Dan_Austin 71 Posted February 13, 2020 Posted February 13, 2020 I am not sure if this is a feature request or a bug report. I don't see it described in any forum, but that may be my search failing to match the terms another poster used. I recently had a very brief power-outage. My emby server and all of my network recovered properly, except my cable modem. It just needed a reset, but what I found odd is that I had no guide data, despite an update just before the outage. If emby should already be storing the guide data either in the database or other file, it does not seem to be.(bug) If it is only storing guide data in memory, then it should also write it out to the filesystem. That way if the internet is down post restart, the system could continue to function until the last day in the stored guide. (feature)
Luke 42246 Posted February 13, 2020 Posted February 13, 2020 Hi there, yes this is something we'll look to improve in future updates. Thanks.
