fbrassin 47 Posted January 9, 2020 Posted January 9, 2020 Hello, i have 2 libraries. The first has all my movies. The second has got only some of them, (the ones i want to watch first) If i start watching a movie that is in both libraries and stop it, i have that movie twice in continue watching. Is there is way to have it only once? I managed to have once, but removing sencond library from home, but i want to leave my library in home. Tnx
Luke 42246 Posted January 9, 2020 Posted January 9, 2020 @@Happy2Play can you link him to existing topics about this? thanks.
Happy2Play 9814 Posted January 10, 2020 Posted January 10, 2020 May need to elaborate on these library setups. https://emby.media/community/index.php?/topic/67600-two-copies-of-move-in-the-continue-watching/ https://emby.media/community/index.php?/topic/80219-emby-showing-duplicate-entries-in-the-%E2%80%9Ccontinue-watching%E2%80%9D-section/
fbrassin 47 Posted January 11, 2020 Author Posted January 11, 2020 Sorry, i didn't understand well. I manage to merge the two movies in the home screen manually, but don't understand if there is an option to merge them by default.
Luke 42246 Posted January 11, 2020 Posted January 11, 2020 The only automatic merging for movies would be putting them in the same folder and using our multi version naming conventions.
Luke 42246 Posted January 11, 2020 Posted January 11, 2020 Have you explored the multi-select menu to merge them?
levander 97 Posted January 11, 2020 Posted January 11, 2020 @@fbrassin I also have some movies in 2 or more libraries and I never had similar problem. In my scenario the folders that are in both libraries must be put as separate paths. That folder mustn't be subfolder of any folder that are already as path in one of the library. I hope I'm clear enough and that it helps.
fbrassin 47 Posted January 12, 2020 Author Posted January 12, 2020 My situation is like this. Library 1 (with all the movies): /media/Movies/DIR_MOVIE Then i have a script that reads my watchlist on trakt and makes links of the movies that are in /media/movies/DIR_MOVIE in a new folder called /media/watchlist/movies with a subforder for each movie Library 2 points to /media/watchlist/movie When i watch a movie that is in the watchlist and stop it i see the movie twice in continue watching.
levander 97 Posted January 12, 2020 Posted January 12, 2020 Ah, I misunderstood. You have duplicates. Just ideas: you could create new user for watchlist links or tell your script to just tag your movies to watch. Or you wait for emby watchlist support.
fbrassin 47 Posted January 12, 2020 Author Posted January 12, 2020 (edited) I'd like to wait watchlist support, but it is a so long reguest that i don't think it will be ever developed. Edited January 12, 2020 by fbrassin
