you.
Luke 42246 Posted February 27, 2020 Posted February 27, 2020 Which directory is the server having the issues with? /opt/emby-server is root root and /TV is emby emby. The server can create a folder in /TV. So, is it trying to save the nfo files in /opt/emby-server/ somewhere? Please attach the same log files that were requested from the other user. Thanks. Also, is saving nfo files to the media directories necessary? That is entirely your personal preference.
mprecup 0 Posted February 27, 2020 Posted February 27, 2020 I've worked it out. This was the error I was getting. I turned off NFO and started poking around through syslog and checking directories with ls -al. I ended up doing chown -R emby:emby /mnt/md0 and added my user to the emby group. Restarted everything and re added NFO's. 2020-02-26 10:37:43.165 Error App: Error running postscan task *** Error Report *** Version: 4.1.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.15.0.88 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 32 Program data path: /var/lib/emby Application directory: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: InternalServerError at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Tvdb.TvdbPrescanTask.GetSeriesIdsToUpdate(IEnumerable`1 existingSeriesIds, String lastUpdateTime, CancellationToken cancellationToken) at Tvdb.TvdbPrescanTask.Run(IProgress`1 progress, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.LibraryManager.RunPostScanTasks(IProgress`1 progress, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() Thank you!
