densma 12 Posted December 29, 2019 Posted December 29, 2019 7.1 or more channels are being transcoded with transcode reason : Audio Channels over limit is this limitation of emby? notice both DTS and DD i'm using nvidia shield.
Luke 42246 Posted December 29, 2019 Posted December 29, 2019 Hi, did you enable the audio downmixing option in the app?
ebr 16338 Posted December 29, 2019 Posted December 29, 2019 Hi. With the exception of DD+ specifically, this would be a limitation of your audio system. Do you have a 7.1 system connected?
densma 12 Posted January 19, 2020 Author Posted January 19, 2020 This is DD+ 7.1 checking other audio AAC, OPUS,DTS MASTER, DOLBY ATMOS works well. i guess not much support for DD+ 7.1? is this limitation of ffmpeg? Hi. With the exception of DD+ specifically, this would be a limitation of your audio system. Do you have a 7.1 system connected?
ebr 16338 Posted January 20, 2020 Posted January 20, 2020 Okay, your original post said DTS too. The issue with DD+ 7.1 has supposedly been addressed by Google in their development branch but we have not tested it yet. For now, that must be transcoded down.
densma 12 Posted January 21, 2020 Author Posted January 21, 2020 yeah. sorry that was my misunderstanding. its just DD+ 7.1 only Okay, your original post said DTS too. The issue with DD+ 7.1 has supposedly been addressed by Google in their development branch but we have not tested it yet. For now, that must be transcoded down.
densma 12 Posted January 28, 2020 Author Posted January 28, 2020 I tested this on Plex using same system and it works. so its not Andriod limitation. same with subtitle issue reported on the link below works well on Plex. https://emby.media/community/index.php?/topic/67622-transparent-subtitle/ Okay, your original post said DTS too. The issue with DD+ 7.1 has supposedly been addressed by Google in their development branch but we have not tested it yet. For now, that must be transcoded down.
ebr 16338 Posted January 28, 2020 Posted January 28, 2020 Hi. As I said, it is an issue with the Google player we are using and they indicate they have addressed it in their development branch.
densma 12 Posted January 28, 2020 Author Posted January 28, 2020 what deos that mean? when are we going to see update for this? Hi. As I said, it is an issue with the Google player we are using and they indicate they have addressed it in their development branch.
ebr 16338 Posted January 28, 2020 Posted January 28, 2020 Most likely in the next beta cycle of the app. 1
densma 12 Posted January 30, 2020 Author Posted January 30, 2020 one of my user is able to play DD+8 with no transcoding. using XBR-65A1E and AndroidTv 1.7.54g I am using Nvidia shield with version 1.7.77g registered. Server is 4.4.0.10 Most likely in the next beta cycle of the app.
densma 12 Posted January 30, 2020 Author Posted January 30, 2020 Sorry for confusion. i meant its not working for me using nvidia shield with version 1.7.77g. maybe i can try official version. i think my nvidia shield is using beta version. i notice now only audio is transcoded which is better than video/audio being transcoded That's great news, thanks !
ebr 16338 Posted January 30, 2020 Posted January 30, 2020 one of my user is able to play DD+8 with no transcoding. using XBR-65A1E and AndroidTv 1.7.54g I am using Nvidia shield with version 1.7.77g registered. Server is 4.4.0.10 Correct. This issue is specific to the Shield. As I said, you aren't going to see any change in behavior until some time in the next beta cycle for the app. Thanks.
densma 12 Posted February 7, 2020 Author Posted February 7, 2020 any update? was this included in the last update? Correct. This issue is specific to the Shield. As I said, you aren't going to see any change in behavior until some time in the next beta cycle for the app. Thanks.
ebr 16338 Posted February 8, 2020 Posted February 8, 2020 This has not been included in our beta yet. We don't typically bring in the development branch of the player. I believe this is close to release by Google, however.
densma 12 Posted February 18, 2020 Author Posted February 18, 2020 Happy to report this has been resloved now. i guess by google update? DD+7.1 works well with Shield
FrostByte 5454 Posted February 18, 2020 Posted February 18, 2020 It was the updated Google exoplayer 2.11.2 in the latest beta version of the android app which had the fix
ebr 16338 Posted February 18, 2020 Posted February 18, 2020 Actually, this is only in beta right now. Thanks. 1
