Malmgren 17 Posted November 27, 2019 Posted November 27, 2019 Hi. I've got quite many errors like the following in my log: 2019-11-27 14:13:54.821 Info App: ProcessRun 'extract-image' Execute: /opt/emby-server/bin/ffmpeg -ss 15:08:26.480 -f avi -threads 1 -i file:"/mnt/nas/public/Serier/Trigger Happy TV/3x01 - Angry Cyclist.avi" -an -sn -threads 0 -vframes 1 -vf "scale=600:trunc(ow/a/2)*2,thumbnail=24" -f image2 "/var/lib/emby/cache/temp/66fdc849-aa59-4b9d-88de-4de3223c5051.jpg" 2019-11-27 14:13:56.331 Error ImageExtraction: ffmpeg image extraction failed for file:"/mnt/nas/public/Serier/Trigger Happy TV/3x01 - Angry Cyclist.avi" (output file not found) 2019-11-27 14:13:56.332 Error ImageExtraction: Thumbnail-Filter extraction failed, will attempt standard way. Input: file:"/mnt/nas/public/Serier/Trigger Happy TV/3x01 - Angry Cyclist.avi" 2019-11-27 14:13:56.333 Info App: ProcessRun 'extract-image' Execute: /opt/emby-server/bin/ffmpeg -ss 15:08:26.480 -f avi -threads 1 -i file:"/mnt/nas/public/Serier/Trigger Happy TV/3x01 - Angry Cyclist.avi" -an -sn -threads 0 -vframes 1 -vf "scale=600:trunc(ow/a/2)*2" -f image2 "/var/lib/emby/cache/temp/15eb7a0c-91ab-4486-8f12-3b2b7ab17f54.jpg" 2019-11-27 14:13:57.849 Error ImageExtraction: ffmpeg image extraction failed for file:"/mnt/nas/public/Serier/Trigger Happy TV/3x01 - Angry Cyclist.avi" (output file not found) 2019-11-27 14:13:57.855 Error App: Error in Screen Grabber *** Error Report *** Version: 4.3.0.30 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_arm64.deb Operating system: Unix 4.4.190.1233 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.Exception: System.Exception: ffmpeg image extraction failed for file:"/mnt/nas/public/Serier/Trigger Happy TV/3x01 - Angry Cyclist.avi" (output file not found) at Emby.Server.MediaEncoding.ImageExtraction.ImageExtractionManager.ExtractImageInternal(ReadOnlyMemory`1 inputPath, ReadOnlyMemory`1 container, MediaStream videoStream, Nullable`1 streamIndex, Nullable`1 threedFormat, Nullable`1 offset, Boolean useThumbNailFilter, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.ImageExtraction.ImageExtractionManager.ExtractImage(ReadOnlyMemory`1 inputPath, ReadOnlyMemory`1 container, MediaStream videoStream, Nullable`1 streamIndex, MediaProtocol protocol, Boolean isAudio, Nullable`1 threedFormat, Nullable`1 offset, CancellationToken cancellationToken) at MediaBrowser.Providers.MediaInfo.VideoImageProvider.GetVideoImage(Video item, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.ItemImageProvider.RefreshFromProvider(BaseItem item, IDynamicImageProvider provider, ImageRefreshOptions refreshOptions, TypeOptions savedOptions, LibraryOptions libraryOptions, ICollection`1 downloadedImages, RefreshResult result, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() /opt/emby-server/bin/ffmpeg -ss 15:08:26.480 -f avi -threads 1 -i file:"/mnt/nas/public/Serier/Trigger Happy TV/3x01 - Angry Cyclist.avi" -an -sn -threads 0 -vframes 1 -vf "scale=600:trunc(ow/a/2)*2,thumbnail=24" -f image2 "/var/lib/emby/cache/temp/66fdc849-aa59-4b9d-88de-4de3223c5051.jpg" I started digging and it turns out I can't even run ffmpeg manually: root@rock64:/opt/emby-server# /opt/emby-server/bin/ffprobe /opt/emby-server/bin/ffprobe: error while loading shared libraries: libavdevice.so.58: cannot open shared object file: No such file or directory Don't really know how this works, but there is a libavdevice.so.58: root@rock64:/opt/emby-server# file /opt/emby-server/lib/libavdevice.so.58 /opt/emby-server/lib/libavdevice.so.58: symbolic link to libavdevice.so.58.9.100 root@rock64:/opt/emby-server# file /opt/emby-server/lib/libavdevice.so.58.9.100 /opt/emby-server/lib/libavdevice.so.58.9.100: ELF 64-bit LSB shared object, ARM aarch64, version 1 (SYSV), dynamically linked, BuildID[sha1]=8f0dd676c354fa7436821e7094698e36f6f32db7, stripped Don't really know where to continue digging? This is the official 4.3.0.30 package for arm64, running on Debian 10.02.
Luke 42246 Posted November 27, 2019 Posted November 27, 2019 Hi there, you can't run our ffmpeg directly without first setting up things such as environment variables. It's something we can try to document when we have a chance. As for your issue, since you're on arm64 I believe it is probably related to this: https://emby.media/community/index.php?/topic/79567-server-crash-when-i-try-to-play-a-movie/ Strangely the problems are not observed on the beta channel even though they currently have identical code, so we're currently trying to chase down what the difference is. Thanks.
Malmgren 17 Posted November 28, 2019 Author Posted November 28, 2019 Yep, I kinda suspected it could be related. Thanks for looking into it! Please tell me if there's anything more I can do to help. /Daniel
alucryd 318 Posted December 1, 2019 Posted December 1, 2019 @@Malmgren Please run these lines first and try again: APP_DIR=/opt/emby-server export AMDGPU_IDS=$APP_DIR/share/libdrm/amdgpu.ids if [ -z $EMBY_DATA ]; then if [ -d /var/lib/emby-server ]; then export EMBY_DATA=/var/lib/emby-server else export EMBY_DATA=/var/lib/emby fi fi export FONTCONFIG_PATH=$APP_DIR/etc/fonts export LD_LIBRARY_PATH=$APP_DIR/lib:$APP_DIR/lib/samba export LIBVA_DRIVERS_PATH=$APP_DIR/lib/dri:/usr/lib/x86_64-linux-gnu/dri:/usr/lib64/dri:/usr/lib/dri if [ -n $LIBVA_DRIVERS_DIR ]; then export LIBVA_DRIVERS_PATH=$LIBVA_DRIVERS_PATH:$LIBVA_DRIVERS_DIR fi export SSL_CERT_FILE=$APP_DIR/etc/ssl/certs/ca-certificates.crt Then make sure to be in the /opt/emby-server directory before running the ffmpeg binary, as the loader path is relative to make the whole installation more portable.
Malmgren 17 Posted December 1, 2019 Author Posted December 1, 2019 Yep, after doing those exports the command runs. I ran the command with the exact same parameters that Emby is doing and got the same result (no output file was created). Not really clear on why though. Here is the output: root@rock64:/opt/emby-server# /opt/emby-server/bin/ffmpeg -ss 15:08:26.480 -f avi -threads 1 -i file:"/mnt/nas/public/Serier/Trigger Happy TV/3x01 - Angry Cyclist.avi" -an -sn -threads 0 -vframes 1 -vf "scale=600:trunc(ow/a/2)*2,thumbnail=24" -f image2 "/var/lib/emby/cache/temp/66fdc849-aa59-4b9d-88de-4de3223c5051.jpg" ffmpeg version 4.3.0-emby_2019_11_09 Copyright (c) 2000-2019 the FFmpeg developers and softworkz for Emby LLC built with gcc 7.4.1 (Linaro GCC 7.4-2019.02) 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] Execution Date: 2019-12-01 15:58:21 Input #0, avi, from 'file:/mnt/nas/public/Serier/Trigger Happy TV/3x01 - Angry Cyclist.avi': Duration: 01:21:15.20, start: 0.000000, bitrate: 1141 kb/s Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 512x384 [SAR 1:1 DAR 4:3], 999 kb/s, Level 5, 29.97 fps, 29.97 tbr, 29.97 tbn, 29.97 tbc Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, fltp, 128 kb/s Stream mapping: Stream #0:0 -> #0:0 (mpeg4 (native) -> mjpeg (native)) Press [q] to stop, [?] for help [mpeg4 @ 0x3188a180] Video uses a non-standard and wasteful way to store B-frames ('packed B-frames'). Consider using the mpeg4_unpack_bframes bitstream filter without encoding but stream copy to fix it. [swscaler @ 0x319662e0] deprecated pixel format used, make sure you did set range correctly Output #0, image2, to '/var/lib/emby/cache/temp/66fdc849-aa59-4b9d-88de-4de3223c5051.jpg': Metadata: encoder : Lavf58.31.104 Stream #0:0: Video: mjpeg, yuvj444p(pc), 600x450 [SAR 1:1 DAR 4:3], q=2-31, 200 kb/s, 29.97 fps, 29.97 tbn, 29.97 tbc Metadata: encoder : Lavc58.56.101 mjpeg Side data: cpb: bitrate max/min/avg: 0/0/200000 buffer size: 0 vbv_delay: N/A frame= 0 fps=0.0 q=0.0 Lsize= 0kB time=00:00:00.00 bitrate=N/A throttle=off speed= 0x video:0kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown Output file is empty, nothing was encoded (check -ss / -t / -frames parameters if used) EXIT
alucryd 318 Posted December 2, 2019 Posted December 2, 2019 Thanks for the feedback. I'm told emby 4.3.0.24 is working fine, could you please check that version? If possible I'd like you to extract the command that is ran from that particular version so that I can compare it to the one in 4.3.0.30. Both ship with the exact same ffmpeg binary, so if anything isn't working it's probably down to the command.
Malmgren 17 Posted December 2, 2019 Author Posted December 2, 2019 Yep. I think I've found the culprit, it was there right in our faces all the time. In .24 the command used for this exact episode is /opt/emby-server/bin/ffmpeg -ss 00:08:07.520 -f avi -threads 1 -i file:"/mnt/nas/public/Serier/Trigger Happy TV/3x01 - Angry Cyclist.avi" -an -sn -threads 0 -vframes 1 -vf "scale=600:trunc(ow/a/2)*2,thumbnail=24" -f image2 "/var/lib/emby/cache/temp/96cb9986-a395-400b-a441-e90d4f4950f7.jpg" ...while for .30 it is /opt/emby-server/bin/ffmpeg -ss 15:08:26.480 -f avi -threads 1 -i file:"/mnt/nas/public/Serier/Trigger Happy TV/3x01 - Angry Cyclist.avi" -an -sn -threads 0 -vframes 1 -vf "scale=600:trunc(ow/a/2)*2,thumbnail=24" -f image2 "/var/lib/emby/cache/temp/66fdc849-aa59-4b9d-88de-4de3223c5051.jpg" The only different seems to be the ss option. So if I understand correctly, in version .24 it seeks eight minutes into the video, while in .30 it seeks over 15 hours. Which is far more than the total length of the video. So it seems someone simply broke how the seek time is calculated between .24 and .30.
Luke 42246 Posted December 4, 2019 Posted December 4, 2019 @@Malmgren what does the web app detail screen show as the runtime for that item?
Malmgren 17 Posted December 4, 2019 Author Posted December 4, 2019 @@Malmgren what does the web app detail screen show as the runtime for that item? It says 1h 21m. /Daniel
Luke 42246 Posted December 4, 2019 Posted December 4, 2019 Can you attach the emby server log from that, and the image extraction log, so that we can see context? Thanks.
Malmgren 17 Posted December 5, 2019 Author Posted December 5, 2019 Ok, attaching two logs. In the first one around 20:14:48 I refreshed the metadata for that episode in Emby 4.3.0.30. Then I stopped and downgraded Emby and did the same thing with 4.3.0.24, around 20:18:11. Does these logs show you what you need to see? /Daniel embyserver-63710914621.txt embyserver-63710920049.txt
Luke 42246 Posted December 6, 2019 Posted December 6, 2019 Hi, please see here if you'd like to help test a patch: https://emby.media/community/index.php?/topic/79620-v43026-crash-v43024b-seemed-fine/?p=816570 Thanks !
Malmgren 17 Posted December 7, 2019 Author Posted December 7, 2019 Nope, no luck. It still tries to extract the thumbnail from a point in time way after the movie ended: 2019-12-07 09:03:42.559 Info App: ProcessRun 'extract-image' Execute: /opt/emby-server/bin/ffmpeg -ss 15:10:13.902 -f avi -threads 1 -i file:"/mnt/nas/public/Serier/Trigger Happy TV/3x01 - Angry Cyclist.avi" -an -sn -threads 0 -vframes 1 -vf "scale=600:trunc(ow/a/2)*2,thumbnail=24" -f image2 "/var/lib/emby/cache/temp/1645a662-6d32-473f-8f9c-5a7699e6c164.jpg"
Malmgren 17 Posted December 9, 2019 Author Posted December 9, 2019 Also tried the latest beta (4.4.0.1) now, same problem there. /Daniel
softworkz 5133 Posted December 22, 2019 Posted December 22, 2019 @@Malmgren - It wasn't resolved in 4401, but it should be now (https://emby.media/community/index.php?/topic/79620-v43026-crash-v43024b-seemed-fine/?p=819073) Please try the latest beta.
softworkz 5133 Posted December 28, 2019 Posted December 28, 2019 @@Malmgren - Does it work with the latest beta?
Malmgren 17 Posted December 29, 2019 Author Posted December 29, 2019 @@Malmgren - Does it work with the latest beta? I went for the latest stable (4.3.1.0) instead and it seems to work now. I guess it's the same fix there as in the betas? /Daniel
