Faro83 0 Posted November 9, 2019 Posted November 9, 2019 Salve.. Come faccio a installare emby nella mia samsung smart TV UE55H6200AY? Grazie
FrostByte 5453 Posted November 9, 2019 Posted November 9, 2019 (edited) Salve.. Come faccio a installare emby nella mia samsung smart TV UE55H6200AY? Grazie Ciao ... l'app della community può essere installata usando le istruzioni qui: https://emby.media/community/index.php?/topic/9869-samsung-orsay-smarttv-2011-2014-community-app-install-instructions/?p=277344 oppure l'app ufficiale può essere installata usando le istruzioni qui: https://emby.media/community/index.php?/topic/45404-how-to-install-the-official-orsay-app-on-your-2014-h-series-tv-if-you-live-outside-the-us-uk-or-ireland/ Edited November 9, 2019 by FrostByte
nikita974 0 Posted March 25, 2020 Posted March 25, 2020 ciao ho il problema del certificato che non riesco ad risolvere , sempre su una serie F
FrostByte 5453 Posted March 25, 2020 Posted March 25, 2020 ciao ho il problema del certificato che non riesco ad risolvere , sempre su una serie F Are you trying to connect to someone else's server?
nikita974 0 Posted March 26, 2020 Posted March 26, 2020 yes on first tutorial server **.54 same result Failed to install. For more information, visithttp://www.samsungdforum.com/Support/TVAppsSecurity try follow your tutorial and build my IIS server to install app downloaded from github and same results
