vdatanet 1619 Posted October 22, 2019 Posted October 22, 2019 (edited) Most HEVC + DTS movies that require audio transcoding show green artifacts. Like this: https://streamable.com/w8gip Plex directs plays this movie and If I disable transcoding permission in user, Emby for Android TV also directs play the movie, without artifacts. So I guess my TV supports DTS and Emby App for Android TV is not able to detect it. I don't mind if DTS is not detected, my TV doesn't support DTS and audio needs to be transcoded. The issue are the artifacts shown when transcoding audio. Edit.- This is a cropped rip (those that didn't fire HDR when playing them with Nvidia Shield). Full remux rips doesn't exhibit this issue. ffmpeg-remux-02f944c0-6b7f-412e-839c-4f1383d2e358_1.txt Edited October 22, 2019 by vdatanet
vdatanet 1619 Posted October 26, 2019 Author Posted October 26, 2019 Does anyone else get these green artifacts when transcoding the audio of a reencoded 4k HDR movie from a Blu-ray? I have no problem with direct play, but in my systems where DTS is not supported (audio transcoding is needed), I see these green artifacts. Not just one movie, most of them.
ebr 16338 Posted October 26, 2019 Posted October 26, 2019 I think there are a number of topics sprinkled around right now referencing this basic issue with HEVC HDR video streams being stream copied and delivered via HLS. @
Guest asrequested Posted October 26, 2019 Posted October 26, 2019 Yeah, it's a container issue https://emby.media/community/index.php?/topic/75688-4k-hevc-files-freeze-after-a-few-seconds/
vdatanet 1619 Posted October 29, 2019 Author Posted October 29, 2019 @@ebr I've disabled surround sound on NVIDIA Shield. Now DTS audio direct plays and green artifacts are gone. Does mean that NVIDIA Shield can decode DTS audio and down mix to Stereo?
Luke 42246 Posted November 15, 2019 Posted November 15, 2019 It says direct playing in the server dashboard?
Guest asrequested Posted November 15, 2019 Posted November 15, 2019 @@ebr I've disabled surround sound on NVIDIA Shield. Now DTS audio direct plays and green artifacts are gone. Does mean that NVIDIA Shield can decode DTS audio and down mix to Stereo? Yes
vdatanet 1619 Posted November 15, 2019 Author Posted November 15, 2019 It says direct playing in the server dashboard? Yes. The only drawback is a slightly low volume.
