iNfRaSoNiC 1 Posted February 8, 2020 Posted February 8, 2020 (edited) Hello, Samsung model number: QE65Q70RA Samsung firmware version: 1335 Samsung Emby client version #: 4.3.1.0 please check the image I've provided. I have an issue with the external subtitles lining as you can see below. The text after "..." should appear on a new row but instead its on the same and this is causing issues with big lines also it is very unpleasant to watch and read. Can you look into this issue? Here is the text extracted from the subs 1 00:00:00,333 --> 00:00:03,233 <i>Досега в "Стрелата"...</i> - Наистина ли смяташ, As you can see there are two different rows. Other programs and Samsung original player are displaying this as it should so the problem must be with the Emby app for Tizen. Also the fire is direct playing ( no transcoding ) Also just to mention the issue is not present when using the web emby player ( as shown in the screens below ) Thank you in advance. Edited February 8, 2020 by iNfRaSoNiC
Luke 42242 Posted February 8, 2020 Posted February 8, 2020 Hi there, what version of the app are you running?
iNfRaSoNiC 1 Posted February 8, 2020 Author Posted February 8, 2020 (edited) Hi there, what version of the app are you running? Hi I am using the latest one - 1.0.73 Edited February 10, 2020 by iNfRaSoNiC
iNfRaSoNiC 1 Posted February 15, 2020 Author Posted February 15, 2020 I will check today with 1.0.74 Sent from my SM-N975F using Tapatalk
FrostByte 5453 Posted February 15, 2020 Posted February 15, 2020 where can download 1.0.74 or 1.0.73? The latest version should always be on GitHub https://emby.media/community/index.php?/topic/74969-samsung-tizen-smarttv-2015-present-beta-app-install-from-usb/
gzbenson 0 Posted February 15, 2020 Posted February 15, 2020 The latest version should always be on GitHub https://emby.media/community/index.php?/topic/74969-samsung-tizen-smarttv-2015-present-beta-app-install-from-usb/ https://github.com/MediaBrowser/Emby.Releases/raw/master/tizen/tizen.zip this link is not work ...
Luke 42242 Posted February 15, 2020 Posted February 15, 2020 The link in the instructions page works just fine.
FrostByte 5453 Posted February 15, 2020 Posted February 15, 2020 https://github.com/MediaBrowser/Emby.Releases/raw/master/tizen/tizen.zip this link is not work ... Ya, what you posted is not the same as the one in the instructions. I just downloaded it again myself with no problems, so it should be good
gzbenson 0 Posted February 15, 2020 Posted February 15, 2020 Ya, what you posted is not the same as the one in the instructions. I just downloaded it again myself with no problems, so it should be good i dont know why i cant download the zip file from this link ,Could you send me the zip file directly by email ? gzbenson@.com
Luke 42242 Posted February 15, 2020 Posted February 15, 2020 The link posted in this thread is not the same as the one in the instructions. Just use the one in the instructions.
burtmadsen 0 Posted February 27, 2020 Posted February 27, 2020 please check the image I've provided. I have an issue with the external subtitles lining as you can see below. The text after "..." should appear on a new row but instead its on the same and this is causing issues with big lines also it is very unpleasant to watch and read. Can you look into this issue? I have to this issue with external subtitles lining, with latest version of app. I hope that you will solve this soon.
Luke 42242 Posted February 27, 2020 Posted February 27, 2020 Hi @@burtmadsen, can you please describe your issue? Thanks.
iNfRaSoNiC 1 Posted February 27, 2020 Author Posted February 27, 2020 Hi @@burtmadsen, can you please describe your issue? Thanks.Luke, I think he is referring to the original issue described in the first post. But this issue is not new for the new version only. It's just a bug that is not fixed yet. Sent from my SM-N975F using Tapatalk
burtmadsen 0 Posted February 28, 2020 Posted February 28, 2020 Luke, I think he is referring to the original issue described in the first post. But this issue is not new for the new version only. It's just a bug that is not fixed yet. Sent from my SM-N975F using Tapatalk This is exactly what I wanted to say. Just to add that i have the same problem. Cheers!
Luke 42242 Posted February 29, 2020 Posted February 29, 2020 Thanks for reporting. We'll take a look.
toster 0 Posted May 17, 2020 Posted May 17, 2020 There is any chance to fix that problem? I have same issue that OP has described (one lined subtitles). App version 1.0.78
luizbacci 0 Posted July 14, 2020 Posted July 14, 2020 (edited) Hello. I'm new on Emby (just moved from Plex) and I'm facing the same "issue". I'm running the latest emby app (1.0.80) on UN58MU6120G Samsung TV. Edited July 14, 2020 by luizbacci
iNfRaSoNiC 1 Posted January 1, 2021 Author Posted January 1, 2021 Hello guys and Happy new Year. Is there any update here? I am using the latest server + tizen app but still have one lined subtitles ?
SamES 1084 Posted January 1, 2021 Posted January 1, 2021 Let me test this again. I can't recall, did you previously provide the media info and/or a sample of this case?
iNfRaSoNiC 1 Posted January 2, 2021 Author Posted January 2, 2021 8 hours ago, SamES said: Let me test this again. I can't recall, did you previously provide the media info and/or a sample of this case? Yes, Sam, I did. Check the op. Also this is happening with everything no matter the format or codec.
SamES 1084 Posted January 2, 2021 Posted January 2, 2021 Can you give me a copy of the external srt and some times in it that you know should be on two lines? I have an idea how we might be able to fix this 1
iNfRaSoNiC 1 Posted January 2, 2021 Author Posted January 2, 2021 (edited) 3 hours ago, SamES said: Can you give me a copy of the external srt and some times in it that you know should be on two lines? I have an idea how we might be able to fix this Thanks, I will post them later today The.Unfamiliar.2020.1080p.WEBRip.DD5.1.X.264-EVO.srt Here, you can see for example in line 5 "5 00:01:55,486 --> 00:01:59,657 Знаеш ли кой е това? - Здравей, Лили. Аз съм майка ти." On my Samsung TV I am getting " Знаеш ли кой е това? - Здравей, Лили. Аз съм майка ти. " These are Cyrillic subtitles but it does not matter. Edited January 2, 2021 by iNfRaSoNiC
SamES 1084 Posted January 3, 2021 Posted January 3, 2021 Thanks, I'll let you know if we have options to resolve this
